09-27-2020, 09:24 | #1 (permalink) |
Freak Poster Join Date: Mar 2015 Location: some way in da world
Member: 2360557 Status: Offline Thanks Meter: 29 | about to fix dead boot samsung a105f n a107f always error Microsoft Windows 10 (32 bit) build 10586 (10.0.10586.1106) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = B0227941E16B0A59 Card Serial = AAEF248F EasyJTAG Box Firmware = 2.5204 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 443 mV CMD Active Level: 1159 mV Can't init device. Reason: CMD Timeout Error |
The Following User Says Thank You to butt.cell For This Useful Post: |
09-28-2020, 06:29 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Try to use Latest EasyJTAG Classic software and choose different VIO settings Also you can use HiPower CLK mode with USB-powered board (connect onli GND/CLK/CMD/Dat_0) |
The Following User Says Thank You to layder For This Useful Post: |
09-30-2020, 13:15 | #3 (permalink) | |
Insane Poster Join Date: Nov 2011 Age: 42
Member: 1683660 Status: Offline Thanks Meter: 14 | Quote:
I had the same problem with the a105f device with easy jtag plus the solution was done by connecting a resistance of 100 ohms between the vccq line and the cmd line and choosing the frequency 9mhz or 1mhz note: i do not have an isp adapter i use direct connection to the box and in this case i connected the power vcc and vccq from the box and not From usb, you have to try and try to find the solution. also in my case the emmc was corrupted Last edited by wissammic; 09-30-2020 at 13:22. | |
