10-13-2020, 15:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | a107f dead repair done still dead Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = 0DFF8012C2EBA278 Card Serial = AAAF3D57 EasyJTAG Box Firmware = 1.6300 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting frequence to 21 MHz CMD Pullup Level: 1691 mV CMD Active Level: 1732 mV Can't init device. Reason: CMD CRC Error Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 2990 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_154854.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: para, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: efuse, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: nvram, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: efs, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: sec_efs, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: bota, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: param, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: up_param, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: expdb, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: frp, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: metadata, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: protect1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: protect2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: seccfg, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: persist, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: persistent, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: misc, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: sec1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: spmfw, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: lk, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: steady, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: boot, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: recovery, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: dtbo, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: tee1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: vendor, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: product, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: system, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: vbmeta, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: cache, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: omr, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: userdata, [000150000000 - 000747800000], size: 0005F7800000 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 2939 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_155348.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: para, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: efuse, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: nvram, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: efs, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: sec_efs, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: bota, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: param, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: up_param, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: expdb, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: frp, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: metadata, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: protect1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: protect2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: seccfg, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: persist, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: persistent, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: misc, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: sec1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: spmfw, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: lk, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: steady, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: boot, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: recovery, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: dtbo, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: tee1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: vendor, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: product, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: system, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: vbmeta, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: cache, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: omr, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: userdata, [000150000000 - 000747800000], size: 0005F7800000 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 2031 mV CMD Active Level: 2990 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_155358.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x02 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QD63MB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 415.41 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QD63MB_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Writing partition... Error writing at address: 0000003B8000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Done writing partition. Write speed: 401.21 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000 Filename: EMMC_QD63MB_ROM1_000000000000_000040000000.bin eMMC switching to ROM1 Writing partition... Error writing at address: 000003300000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000003300000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 000003300000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Writing has been stopped Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 2990 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_155546.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: para, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: efuse, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: nvram, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: efs, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: sec_efs, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: bota, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: param, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: up_param, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: expdb, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: frp, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: metadata, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: protect1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: protect2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: seccfg, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: persist, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: persistent, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: misc, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: sec1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: spmfw, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: lk, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: steady, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: boot, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: recovery, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: dtbo, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: tee1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: vendor, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: product, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: system, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: vbmeta, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: cache, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: omr, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: userdata, [000150000000 - 000747800000], size: 0005F7800000 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 2970 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_155556.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x02 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QD63MB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 411.60 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QD63MB_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 416.84 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000 Filename: EMMC_QD63MB_ROM1_000000000000_000040000000.bin eMMC switching to ROM1 Writing partition... Error writing at address: 000000380000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000003900000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000006E80000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00000A400000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00000D940000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000010940000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error: Previous operation is not finished yet. Error: Previous operation is not finished yet. Error: Previous operation is not finished yet. Stopped by User request... Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 3052 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160229.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: para, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: efuse, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: nvram, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: efs, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: sec_efs, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: bota, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: param, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: up_param, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: expdb, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: frp, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: metadata, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: protect1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: protect2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: seccfg, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: persist, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: persistent, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: misc, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: sec1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: spmfw, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: lk, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: steady, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: boot, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: recovery, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: dtbo, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: tee1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: vendor, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: product, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: system, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: vbmeta, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: cache, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: omr, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: userdata, [000150000000 - 000747800000], size: 0005F7800000 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 2010 mV CMD Active Level: 3062 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160238.