02-17-2021, 18:32 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | Bug or my fault? MMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 10 (64 bit) build 18363 (10.0.18362.1316) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = C006003434A0XX Card Serial = AAA36FXX EasyJTAG Box Firmware = 1.6300 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 3238 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 0600003136FFFFFFFFFF195C493934EA EMMC CSD: 8C4F012A0F598000F6D801E08A400076 EMMC Manufacture : , EMMC NAME: 16 , HEX: 313600000000 , S/N: 195C4939 , rev. 0xFF EMMC Manufacture ID: 0x06 , OEM ID: 0x00 , Device Type: Device (removable) , Date: 3/2001 EMMC ROM 1 (Main User Data) Capacity: 31596 MB (0007B6C80000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x00 Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 16_195C4939_20210217_095000.extcsd EMMC Init completed. Scanning soft partitions Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #1 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #2 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #3 Stopped by User request... partitions were not possible to be read and also RPMB and ROM2/3 are wrong. When I used a different device for reading eMMC, it showed like this Boot version: 1.04, FW version: 1.13 (Aug 19 2019 23:46:09) Insertion test... Done Init bus... VCC: 3.3 V, VCCQ: 3.0 V Bus: 8 bit (HS SDR 52MHz) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x13 (Micron) Product name: S0J97Y (0x53304a393759), rev: 0x10, serial number: 0x043A6768 Manufacturing date: Jun 2018 CID: 13014E53 304A3937 5910043A 6768650E CSD: D05F0132 8F5903FF FFFFFFEF 864000CC EXT_CSD revision: 1.8 (MMC v5.1) Partition info: Boot1: 4 MiB Boot2: 4 MiB RPMB: 4 MiB [Provisioned, counter: 98999] User area: 29.12 GiB(31,268,536,320 bytes) Cache size: 1 MiB Hardware reset function: 1 Partition configuration: 0x00 No boot acknowledge is sent (default) Device is not boot-enabled (default) Partitioning support: 0x07 Device support partitioning feature Device can have enhanced technological features Device partitioning possible Boot configuration protection: 0x00 Boot bus conditions: 0x00 Boot area write protection: 0x00 crypto state: encrypted? ANDROID System Info: platform: sdm660, cpu abi: arm64-v8a manufacturer: Sony board: sdm660, name: pioneer_dsds brand: Sony, model: H4113 build model list: H4113 build id: 50.2.A.3.55, version: 9 [Pie] (50.2.A.3.55) build description: pioneer_dsds-user 9 P-NILE-CAF-200407-1702 1 dev-keys crypto state: encrypted? seem to be correct. Where can be a problem? |
03-06-2021, 09:29 | #3 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for the reply. As far as I remember It happened only 2 times( different eMMC) - otherwise Z3X Jtag works great - so it should not be the socket problem. I used the same eMMC with UFI box and it worked properlly. So I guess( not sure of course) it might be Z3X Jtag bug. |
