Member: 1344199
Thanks Meter: 13 | Warning: Health report is very BAD To the respected supporters,
How to deal with this issue
IM VERY NEW IN EASY JTAG
Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used
Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used
Pre EOL information [267]: 0x03 Urgent
--Waiting for good responce Quote:
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 36 MHz
CMD Pullup Level: 1809 mV
CMD Active Level: 1860 mV
EMMC Device Information :
EMMC CID: 90014A484347386134A22899A50D354F
EMMC CSD: D02701328F5903FFFFFFFFEF8A400027
EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2899A50D , rev. 0xA2
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2018
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 135644 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HCG8a4_2899A50D_20210109_142619.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB)
Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB)
Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB)
Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB)
Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB)
Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB)
Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB)
Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB)
Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB)
Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 (256. KB)
Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 (256. KB)
Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 (16.0 MB)
Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 (1.50 MB)
Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 (1.50 MB)
Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB)
Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB)
Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB)
Partition: splash, [000014000000 - 000014B00000], size: 000000B00000 (11.0 MB)
Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB)
Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB)
Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB)
Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB)
Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB)
Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 (3.00 GB)
Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 (256. MB)
Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 (32.0 MB)
Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 (1.00 MB)
Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 (512. KB)
Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 (32.0 KB)
Partition: oem, [0000F6188000 - 000106188000], size: 000010000000 (256. MB)
Partition: limits, [000108000000 - 000108008000], size: 000000008000 (32.0 KB)
Partition: mota, [00010C000000 - 00010C080000], size: 000000080000 (512. KB)
Partition: dip, [00010C080000 - 00010C180000], size: 000000100000 (1.00 MB)
Partition: mdtp, [00010C180000 - 00010E180000], size: 000002000000 (32.0 MB)
Partition: syscfg, [00010E180000 - 00010E200000], size: 000000080000 (512. KB)
Partition: mcfg, [00010E200000 - 00010E600000], size: 000000400000 (4.00 MB)
Partition: lksecapp, [000110000000 - 000110020000], size: 000000020000 (128. KB)
Partition: lksecappbak, [000110020000 - 000110040000], size: 000000020000 (128. KB)
Partition: cmnlib, [000110040000 - 000110080000], size: 000000040000 (256. KB)
Partition: cmnlibbak, [000110080000 - 0001100C0000], size: 000000040000 (256. KB)
Partition: cmnlib64, [0001100C0000 - 000110100000], size: 000000040000 (256. KB)
Partition: cmnlib64bak, [000110100000 - 000110140000], size: 000000040000 (256. KB)
Partition: keymaster, [000110140000 - 000110180000], size: 000000040000 (256. KB)
Partition: keymasterbak, [000110180000 - 0001101C0000], size: 000000040000 (256. KB)
Partition: apdp, [000114000000 - 000114040000], size: 000000040000 (256. KB)
Partition: msadp, [000114040000 - 000114080000], size: 000000040000 (256. KB)
Partition: dpo, [000114080000 - 000114082000], size: 000000002000 (8.00 KB)
Partition: logdump, [000114082000 - 000118082000], size: 000004000000 (64.0 MB)
Partition: cust, [000118082000 - 00014C082000], size: 000034000000 (832. MB)
Partition: userdata, [00014C082000 - 000E8F7FBE00], size: 000D43779E00 (53.0 GB)
GPT header successfully parsed
Get firmware version
Brand = xiaomi
Manufacturer = Xiaomi
Device = vince
Model = Redmi 5 Plus
Phone platform = msm8953
CPU Abi = arm64-v8a
Android release = 8.1.0
Security Patch = 2019-10-01
Firmware version = ZQL1711-vince-build-20191108142512
Miui Version = V11.0.2.0.OEGMIXM
Firmware date = Fri Nov 8 14:24:59 WIB 2019