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x02 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_ROM2_QD63MB_2361984962_00000000_00400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 406.84 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_ROM3_QD63MB_2361984962_00000000_00400000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 407.19 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000 Filename: EMMC_ROM1_QD63MB_2361984962_00000000_40000000.bin eMMC switching to ROM1 Writing partition... Error writing at address: 000002140000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000005680000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error: Previous operation is not finished yet. Stopped by User request... Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 3042 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160527.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOOT_PARA, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: PARA, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: EFUSE, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: NVRAM, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: EFS, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: SEC_EFS, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: BOTA, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: PARAM, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: UP_PARAM, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: EXPDB, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: FRP, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: NVCFG, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: NVDATA, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: METADATA, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: PROTECT1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: SECCFG, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: PERSIST, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: PERSISTENT, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: MISC, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: SEC1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: PROINFO, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: MD1IMG, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: SPMFW, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: SCP1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: SSPM_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: LK, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: STEADY, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: BOOT, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: DTBO, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: TEE1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: VENDOR, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: PRODUCT, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: SYSTEM, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: VBMETA, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: CACHE, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: OMR, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: USERDATA, [000150000000 - 000747BFBE00], size: 0005F7BFBE00 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 2010 mV CMD Active Level: 3052 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160536.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x02 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_ROM2_QD63MB_2361984962_00000000_00400000.bin eMMC switching to ROM2 Writing partition... Error writing at address: 000000360000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 000000360000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 000000360000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Writing has been stopped Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 2990 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160657.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000 Filename: EMMC_ROM1_QD63MB_2361984962_00000000_40000000.bin eMMC switching to ROM1 Writing partition... Stopped by User request... Setting frequence to 21 MHz Error: Previous operation is not finished yet. CMD Pullup Level: 2010 mV CMD Active Level: 2990 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160709.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOOT_PARA, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: PARA, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: EFUSE, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: NVRAM, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: EFS, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: SEC_EFS, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: BOTA, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: PARAM, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: UP_PARAM, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: EXPDB, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: FRP, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: NVCFG, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: NVDATA, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: METADATA, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: PROTECT1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: SECCFG, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: PERSIST, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: PERSISTENT, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: MISC, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: SEC1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: PROINFO, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: MD1IMG, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: SPMFW, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: SCP1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: SSPM_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: LK, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: STEADY, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: BOOT, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: DTBO, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: TEE1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: VENDOR, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: PRODUCT, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: SYSTEM, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: VBMETA, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: CACHE, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: OMR, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: USERDATA, [000150000000 - 000747BFBE00], size: 0005F7BFBE00 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error Setting frequence to 21 MHz CMD Pullup Level: 2031 mV CMD Active Level: 3042 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160744.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOOT_PARA, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: PARA, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: EFUSE, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: NVRAM, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: EFS, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: SEC_EFS, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: BOTA, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: PARAM, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: UP_PARAM, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: EXPDB, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: FRP, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: NVCFG, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: NVDATA, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: METADATA, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: PROTECT1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: SECCFG, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: PERSIST, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: PERSISTENT, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: MISC, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: SEC1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: PROINFO, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: MD1IMG, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: SPMFW, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: SCP1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: SSPM_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: LK, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: STEADY, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: BOOT, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: DTBO, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: TEE1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: VENDOR, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: PRODUCT, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: SYSTEM, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: VBMETA, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: CACHE, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: OMR, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: USERDATA, [000150000000 - 000747BFBE00], size: 0005F7BFBE00 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 3021 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160844.extcsd EMMC Init completed. Opening file: A10S_EUR_OPEN.pit Pit: A10S_EUR_OPEN.pit Entry count: 44 The size of the last section has been updated BL_A107FXXU6BTF1_CL18740799_QB31905611_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img.lz4 lk.img.lz4 param.bin.lz4 up_param.bin.lz4 efuse.img.lz4 Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error Setting frequence to 21 MHz CMD Pullup Level: 2010 mV CMD Active Level: 2939 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160932.