Old 04-06-2021, 00:14   #1 (permalink)
Member: 2693967
Thanks Meter: 6
(ASK) Xiaomi Merlin Emmc 6/128
eMMC_tool ver. 2.0.0.0 (release date: 30.12.2020)
Microsoft Windows 10 (64 bit) build 19042 (10.0.19041.804)
Looking for EasyJTAG box...
EasyJTAG API ver. 3403
EasyJTAG Box Serial = 0DF1DACCFF222422
Card Serial = AA944AD4
EasyJTAG Box Firmware = 2,5301
Changelog:
30/12/2020 (ver 1.6.4.0)
Add: New keys for Oppo unpack
Fix: Fix LG Parser
Fix: Bugs that have been found through your crash report
Add: new version 2.0.0.0 (qualcomm, samsung)
Operation: Connect to Z3X EasyJtagPlus
Setting Interface to EasyJtag2/E-Socket
Setting IO Levels to 2.8V
Setting Frequence to 42 Mhz
Setting BusWidth to Auto
Setting HS Timing to Enabled
EMMC Device Information :
EMMC CID: 150100335636434D420286B69031573F
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
Manufacturer: SAMSUNG , NAME: 3V6CMB , HEX: 335636434D42 , S/N: 3190B686 , Rev: 02
Manufacturer ID: 15 , OEM ID: 00 , Device Type: BGA (Discrete embedded) , Date: 5/2020
EMMC ROM 1 (Main User Data) Capacity: 119276 MB (0x001D1EC00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (0x000000400000)
EMMC RPMB Capacity: 16384 KB (0x000001000000) , Counter: 2963 , Response: Not Clean
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot partition 1 enabled for boot , Boot ACK
Boot Bus Config: 0x02 , x8 (sdr/ddr) bus width in boot operation mode
H/W Reset Function [RST_N_FUNCTION]: 0x01 , RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition settings [PARTITION_SETTING_COMPLETED]: 0x00
EMMC Init completed
Backup saved: 3V6CMB_3190B686_20210406_070343.extcsd (new backup)
Connected successfully
Operation: Smart Report ...
Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used
Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used
Pre EOL information [267]: 0x01 Normal
Done
Operation: MoviNand Format + Reset ...
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB
Sending Internal Reconfiguration Request... Waiting configuration Apply!
Restoring configuration...
Wiping Card... Please do not touch it!
Successfully
Please don't forget to repair extCSD from backup
Operation: Repair Extcsd ...
Done
Operation: Remove WriteProtection ...
Error: This emmc does not have write protection
Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write)
Scanning soft partitions from ROM2
GPT header is not found
Scanning soft partitions from ROM3
Scanning soft partitions from ROM1
MBR header is not found
Done
Operation: Random Check ...
If your restore data error occurs - the original data can be found in a folder:
\Backups\RandomCheck\20210406_070812\
Error writing at address: 000000000000 , error: -101, CARD Ready Timeout Error ... Retry #1
Error writing at address: 000000000000 , error: -101, CARD Ready Timeout Error ... Retry #2
Error writing at address: 000000000000 , error: -101, CARD Ready Timeout Error ... Retry #3
Address: 000000000000, size: 000000004000 - FAIL
Write Speed - Max : 0,38 KB/s , Min : 0,38 KB/s , Avg : 0,38 KB/s , Slow blocks: 0 of 1 (0,00 %) , Verified: 16,00 KB
Read Speed - Max : 6515,19 KB/s , Min : 6515,19 KB/s , Avg : 6515,19 KB/s , Slow blocks: 0 of 1 (0,00 %) , Verified: 16,00 KB
Stopped by User request...
Sent from my SM-N950N using Tapatalk
Old 04-06-2021, 00:18   #2 (permalink)
Member: 2693967
Thanks Meter: 6
Changelog:
Fix: Fix LG Parser
EMMC Init completed
Done
Successfully
Done
Done
I have xiaomi redmi note 9 merlin, restart after update ota.
Flash using many tool and firmware still restart.
Try to remove and check emmc,
But i dont know to write emmc xiaomi MTK using easy jtag, pliss help sir
Oyah, board without emmc ( after i remove emmc ) can detect emmc usb port on PC.
Old 04-06-2021, 14:28   #3 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,013
bro this condition you not need remove emmc.. you try online flash auth tool
i am face same problem redmi note 9 merlin hang logo some time than restart customer says phone face problem after try root
i am flash phone market tool problem aseity so flash sp flash tool bypass secure boot loader or flashing complete phone working fine
see this thread_ REDMI NOTE 9 merlin restart bricked after root solved sp flash tool
Old 04-06-2021, 15:42   #4 (permalink)
Member: 2693967
Thanks Meter: 6
Thank you for reply bro,
Before i remove emmc.
I flash using ur methode too
And using paid tool to flash auth
But stil restart bro
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.16146 seconds with 7 queries
