08-28-2020, 07:21 | #1 (permalink) |
Junior Member Join Date: Sep 2019 Location: Indonesia
Member: 2927084 Status: Offline Thanks Meter: 1 | Hello team please fix error Code: -2303, Reason: UTP: UPIU QUERY UFS Chip Voltage: Low Can't init device, Code: -2303, Reason: UTP: UPIU QUERY result fail: General failure VCC: 3256mV VCCQ2: 1779mV this ufs chip is normal but can't identify THGBF7T0L8LBATA 128GB |
12-26-2020, 17:30 | #4 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Saudi Arabia-Riyadh
Member: 1464763 Status: Offline Sonork: 100.1615235 Thanks Meter: 30 | Z3X EasyJtag Software ver. 3.7.0.20 UFS Socket Info. Serial: 012321EE0E9B13DBEE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 25.11.20 Identify UFS Chip. UFS Chip Voltage: High Check ISP connect. Can't init device, Code: -2303, Reason: UTP: UPIU QUERY result fail: General failure VCC: 3327mV VCCQ2: 1920mV UFS Version: 2.0 Done. |
12-26-2020, 19:20 | #5 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Post photo of you connection and chip/pcb info Last edited by layder; 12-27-2020 at 13:58. | |
07-08-2022, 14:03 | #6 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1953034 Status: Offline Thanks Meter: 0 | help with error: Can't init device, Code: -2303, Reason: UTP: UPIU QUERY result fail: hello i faced the same error for UFS (MICRON IDA22) pulled out from working poco f3 can't be detected. (i have tried low and high voltage and emmc PLUS2) (also tried with Disable UFS safe mode) any solution??? log: Z3X EasyJtag Software ver. 3.7.0.24 UFS Socket Info. Serial: 01234B71326286FDEE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 08.11.20 Identify UFS Chip. UFS Chip Voltage: High Can't init device, Code: -2303, Reason: UTP: UPIU QUERY result fail: General failure VCC: 3164mV VCCQ2: 1920mV Done. |
07-08-2022, 18:21 | #7 (permalink) |
Member: 2927084 Status: Offline Thanks Meter: 1 | in general this problem is the ufs chip which is still alive if it is installed on the cellphone board, but can't be identified with easy jtag plus, until now it is still not solved, I still have the UFS chip in the first post. |
12-13-2022, 16:17 | #8 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: HIGH Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: OFF Warning! Using this option maybe damage a chip.. Initialize UFS Engine Fail. Code: -2303/ERROR_UFS_UTP_UPIU_QUERY_FAIL_GENERAL_FAILURE Scanner Thread Terminated Elapsed: 00:00:07:842 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: OFF Warning! Using this option maybe damage a chip.. Initialize UFS Engine Fail. Code: -2303/ERROR_UFS_UTP_UPIU_QUERY_FAIL_GENERAL_FAILURE Scanner Thread Terminated Elapsed: 00:00:12:514 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -2303/ERROR_UFS_UTP_UPIU_QUERY_FAIL_GENERAL_FAILURE Scanner Thread Terminated Elapsed: 00:00:01:826 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
12-13-2022, 16:17 | #9 (permalink) |
The Following User Says Thank You to Aamir_Zia For This Useful Post: |
