11-21-2021, 14:46 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | ANE-LX1 dead boot .Please help with my 1st attempt. Thanks I have taken the ic off and put in the emmc socket 153. Now the log is below do you see any problem with it ? Or shall i just reball it and install back on the phone. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1571mV pin connected ok command: 1582mV pin connected ok data0: 1579mV pin connected ok data1: 1577mV pin connected ok data2: 1580mV pin connected ok data3: 1579mV pin connected ok data4: 1580mV pin connected ok data5: 1579mV pin connected ok data6: 1575mV pin connected ok data7: 1579mV pin connected ok Box S/N: DCCF25759D761xxx, ,FW Ver.: 02.53 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E53304A33385910075B15019519 eMMC CSD : D05F01328F5913FFFFFFFFEF964000A9 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 09/2018 Rev.0x10 eMMC NAME: S0J38Y , S/N: 123409665 eMMC NAME (HEX): 53304A333859 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 87 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: S0J38Y_ 123409665_20211121_1333.extcsd Caution: invalid backup GPT header, but valid main header! Caution! After loading partitions, the CRC doesn't check out! EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. You will need to delete this partition or resize it in another utility. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Detected 65 partitions ------ P0 (VRL) [0x80000 0x40000] Size: 256.0KB P1 (VRL_BACKUP) [0xc0000 0x40000] Size: 256.0KB P2 (FW_LPM3) [0x100000 0x40000] Size: 256.0KB P3 (FRP) [0x140000 0xc0000] Size: 768.0KB P4 (FASTBOOT) [0x200000 0x400000] Size: 4.0MB P5 (MODEMNVM_FACTORY) [0x600000 0x400000] Size: 4.0MB P6 (NVME) [0xa00000 0x600000] Size: 6.0MB P7 (OEMINFO) [0x1000000 0x4000000] Size: 64.0MB P8 (RESERVED3) [0x5000000 0x400000] Size: 4.0MB P9 (MODEMNVM_BACKUP) [0x5400000 0x400000] Size: 4.0MB P10 (MODEMNVM_IMG) [0x5800000 0x800000] Size: 8.0MB P11 (MODEMNVM_SYSTEM) [0x6000000 0x400000] Size: 4.0MB P12 (SECURE_STORAGE) [0x6400000 0x2000000] Size: 32.0MB P13 (RESERVED4) [0x8400000 0x200000] Size: 2.0MB P14 (RESERVED5) [0x8600000 0x200000] Size: 2.0MB P15 (PERSIST) [0x8800000 0x200000] Size: 2.0MB P16 (MODEM_SECURE) [0x8a00000 0xe00000] Size: 14.0MB P17 (MODEM_OM) [0x9800000 0x2000000] Size: 32.0MB P18 (SPLASH2) [0xb800000 0x4000000] Size: 64.0MB P19 (MISC) [0xf800000 0x200000] Size: 2.0MB P20 (MODEMNVM_UPDATE) [0xfa00000 0x1800000] Size: 24.0MB P21 (RESERVED2) [0x11200000 0x2e00000] Size: 46.0MB P22 (PRELOAD) [0x14000000 0x800000] Size: 8.0MB P23 (TEEOS) [0x14800000 0x400000] Size: 4.0MB P24 (TRUSTFIRMWARE) [0x14c00000 0x200000] Size: 2.0MB P25 (SENSORHUB) [0x14e00000 0x1000000] Size: 16.0MB P26 (FW_HIFI) [0x15e00000 0xc00000] Size: 12.0MB P27 (ERECOVERY_KERNEL) [0x16a00000 0x1800000] Size: 24.0MB P28 (ERECOVERY_RAMDISK) [0x18200000 0x2000000] Size: 32.0MB P29 (ERECOVERY_VENDOR) [0x1a200000 0x1000000] Size: 16.0MB P30 (KERNEL) [0x1b200000 0x1800000] Size: 24.0MB P31 (ENG_SYSTEM) [0x1ca00000 0xc00000] Size: 12.0MB P32 (RECOVERY_RAMDISK) [0x1d600000 0x2000000] Size: 32.0MB P33 (RECOVERY_VENDOR) [0x1f600000 0x1000000] Size: 16.0MB P34 (DTS) [0x20600000 0x1c00000] Size: 28.0MB P35 (DTO) [0x22200000 0x400000] Size: 4.0MB P36 (MODEM_FW) [0x22600000 0x6000000] Size: 96.0MB P37 (RECOVERY_VBMETA) [0x28600000 0x100000] Size: 1.0MB P38 (ERECOVERY_VBMETA) [0x28700000 0x100000] Size: 1.0MB P39 (ENG_VENDOR) [0x28800000 0xc00000] Size: 12.0MB P40 (DFX) [0x29400000 0x1000000] Size: 16.0MB P41 (VBMETA) [0x2a400000 0x400000] Size: 4.0MB P42 (CACHE) [0x2a800000 0x8000000] Size: 128.0MB P43 (ODM) [0x32800000 0x8000000] Size: 128.0MB P44 (HISITEST0) [0x3a800000 0x200000] Size: 2.0MB P45 (HISITEST1) [0x3aa00000 0x200000] Size: 2.0MB P46 (HISITEST2) [0x3ac00000 0x400000] Size: 4.0MB P47 (PATCH) [0x3b000000 0x2000000] Size: 32.0MB P48 (BOOTFAIL_INFO) [0x3d000000 0x200000] Size: 2.0MB P49 (RRECORD) [0x3d200000 0x1000000] Size: 16.0MB P50 (RESERVED9) [0x3e200000 0xe00000] Size: 14.0MB P51 (SYSTEM) [0x3f000000 0xe9000000] Size: 3.640GB P52 (PREAS) [0x128000000 0x46800000] Size: 1.101GB P53 (PREAVS) [0x16e800000 0x2000000] Size: 32.0MB P54 (CUST) [0x170800000 0xc000000] Size: 192.0MB P55 (VERSION) [0x17c800000 0x2000000] Size: 32.0MB P56 (VENDOR) [0x17e800000 0x31000000] Size: 784.0MB P57 (PRODUCT) [0x1af800000 0x3a800000] Size: 936.0MB P58 (USERDATA) [0x1ea000000 0xca5800000] Size: 50.585GB P88 () [0x2000 0xfffffffffffe200] Size: 1048575.999TB P91 () [0x20000000000000 0x20040000000200] Size: 8196.0TB P93 (ࠀ耀) [0x800000 0] Size: 0.0B P94 () [0x2000000000000 0] Size: 0.0B P95 () [0x200000000000000 0] Size: 0.0B P96 () [0x100002000000 0x1073fffe000200] Size: 4211.999TB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.640GB) Short EXT fs info: Size: 3.583GB Block size: 4.0KB Inode size: 256 Inodes: 20880 Short Android info: Unable to read prop.plist , code : 6 --------------------------------------------- Detected abnormal USERDATA end offset: 0x0E8F800000, but total disk size is 0x0E8F800000 Done. |
The Following User Says Thank You to luckycool For This Useful Post: |
11-23-2021, 15:38 | #2 (permalink) | ||
Member: 143848 Status: Offline Thanks Meter: 125 | 1) To my understanding this is GPT Error. Am i Correct ? Quote:
11-23-2021, 15:40 | #3 (permalink) | ||
Member: 143848 Status: Offline Thanks Meter: 125 | Making Rom2 BACKUP 4mb gives error Quote:
11-23-2021, 15:42 | #4 (permalink) | |
Member: 143848 Status: Offline Thanks Meter: 125 | In Partition Tab Fix Table Gives Error Quote:
11-23-2021, 15:48 | #5 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | if you want to revived your Phone with the eMMC just apply this procedure, which method i have done P8 Lite, No need any Dump Just Watching Carefully the P8 Lite Video Tutorial hopefully you will be done. before Erase eMMC create SEC data backup. all the best. https://forum.gsmhosting.com/vbb/f67...-boot-2979952/ |
11-25-2021, 02:49 | #6 (permalink) | |
Member: 143848 Status: Offline Thanks Meter: 125 | Quote:
I have successfully made backup of ROM2 and ROM3. Its a Micron Chip. Am i wasting my time and I cant make backup this EMMC. | |
12-17-2021, 14:31 | #9 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
