Old 10-14-2021, 17:19   #1 (permalink)
Member: 1882912
Sonork: 100.1677703
Thanks Meter: 263
TA-1204 Restart problem solved with Easy-Jtag Plus
Logs :
---------- eMMC Device Information ----------
eMMC CID : 88010343434D3442384002B00500677D
eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D
eMMC Manufacturer ID: 0088 , OEM ID: 0103
eMMC Date: 06/2020  Rev.0x40
eMMC NAME: CCM4B8 , S/N:   45090048
eMMC NAME (HEX): 43434D344238
EMMC ROM1 (Main User Data)   Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 516 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: CCM4B8_  45090048_20211014_1600.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x03]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
------------------------- eMMC v5+ -------------------------
Supported modes [SUPPORTED_MODES: 0x03]
FFU features [FFU_FEATURES: 0x00]
Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00]
FFU Argument [FFU_ARG: 0x00000000]
Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0]
Vendor proprietary health report:
[VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x00]
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01]
 i.e. 0% - 10% device life time used
Pre EOL information [PRE_EOL_INFO: 0x01]
 i.e. Normal
Optimal read size [OPTIMAL_READ_SIZE: 0x00]
Optimal write size [OPTIMAL_WRITE_SIZE: 0x20]
Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01]
Device version [DEVICE_VERSION: 0x00 - 0x00]
Firmware version:
[FIRMWARE_VERSION[261]]: 0x00
[FIRMWARE_VERSION[260]]: 0x00
[FIRMWARE_VERSION[259]]: 0x00
[FIRMWARE_VERSION[258]]: 0x00
[FIRMWARE_VERSION[257]]: 0x00
[FIRMWARE_VERSION[256]]: 0x02
[FIRMWARE_VERSION[255]]: 0x02
[FIRMWARE_VERSION[254]]: 0x0a
Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00]
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
 [MIN_PERF_DDR_W_8_52: 0x00]
 [MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x05]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
 Device supports alternative boot method
 Device supports dual data rate during boot
 Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x06]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x05]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x16]
Sector Count [SEC_COUNT: 0x01ce8000]
Minimum Write Performance for 8bit:
 [MIN_PERF_W_8_52: 0x00]
 [MIN_PERF_R_8_52: 0x00]
 [MIN_PERF_W_8_26_4_52: 0x00]
 [MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
 [MIN_PERF_W_4_26: 0x00]
 [MIN_PERF_R_4_26: 0x00]
Power classes registers:
 [PWR_CL_26_360: 0x00]
 [PWR_CL_52_360: 0x00]
 [PWR_CL_26_195: 0x00]
 [PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x0a]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05]
I/O Driver Strength [DRIVER_STRENGTH: 0x1f]
Card Type [CARD_TYPE: 0x57]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x08]
 No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x15
Enable background operations handshake [BKOPS_EN]: 0x00
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000268
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
 [GP_SIZE_MULT_3]: 0x000000
 [GP_SIZE_MULT_2]: 0x000000
 [GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1CE8000 sectors 14.5 GiB
Soft (Partitioned) Disk/Image size: 1CE7FBC sectors 14.5 GiB
Disk identifier (GUID): 11111111-2222-3333-4444-000000000000
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,30310366
Partition info successfully found
------ Detected 38 partitions ------
P0 (PRODNV) [0x100000 0xa00000] Size: 10.0MB
P1 (MISCDATA) [0xb00000 0x100000] Size: 1.0MB
P2 (RECOVERY) [0xc00000 0x2300000] Size: 35.0MB
P3 (MISC) [0x2f00000 0x100000] Size: 1.0MB
P4 (MISCAUTH) [0x3000000 0x300000] Size: 3.0MB
P5 (TRUSTOS) [0x3300000 0x600000] Size: 6.0MB
P6 (TRUSTOS_BAK) [0x3900000 0x600000] Size: 6.0MB
P7 (SML) [0x3f00000 0x100000] Size: 1.0MB
P8 (SML_BAK) [0x4000000 0x100000] Size: 1.0MB
P9 (UBOOT) [0x4100000 0x100000] Size: 1.0MB
P10 (UBOOT_BAK) [0x4200000 0x100000] Size: 1.0MB
P11 (UBOOT_LOG) [0x4300000 0x400000] Size: 4.0MB
P12 (LOGO) [0x4700000 0x100000] Size: 1.0MB
P13 (FBOOTLOGO) [0x4800000 0x100000] Size: 1.0MB
P14 (L_FIXNV1) [0x4900000 0x100000] Size: 1.0MB
P15 (L_FIXNV2) [0x4a00000 0x100000] Size: 1.0MB
P16 (L_RUNTIMENV1) [0x4b00000 0x100000] Size: 1.0MB
P17 (L_RUNTIMENV2) [0x4c00000 0x100000] Size: 1.0MB
P18 (GPSGL) [0x4d00000 0x100000] Size: 1.0MB
P19 (GPSBD) [0x4e00000 0x100000] Size: 1.0MB
P20 (WCNMODEM) [0x4f00000 0xa00000] Size: 10.0MB
P21 (PERSIST) [0x5900000 0x200000] Size: 2.0MB
P22 (L_MODEM) [0x5b00000 0x1900000] Size: 25.0MB
P23 (L_DELTANV) [0x7400000 0x100000] Size: 1.0MB
P24 (L_GDSP) [0x7500000 0xa00000] Size: 10.0MB
P25 (L_LDSP) [0x7f00000 0x1400000] Size: 20.0MB
P26 (PM_SYS) [0x9300000 0x100000] Size: 1.0MB
P27 (BOOT) [0x9400000 0x2300000] Size: 35.0MB
P28 (DTB) [0xb700000 0x800000] Size: 8.0MB
P29 (DTBO) [0xbf00000 0x800000] Size: 8.0MB
P30 (SYSTEM) [0xc700000 0x76c00000] Size: 1.855GB
P31 (CACHE) [0x83300000 0x9600000] Size: 150.0MB