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOOT_PARA, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: PARA, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: EFUSE, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: NVRAM, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: EFS, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: SEC_EFS, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: BOTA, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: PARAM, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: UP_PARAM, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: EXPDB, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: FRP, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: NVCFG, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: NVDATA, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: METADATA, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: PROTECT1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: SECCFG, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: PERSIST, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: PERSISTENT, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: MISC, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: SEC1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: PROINFO, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: MD1IMG, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: SPMFW, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: SCP1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: SSPM_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: LK, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: STEADY, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: BOOT, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: DTBO, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: TEE1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: VENDOR, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: PRODUCT, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: SYSTEM, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: VBMETA, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: CACHE, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: OMR, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: USERDATA, [000150000000 - 000747BFBE00], size: 0005F7BFBE00 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 3052 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_160947.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking Lz4: preloader.img.lz4 Unpacking file: efuse.img Unpacking Lz4: efuse.img.lz4 Unpacking file: param.bin Unpacking Lz4: param.bin.lz4 Unpacking file: up_param.bin Unpacking Lz4: up_param.bin.lz4 Unpacking file: lk.img Unpacking Lz4: lk.img.lz4 Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 258560 bytes eMMC switching to ROM2 Erasing partition... Error erasing at address: 0000003B0000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Writing partition... Done writing partition. Write speed: 391.48 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000000580000 , filesize: 1024 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 77.10 KB/s Partition name: PARAM Filename: param.bin , Offset: 000006B00000 , filesize: 123392 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 448.96 KB/s Partition name: UP_PARAM Filename: up_param.bin , Offset: 000006F00000 , filesize: 727552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 875.65 KB/s Partition name: LK Filename: lk.img , Offset: 00001C400000 , filesize: 1276128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 871.19 KB/s Check BootConfig for the selected vendor All done time: [00:00:19:401] Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 3011 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201013_161652.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOOT_PARA, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: PARA, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: EFUSE, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: NVRAM, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: EFS, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: SEC_EFS, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: BOTA, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: PARAM, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: UP_PARAM, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: EXPDB, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: FRP, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: NVCFG, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: NVDATA, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: METADATA, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: PROTECT1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: SECCFG, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: PERSIST, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: PERSISTENT, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: MISC, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: SEC1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: PROINFO, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: MD1IMG, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: SPMFW, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: SCP1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: SSPM_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: LK, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: STEADY, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: BOOT, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: DTBO, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: TEE1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: VENDOR, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: PRODUCT, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: SYSTEM, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: VBMETA, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: CACHE, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: OMR, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: USERDATA, [000150000000 - 000747BFBE00], size: 0005F7BFBE00 (23.8 GB) GPT header successfully parsed Get firmware version |
10-14-2020, 10:39 | #5 (permalink) | |
Member: 430612 Status: Offline Thanks Meter: 301 | Quote:
READ EMMC eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = 0DFF8012C2EBA278 Card Serial = AAAF3D57 EasyJTAG Box Firmware = 1.6300 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting frequence to 21 MHz CMD Pullup Level: 1680 mV CMD Active Level: 1732 mV Can't init device. Reason: CMD CRC Error Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error Setting frequence to 21 MHz CMD Pullup Level: 2010 mV CMD Active Level: 3000 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201014_113345.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOOT_PARA, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: PARA, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: EFUSE, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: NVRAM, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: EFS, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: SEC_EFS, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: BOTA, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: PARAM, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: UP_PARAM, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: EXPDB, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: FRP, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: NVCFG, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: NVDATA, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: METADATA, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: PROTECT1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: SECCFG, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: PERSIST, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: PERSISTENT, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: MISC, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: SEC1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: PROINFO, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: MD1IMG, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: SPMFW, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: SCP1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: SSPM_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: LK, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: STEADY, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: BOOT, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: DTBO, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: TEE1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: VENDOR, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: PRODUCT, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: SYSTEM, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: VBMETA, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: CACHE, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: OMR, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: USERDATA, [000150000000 - 000747BFBE00], size: 0005F7BFBE00 (23.8 GB) GPT header successfully parsed Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 2031 mV CMD Active Level: 2990 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201014_113428.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM1 , start: 0x000000000000 , size: 0x000040000000 Output file: C:\Program Files\Z3X\EASYJTAGPLUS\Backups\a10s\EMMC_QX63MB_RO M1_000000000000_000040000000.bin eMMC switching to ROM1 Reading partition... Error reading at address: 000002140000 , error: -206, PORT Read Error ... Retry #1 Error reading at address: 000002140000 , error: -2, CMD CRC Error ... Retry #2 Error reading at address: 000002140000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Reading has been stopped Try the "Skip unreadable blocks" option | |
