10-09-2022, 11:12 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Jamalpur, Bangladesh
Member: 623873 Status: Offline Thanks Meter: 41 | BGA221 Samsung All Emmc Damage !!! Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2130 mV CMD Active Level: 2259 mV EMMC Device Information : EMMC CID: 150100303030303030562012063058CF EMMC CSD: 902701320F5903FFF6DBFFEF8A404023 EMMC Manufacture : SAMSUNG , EMMC NAME: 000000 , HEX: 303030303030 , S/N: 20120630 , rev. 0x56 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2021 EMMC ROM 1 (Main User Data) Capacity: 8192 MB (000200000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 512 KB (000000080000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 EMMC Init completed. Warning: Maybe your emmc damaged Try Isp Pinout Try Socket Try Emmc Isp Pinout Any Solution ? |
10-12-2022, 10:36 | #3 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Quote:
10-12-2022, 12:46 | #5 (permalink) |
Member: 623873 Status: Offline Thanks Meter: 41 | Z3X EasyJtag Software ver. 3.8.0.1 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 917mV pin connected ok command: 996mV pin connected ok data0: 858mV pin connected ok data1: 853mV pin connected ok data2: 855mV pin connected ok data3: 855mV pin connected ok data4: 855mV pin connected ok data5: 854mV pin connected ok data6: 854mV pin connected ok data7: 854mV pin connected ok Box S/N: 221E42AEC69201B1, ,FW Ver.: 02.53 Box IO Level:1800 mV CLK Rate:14000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100303030303030562014031443C7 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 04/2016 Rev.0x56 eMMC NAME: 000000 , S/N: 538182420 eMMC NAME (HEX): 303030303030 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 000000_ 538182420_20221012_1745.extcsd Blocks Reading Error (0x0 , 1 , Reason: DATA RCV Timeout Error ) Blocks Reading Error (0x200 , 1 , Reason: DATA RCV Timeout Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: DATA RCV Timeout Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. |
