Old 09-13-2020, 11:15   #1 (permalink)
Member: 2425099
Thanks Meter: 14
a500f after flash dead
I tried repair boot With Easy-Jtag and aft but phone no power .is dead
please help me solution
log Easy-Jtag
---------- eMMC Device Information ----------
eMMC CID : 150100513331334D4200D6DE6A579222
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 09/2015 Rev.0x0
eMMC NAME: Q313MB , S/N: 3604900439
eMMC NAME (HEX): 513331334D42
IC Name: Samsung , KMQ310013M-B419/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 40 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: Q313MB_3604900439_20200911_2054.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB
Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000BFFF000 (2.246GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 147456
Short Android info:
Build ID: MMB29M
Display Build ID: MMB29M.A500FXXS1CPL2
Release Incremental ID: A500FXXS1CPL2
Release Base ID: 6.0.1
Security Path: 2016-12-01
Device Model: SM-A500F
Device Manufacturer: samsung
Device Name A: a5ltexx
Device Name B: a5lte
Device Board Name: MSM8916
Architecture ABI: armeabi-v7a
Device manufacturer: samsung
Device Platform: msm8916
Product ID: a5lte
Build Description: a5ltexx-user 6.0.1 MMB29M A500FXXS1CPL2 release-keys
PDA ver.: A500FXXS1CPL2
Hidden ver.: A500FXXS1CPL2
Samsung CPU: MSM8916
Backup saved: BuildProp_20200911_2054.txt
Detected USERDATA USERDATA : 0x00B23FF000 (11.889GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 131072
Short userdata info:
Unable to read gesture.key , code 2
Done.
log atf
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 150100513331334D4200D6DE6A579223
CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Boot Information
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3584 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 15758000128 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 4096 KB
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : Q313MB
Product Rev : 0.0
Product SN : D6DE6A57
Manufactured : January 1999
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
150100513331334D4200D6DE6A579223.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Start Writing Flash Images...
Flash Image: MBR + PGPT
Start Writing 0x00000032 Blocks at 0x00000000
Partition Selected: USER AREA
Total Elapsed Time 00:00:00
Write Success!
Flash Image: PIT
Start Writing 0x00000009 Blocks at 0x00000022
Write Success!
Flash Image: SGPT
Start Writing 0x00000021 Blocks at 0x01D59FDF
Write Success!
Flash Image: aboot.mbn
Start Writing 0x00001000 Blocks at 0x000267C0
Total Elapsed Time 00:00:04
Write Success!
Flash Image: sbl1.mbn
Start Writing 0x00000400 Blocks at 0x00026380
Total Elapsed Time 00:00:01
Write Success!
Flash Image: rpm.mbn
Start Writing 0x00000400 Blocks at 0x000277C0
Write Success!
Flash Image: tz.mbn
Start Writing 0x00000400 Blocks at 0x00027BC0
Write Success!
Flash Image: hyp.mbn
Start Writing 0x00000400 Blocks at 0x00027FC0
Write Success!
Flash Image: non-hlos.bin
Start Writing 0x00007800 Blocks at 0x00002000
Total Elapsed Time 00:00:26
Write Success!
Total Images Written: 6
Process Done!
The Following User Says Thank You to sadeghz For This Useful Post:
Old 09-14-2020, 10:07   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 1,867
you need ask this at ATF support section
I can't see EasyJTAG write firmware procedure
Page generated in 0.21476 seconds with 7 queries
