06-02-2022, 16:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: IRAN Age: 39
Member: 1391134 Status: Offline Thanks Meter: 47 | a605g change emmc and boot repair done but phone is not working Z3X EasyJtag Software ver. 3.7.0.23 Skip loading eMMC Addon Firmware CMD Pullup Level:2000 mV CMD Active Level:2526 mV Input file : C:\New folder (6)\A600G\EMMC_RH64AB_ROM1_000000000000_0000400000 00.bin Writing 0040000000 bytes to 0000000000... ROM1 (USER ROM) Done, time taken: 266 sec. Average Write Speed: 4024 kB/s Z3X EasyJtag Software ver. 3.7.0.23 Skip loading eMMC Addon Firmware CMD Pullup Level:2000 mV CMD Active Level:2526 mV Input file : C:\New folder (6)\A600G\EMMC_RH64AB_ROM2_000000000000_0000004000 00.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done, time taken: 4 sec. Average Write Speed: 854 kB/s Z3X EasyJtag Software ver. 3.7.0.23 Skip loading eMMC Addon Firmware CMD Pullup Level:2000 mV CMD Active Level:2526 mV Input file : C:\New folder (6)\A600G\EMMC_RH64AB_ROM3_000000000000_0000004000 00.bin Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done, time taken: 4 sec. Average Write Speed: 868 kB/s Z3X EasyJtag Software ver. 3.7.0.23 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0A00E013F603DAEE, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2598 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100524836344D42054CB668AE84B6 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2017 Rev.0x5 eMMC NAME: RH64MB , S/N: 1287022766 eMMC NAME (HEX): 524836344D42 IC Name: Samsung , KMRH60014M-B614/64GB @BGA221 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RH64MB_1287022766_20220602_1853.extcsd Caution: invalid backup GPT header, but valid main header! EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0015800000 (3.85GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Detected USERDATA USERDATA : 0x0123D00000 (53.681GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021) Microsoft Windows 10 (64 bit) build 16299 (10.0.16299.1480) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = 0A00E013F603DAEE Card Serial = AAEC997E EasyJTAG Box Firmware = 1.6300 Changelog: 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2598 mV EMMC Device Information : EMMC CID: 150100524836344D30051A0168AE84AE EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RH64M0 , HEX: 524836344D30 , S/N: 1A0168AE , rev. 0x05 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: RH64M0_1A0168AE_20220602_193543.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB) Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB) Partition: ddr, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: rpm, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: tz, [000000600000 - 000000800000], size: 000000200000 (2.00 MB) Partition: aboot, [000000800000 - 000000A00000], size: 000000200000 (2.00 MB) Partition: sec, [000000A00000 - 000000A40000], size: 000000040000 (256. KB) Partition: lksecapp, [000000A40000 - 000000AC0000], size: 000000080000 (512. KB) Partition: keymaster, [000000AC0000 - 000000B40000], size: 000000080000 (512. KB) Partition: cmnlib, [000000B40000 - 000000B80000], size: 000000040000 (256. KB) Partition: fsg, [000000B80000 - 000000F80000], size: 000000400000 (4.00 MB) Partition: cmnlib64, [000000F80000 - 000000FC0000], size: 000000040000 (256. KB) Partition: pad, [000000FC0000 - 000001000000], size: 000000040000 (256. KB) Partition: modemst1, [000001000000 - 000001400000], size: 000000400000 (4.00 MB) Partition: modemst2, [000001400000 - 000001800000], size: 000000400000 (4.00 MB) Partition: efs, [000001C00000 - 000002C00000], size: 000001000000 (16.0 MB) Partition: fsc, [000002C00000 - 000002F40000], size: 000000340000 (3.25 MB) Partition: ssd, [000002F40000 - 000002F80000], size: 000000040000 (256. KB) Partition: devcfg, [000002F80000 - 000002FC0000], size: 000000040000 (256. KB) Partition: apdp, [000002FC0000 - 000002FE0000], size: 000000020000 (128. KB) Partition: msadp, [000002FE0000 - 000003000000], size: 000000020000 (128. KB) Partition: param, [000003000000 - 000003C00000], size: 000000C00000 (12.0 MB) Partition: backup, [000003C00000 - 000004000000], size: 000000400000 (4.00 MB) Partition: misc, [000004000000 - 000004100000], size: 000000100000 (1.00 MB) Partition: boot, [000004100000 - 000006100000], size: 000002000000 (32.0 MB) Partition: recovery, [000006100000 - 000008100000], size: 000002000000 (32.0 MB) Partition: dtbo, [000008100000 - 000008300000], size: 000000200000 (2.00 MB) Partition: bota, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: fota, [000008B00000 - 000008F00000], size: 000000400000 (4.00 MB) Partition: nad_refer, [000008F00000 - 000009500000], size: 000000600000 (6.00 MB) Partition: persist, [000009500000 - 00000B500000], size: 000002000000 (32.0 MB) Partition: persistent, [00000B500000 - 00000B600000], size: 000000100000 (1.00 MB) Partition: steady, [00000B600000 - 00000BA00000], size: 000000400000 (4.00 MB) Partition: keystore, [00000BA00000 - 00000BB00000], size: 000000100000 (1.00 MB) Partition: config, [00000BB00000 - 00000BC00000], size: 000000100000 (1.00 MB) Partition: dsp, [00000BC00000 - 00000CC00000], size: 000001000000 (16.0 MB) Partition: modem, [00000CC00000 - 000012C00000], size: 000006000000 (96.0 MB) Partition: apnhlos, [000012C00000 - 000015000000], size: 000002400000 (36.0 MB) Partition: debug, [000015000000 - 000015800000], size: 000000800000 (8.00 MB) Partition: system, [000015800000 - 0000DB000000], size: 0000C5800000 (3.09 GB) Partition: vendor, [0000DB000000 - 0000F9000000], size: 00001E000000 (480. MB) Partition: odm, [0000F9000000 - 00010F800000], size: 000016800000 (360. MB) Partition: cache, [00010F800000 - 000122400000], size: 000012C00000 (300. MB) Partition: hidden, [000122400000 - 000122900000], size: 000000500000 (5.00 MB) Partition: omr, [000122900000 - 000123D00000], size: 000001400000 (20.0 MB) Partition: userdata, [000123D00000 - 000E8F7FB000], size: 000D6BAFB000 (53.6 GB) GPT header successfully parsed Get firmware version Firmware info not found HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2598 mV EMMC Device Information : EMMC CID: 150100524836344D30051A0168AE84AE EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RH64M0 , HEX: 524836344D30 , S/N: 1A0168AE , rev. 0x05 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: RH64M0_1A0168AE_20220602_193603.extcsd EMMC Init completed. Opening file: A6PLTE_EUR_OPEN.pit Pit: A6PLTE_EUR_OPEN.pit Entry count: 51 The size of the last section has been updated BL_A605GDXU9CVB1_CL23318745_QB48995193_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: aboot.mbn.lz4 sbl1.mbn.lz4 rpm.mbn.lz4 tz.mbn.lz4 devcfg.mbn.lz4 cmnlib.mbn.lz4 keymaster.mbn.lz4 apdp.mbn.lz4 msadp.mbn.lz4 non-hlos.bin.lz4 lksecapp.mbn.lz4 sec.dat.lz4 HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2598 mV EMMC Device Information : EMMC CID: 150100524836344D30051A0168AE84AE EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RH64M0 , HEX: 524836344D30 , S/N: 1A0168AE , rev. 0x05 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: RH64M0_1A0168AE_20220602_193627.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Unpacking file: sbl1.mbn Unpacking Lz4: sbl1.mbn.lz4 Unpacking file: rpm.mbn Unpacking Lz4: rpm.mbn.lz4 Unpacking file: tz.mbn Unpacking Lz4: tz.mbn.lz4 Unpacking file: aboot.mbn Unpacking Lz4: aboot.mbn.lz4 Unpacking file: sec.dat Unpacking Lz4: sec.dat.lz4 Unpacking file: lksecapp.mbn Unpacking Lz4: lksecapp.mbn.lz4 Unpacking file: keymaster.mbn Unpacking Lz4: keymaster.mbn.lz4 Unpacking file: cmnlib.mbn Unpacking Lz4: cmnlib.mbn.lz4 Unpacking file: devcfg.mbn Unpacking Lz4: devcfg.mbn.lz4 Unpacking file: apdp.mbn Unpacking Lz4: apdp.mbn.lz4 Unpacking file: msadp.mbn Unpacking Lz4: msadp.mbn.lz4 Unpacking file: non-hlos.bin Unpacking Lz4: non-hlos.bin.lz4 Partition name: SBL1 Filename: sbl1.mbn , Offset: 000000400000 , filesize: 374888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 449.13 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000000580000 , filesize: 176124 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 408.37 KB/s Partition name: TZ Filename: tz.mbn , Offset: 000000600000 , filesize: 1519360 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 866.41 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000000800000 , filesize: 1581300 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 855.35 KB/s Partition name: SEC Filename: sec.dat , Offset: 000000A00000 , filesize: 948 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 75.54 KB/s Partition name: LKSECAPP Filename: lksecapp.mbn , Offset: 000000A40000 , filesize: 250728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 851.33 KB/s Partition name: KEYMASTER Filename: keymaster.mbn , Offset: 000000AC0000 , filesize: 230616 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 842.07 KB/s Partition name: CMNLIB Filename: cmnlib.mbn , Offset: 000000B40000 , filesize: 205984 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 853.25 KB/s Partition name: DEVCFG Filename: devcfg.mbn , Offset: 000002F80000 , filesize: 38748 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 611.92 KB/s Partition name: APDP Filename: apdp.mbn , Offset: 000002FC0000 , filesize: 13760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 482.66 KB/s Partition name: MSADP Filename: msadp.mbn , Offset: 000002FE0000 , filesize: 13760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 498.11 KB/s Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000012C00000 , filesize: 36378624 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 860.84 KB/s Partition CACHE : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:03:26:702] now the phone is in download mode but show RPMB PROVISIONED,but HMAC mismatch error i try to chanhe RPMB from 4 to 16 mib but failed this operation any solution ? tx z3x team |
06-13-2022, 12:02 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | qualcom updates have to do i think in rpmb just theory..me and 1 guy also here have problem with qualcom samsung phone..he change emmc..me i just erase rpmb but we connot make the phone to work even if we have the full dump..flashing latest binary available also did not solve the problem..if you still have the old emmc try to read its rpmb..we try to write it back to the new emmc and check if any changes can be made this problem |
