01-16-2021, 08:46 | #1 (permalink) |
Major Poster Join Date: Jan 2017 Location: Pakistan
Member: 2672863 Status: Offline Thanks Meter: 8 | g532g files flash done but not power on eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 18362 (10.0.18362.1) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 9D6FFA17D0342F5B Card Serial = AA38BBE2 EasyJTAG Box Firmware = 2.50 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1718 mV CMD Active Level: 1871 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2138 mV CMD Active Level: 2622 mV EMMC Device Information : EMMC CID: 90014A48384734759201CFE15A52B4CF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: CFE15A52 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_CFE15A52_20210116_123440.extcsd EMMC Init completed. Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2131 mV CMD Active Level: 2694 mV EMMC Device Information : EMMC CID: 90014A48384734759201CFE15A52B4CF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: CFE15A52 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_CFE15A52_20210116_123459.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16BB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 1466.12 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16BB_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 1420.08 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x00000C000000 Filename: EMMC_QN16BB_ROM1_000000000000_00000C000000.bin eMMC switching to ROM1 Writing partition... Error writing at address: 00000B520000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00000B520000 , error: -1, CMD Timeout Error ... Retry #2 Done writing partition. Write speed: 3928.90 KB/s All done time: [00:00:58:248] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2137 mV CMD Active Level: 2614 mV EMMC Device Information : EMMC CID: 90014A48384734759201CFE15A52B4CF EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: CFE15A52 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_CFE15A52_20210116_123607.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 (3.63 GB) GPT header successfully parsed |
