07-24-2014, 10:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | After update, Easy Jtag box not detected... how to solve this problem, i'm new user of this box. |
07-24-2014, 11:25 | #4 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Please - check following: Your Windows XP version need be SP3 , oldes have issue with composite devices. Latest driver must installed 3.0.0.0 If software continue with problems you can run diag package and update firmware with service sw ( https://mega.co.nz/#!ecVRGJ4Y!jylfMP...cAIAAHN-4qJSRA ) |
The Following User Says Thank You to NoName® For This Useful Post: |
07-24-2014, 19:05 | #5 (permalink) |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Checking if JTAG present... EASY Jtag BOX not found Searching card... [1] ----------------------------- Card status :Card not found Trying find box Box not found in normal mode... Trying find box in update mode... Found update port COM203 Updating... Done... Now box are working like standart Unibox Trying find box Box not found in normal mode... Trying find box in update mode... Found update port COM203 Updating... Done... Now box are working like standart Unibox Trying find box Box not found Port Open Error |
08-27-2020, 21:27 | #8 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2550430 Status: Offline Thanks Meter: 1 | easy jtag box is not detected please check is inside Problem easy jtag box is not detected please check is inside z3x card is not detected. please check card is inside. software will be closed now. error code: -9103 |
