any solution eMMC are unusable. HiPower mode is OFF CMD Pullup Level: 825 mV CMD Active Level: 2877 mV EMMC Device Information : EMMC CID: 1501004D4147344642F70F0459E7AFD2 EMMC CSD: D02701320F5903FFF6DBFFFF8E406008 EMMC Manufacture Name: SAMSUNG EMMC NAME: MAG4FB , S/N: 0F0459E7 , rev. F7 EMMC NAME (HEX): 4D4147344642 EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (01FFB6E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 384 KB (000000060000) EMMC RPMB (Replay Protected Memory Block) Capacity: 28416 KB (000001BC0000) EMMC Permanent Write Protection: Yes Backup saved: MAG4FB_0F0459E7_20161228_163127.extcsd EMMC Init completed. eMMC are unusable. :confused: |
You've misunderstood Your emmc is not unusable its only write protected that mean you can't write any file on it it You should do this in order : 1 . Go to advanced operations tab 2 . Select Remove Write Protection 3 . Click custom operation 4 . Again go to advanced operations 5 . Select emmc firmware update 6 . If popup window com up to enter you product number ( the full name on your emmc like : Kxxxxxxxxx-Bxxx) and click confirm 7. After update firmware is done and it show repairing eMMC CID you should take out the emmc if you use adaptors like moorc EMATE or disconnect all lines from emmc if you soldered wires and connect it again 8 . Detect eMMC Again and check the result in log 9 . Post the log of your job here BR : SASH ==>>Seyyed Aidin Shobeyri |
HiPower mode is OFF CMD Pullup Level: 2175 mV CMD Active Level: 2464 mV EMMC Device Information : EMMC CID: 65646F4D204D4F52128100000615444C EMMC CSD: D07FFF320F59007FF6DB80001E40001C EMMC Manufacture Name: EMMC NAME: M MOR , S/N: 00000615 , rev. 81 EMMC NAME (HEX): 4D204D4F5212 EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (01FFB6E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Backup saved: M MOR_00000615_20170710_124752.extcsd EMMC Init completed. Warning: Maybe your emmc damaged eMMC are unusable. HELP ME PLEASE THANK YOU... |
change |
Check DATO connection bro.. |
emmc are unusable - problem in z3x soft 100%! Only in EMMC KLM2G1HE3F-B001, other EMMC all OK Tested in EasyJTAG Plus 1.5.1.0, after 2 times connect emmc programm say "emmc are unusable", but after reconnect VCC EMMC all repeats. Hey support z3x - please pay attention to this. Also, the program spoils the data in the emmc KLM2G1HE3F-B001 when you try check emmc or detect emmc. |
First connect to emmc Quote:
Tested on several emmc |
Need Samsung KMQ310013B-B419 firmware Hello Team i need Need Samsung KMQ310013B-B419 firmware. in may hand j320f . i am try to formate emmc but alwayes emmc password lock and emmc helth is bad error i am try to flash emmc but emmc firmware not add jtag folder i am find to google but no luck plz if possible give me firmware. Samsung KMQ310013B-B419 |
not possible bga 221 |
i have same problem eMMC_tool Suite ver. 1.5.2.0 (release date: 06.08.2018) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2100 EasyJTAG Box Serial = 0900301095CE53A5 Card Serial = AAAA6B50 EasyJTAG Box Firmware = 1.63 Changelog: 06.08.2018 (ver 1.5.2.0) Fix: Bugs that have been found through your crash report Fix: Writing ROM2 for Samsung (Write by vendor) Fix: Freezing the program on a RandomVerify Add: Folder for saving to Explorer (in settings) Add: Extract from store.vol from emmc (explorer) Add: Automatic repair of damaged store.vol when extracting (Explorer) Add: Adding MountPoints for partitions (efs, userdata) when formatting Add: Checking for an empty EFS before backup (Read by Vendor Samsung) Setting frequence to 21 Mhz CMD Pullup Level: 711 mV CMD Active Level: 1557 mV EMMC Device Information : EMMC CID: 65646F4D204D4F521281000002400152 EMMC CSD: D07FFF320F59007FF6DB80001E40001C EMMC Manufacture : , EMMC NAME: MMOR , HEX: 4D004D4F5200 , S/N: 00000240 , rev. 0x81 EMMC Manufacture ID: 0x65 , OEM ID: 0x6F , Device Type: Device (removable) , Date: 0/2014 EMMC ROM 1 (Main User Data) Capacity: 128 MB (000008000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC BootArea Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x78 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: MMOR_00000240_20190312_163351.extcsd EMMC Init completed. eMMC are unusable. |
Is i m right Replay |
i have same problem any solution https://i.postimg.cc/HWbjpFSp/jjjjjjjjjjjjjjjj.png Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 1757 mV CMD Active Level: 1846 mV EMMC Device Information : EMMC CID: 65646F4D204D4F521281000002400153 EMMC CSD: D07FFF320F59007FF6DB80001E40001D EMMC Manufacture : , EMMC NAME: MMOR , HEX: 4D004D4F5200 , S/N: 00000240 , rev. 0x81 EMMC Manufacture ID: 0x65 , OEM ID: 0x6F , Device Type: Device (removable) , Date: 0/2014 EMMC ROM 1 (Main User Data) Capacity: 128 MB (000008000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x78 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: MMOR_00000240_20190510_213522.extcsd EMMC Init completed. eMMC are unusable. |
you eMMC is dead, and need to be replaced |
