01-18-2020, 22:00 | #1 (permalink) |
Junior Member Join Date: Jan 2020 Location: everywhere😁
Member: 2944631 Status: Offline Thanks Meter: 1 | Smart Card Driver in Easy JTag box I had purchased easy jtag plus box. I had installed sell and SamsungToolPro . I have A problem in samrt card driver, from device manager >> smart card>> unknown smart card>> device status : No drivers are installed for this device. . how to fix this driver... |
The Following User Says Thank You to Hamid1980 For This Useful Post: |
01-21-2020, 12:43 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | 1) check EasyJTAG/EasyJTAG Plus activation via z3x Shell - Hardware wizard - card info 2) check EasyJTAG Plus box driver is installed correctly - (you need see Hi-Speed interface and COM port) 3) Card will need be inserted at Z3x EasyJTAG box |
The Following User Says Thank You to layder For This Useful Post: |
01-23-2020, 10:21 | #5 (permalink) |
Member: 2944631 Status: Offline Thanks Meter: 1 | Dear Points 1 and 3 are done correctly. Can you please tell me more details about point 2? like how much speed I should adjust for port? how I make the speeds of BOX and PORT the same? CAN you please insert some pictures.. THANK YOU |
01-23-2020, 13:30 | #6 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | you need install driver for box from EasyJTAG Classic folder (Drivers/EasyJTAG V2 subfolder) |
02-16-2020, 08:48 | #7 (permalink) |
Member: 2944631 Status: Offline Thanks Meter: 1 | DEAR I tried to install driver for box from EasyJTAG Classic folder (Drivers/EasyJTAG V2 subfolder) as you mentioned, but I encountered an errors while installing now I can't attach pics to show porblem. |
