06-23-2020, 20:39 | #1 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | A5 2020 cph1931 emmc problem --------------------------------------------- ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E0350BA6AA6A642 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2019 Rev.0x3 eMMC NAME: hC8aP> , S/N: 1354394278 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hC8aP>_1354394278_20200623_2238.extcsd Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFD2 sectors 58.2 GiB Disk identifier (GUID): EDA28BBE-16DF-535F-3E5B-23E2DFE73EF6 Logical sector size: 0x200 bytes ,First/Last usable sector: 23,122142697 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x00A0020000 (6.246GB) Short EXT fs info: Size: 6.147GB Block size: 4.0KB Inode size: 256 Inodes: 403200 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x02A4020000 (47.678GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. |
06-23-2020, 20:42 | #2 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Z3X EasyJtag EMMC File Manager v 1.18 TEST at 04/04/2020 Started.. Box API Version: 3308 FS Driver Version: 11062019 SQLite Version: 3.30.1 FSCK Engine Version: 11062019 ESE DB Version: 11062019 System Util Version: 11062019 System: Windows NT 6.2 (Build 9200) / 64 BIT CPU: Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz !!FOR BETA-TESTERS ONLY!! Z3X Card Serial: AAA936A3 EasyJtag Box v1 Found at: COM19 EasyJtag Box Firmware: 1.63 Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 101111111110111 Setup HiPower CLK: OFF Disable HS Timing: TRUE Connecting To EasyJtag Box: 2800mV/21MHz/1BIT EasyJtag Box Found! Result: 0/OK CMD Pullup Level: 1773 mV CMD Active Level: 2567 mV EasyJtag S/N: 1201401CBB19DC97 EasyJtag Box FirmWare: 1.63 Box Bus Width = 1 BIT Box Hardware = EasyJtag 1st Generation Search EMMC Chip... EMMC Chip Found! 0/OK EMMC CID: 90014A68433861503E0350BA6AA6A642 EMMC CSD: D02700328F5903FFFFFFFFEF8E400042 EMMC VENDOR: SKHYNIX EMMC NAME: hC8aP> EMMC SERIAL: 50BA6AA6 EMMC REVISION: 03 EMMC ROM1 Size: 122142720 Block(s)/59640 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 32768 Block(s)/16384 KB EMMC RPMB Counter: 0 EMMC RPMB Answer: -1/UNKN_ERR Error While Switch ROM: -1/CMD_TOUT_ERR Scanner Thread Terminated Elapsed: 00:00:09:449 Found 0 Partition(s).. Search Partitions Fail.. Check EMMC or Run Pool Test.. ================ WITH PLUS.EE BUTT CANT DO ANY OPERATION Setting frequence to 21 MHz CMD Pullup Level: 1773 mV CMD Active Level: 2289 mV EMMC Device Information : EMMC CID: 90014A68433861503E0350BA6AA6A642 EMMC CSD: D02700328F5903FFFFFFFFEF8E400042 EMMC Manufacture : SKHYNIX , EMMC NAME: hC8aP> , HEX: 68433861503E , S/N: 50BA6AA6 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: hC8aP__50BA6AA6_20200623_224458.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Qualcomm Searching GPT ... Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 GPT header is found and is valid Checking for ROM2 ... Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #3 Stopped by User request... Last edited by chand_gee; 06-23-2020 at 20:47. |
06-24-2020, 11:44 | #3 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | WITH PLUS.EXE 23/06/2020 22:18:30> Operation: Remove Android Locks 23/06/2020 22:18:30> 23/06/2020 22:18:30> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 23/06/2020 22:18:30> 23/06/2020 22:18:40> Error reading at address: 000002005400 , error: -1, CMD Timeout Error ... Retry #1 23/06/2020 22:18:47> Error writing at address: 000002005400 ... Retry #1 23/06/2020 22:18:55> Error writing at address: 000002005400 ... Retry #2 23/06/2020 22:19:02> Error writing at address: 000002005400 ... Retry #3 23/06/2020 22:19:09> Too many errors. Writing has been stopped ============= WITH CLASIC EXE OPTION RESET OPPO Writing Recovery Command to MISC (50) mmc_write_blocks(0x77800000 , 1000 ), Failed: CMD Timeout Error Done. ================= WITH CLASIC EXE OPTION WIPE USER DATA eMMC CID : 90014A68433861503E0350BA6AA6A642 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2019 Rev.0x3 eMMC NAME: hC8aP> , S/N: 1354394278 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFD2 sectors 58.2 GiB Disk identifier (GUID): EDA28BBE-16DF-535F-3E5B-23E2DFE73EF6 Logical sector size: 0x200 bytes ,First/Last usable sector: 23,122142697 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x02A4020000 (47.678GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x0034800000 (256.0MB) Erasing... Done. --------------------------------------------- STUCK ON OPPO LOGO GO TO RECOVERY MODE AND WIPE DATA ITS DONE |
06-24-2020, 12:12 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | you have non-stable ISP connection try to use 14Mhz, use pull-up resistors on adapter, and HiPowerCLK mode with 4 CLK lines |
The Following 5 Users Say Thank You to layder For This Useful Post: |
06-24-2020, 12:39 | #5 (permalink) | |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
MY ISP WIRES ARE LIKE ROPE AND SOLDER WELL I HAVE SHORTED 4 clk AND ADDED 100ohm resistor also USED HIPOWERCLK MODE14mhz 21 mhz v2.8 3.3 etc etc result was same .."............... | |