P32 (VENDOR) [0x8c900000 0x12c00000] Size: 300.0MB
P33 (PRODUCT) [0x9f500000 0x6400000] Size: 100.0MB
P34 (ELABLE) [0xa5900000 0x1400000] Size: 20.0MB
P35 (VBMETA) [0xa6d00000 0x100000] Size: 1.0MB
P36 (VBMETA_BAK) [0xa6e00000 0x100000] Size: 1.0MB
P37 (USERDATA) [0xa6f00000 0x2f60fbe00] Size: 11.843GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000C700000 (1.855GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 119760
Short Android info:
Build ID:  PPR1.180610.011
Display Build ID:  00WW_1_100
Release Incremental ID:  00WW_1_100
Release Base ID:  9
Security Path:  2020-10-05
Architecture ABI:  armeabi-v7a
Product ID:  NBL
Build Description:  k550-user 9 PPR1.180610.011 00WW_1_100 release-keys
FRP Partition Path:  /dev/block/platform/soc/soc:ap-ahb/20600000.sdio/by-name/persist
Device Model:  Nokia C2
Device Manufacturer:  Nokia
Device Name A:  Nebula_00WW
Device Name B:  NBL
Device manufacturer:  HMD Global
Backup saved: BuildProp_20211014_1600.txt
Detected USERDATA USERDATA : 0x00A6F00000 (11.843GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 776720
Short userdata info:
Unable to read gesture.key , code 2
Done.
Partition BOOT:
File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\boot.img successefuly loaded!
Checking security ...
Z3X EasyJtag Software ver. 3.7.0.24
Loading eMMC GEN2 Firmware... IO: 2400 mV
Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53
CMD Pullup Level:2174 mV
CMD Active Level:2270 mV
Box IO Level:2400 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Check GPT Table
Length limit is enabled!
Input file : C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\boot.img
Writing 0002300000 bytes to 0009400000... ROM1 (USER ROM)
Done, time taken: 26 sec. Average Write Speed: 1407 kB/s
Partition CACHE:
Autodetected SPARSE compressed data
File size is lower then partition size. Write size is correct to 0x8f0d000 bytes!
File C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\cache.img successefuly loaded!
CMD Pullup Level:2172 mV
CMD Active Level:2271 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
Check GPT Table
Write Android Sparse file Address: 0x83300000 ,Length: 0x8F0D000
Input file :C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\cache.img
Header major ver. 00000001
Header minor ver. 00000000
Header header sz. 0000001C
Header chunk hdr. 0000000C
Header block size. 00001000
Header total blk 00008F0D
Header total chunks 0000000A
Begin writing sparse...
Writing 0x8002000 packed bytes
Partition DTBO:
File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\dtbo.img successefuly loaded!
CMD Pullup Level:2171 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
Check GPT Table
Input file : C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\dtbo.img
Writing 0000800000 bytes to 000BF00000... ROM1 (USER ROM)
Done, time taken: 6 sec. Average Write Speed: 1369 kB/s
Partition PRODUCT:
File C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\product.img successefuly loaded!
CLK Rate:18000 kHz
Bus Width:1bit,SDR
Check GPT Table
Input file : C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\product.img
Writing 0006400000 bytes to 009F500000... ROM1 (USER ROM)
Done, time taken: 74 sec. Average Write Speed: 1413 kB/s
Partition RECOVERY:
File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\recovery.img successefuly loaded!
CLK Rate:18000 kHz
Bus Width:1bit,SDR
Check GPT Table
Input file : C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\recovery.img
Writing 0002300000 bytes to 0000C00000... ROM1 (USER ROM)
Done, time taken: 26 sec. Average Write Speed: 1408 kB/s
Partition SYSTEM:
File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\system.img successefuly loaded!
CMD Active Level:2269 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
Check GPT Table
Input file : C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\system.img
Writing 0076C00000 bytes to 000C700000... ROM1 (USER ROM)
Done, time taken: 1404 sec. Average Write Speed: 1418 kB/s
Partition VBMETA:
File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\vbmeta.img successefuly loaded!
CLK Rate:18000 kHz
Bus Width:1bit,SDR
Check GPT Table
Input file : C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\vbmeta.img
Writing 0000100000 bytes to 00A6D00000... ROM1 (USER ROM)
Done, time taken: 1 sec. Average Write Speed: 1048 kB/s
Partition VENDOR:
File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\vendor.img successefuly loaded!
CMD Pullup Level:2170 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
Check GPT Table
Input file : C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\vendor.img
Writing 0012C00000 bytes to 008C900000... ROM1 (USER ROM)
Done, time taken: 221 sec. Average Write Speed: 1417 kB/s
PINOUT:
https://forum.gsmhosting.com/vbb/f67...-done-2986145/
MDxavi.
The Following User Says Thank You to MDxavi For This Useful Post:
Page generated in 0.19975 seconds with 9 queries
