SM-C7000 Dead! Hello everyone, i received two dead Samsung Galaxy C7 which both are in one condition. No reaction to anything and when i connect them with usb cable to computer it found NO driver and NO connection. I checked the emmc's condition and both are dead so i've to change eMMC but i need dump file to programm new ones... Therefore do anyone have any working phone to make a dump file (ROM 1) please? Or already have a working dump file? Thanks in advance |
You don't need any dump just in easy plus in write tab select Samsung and put pit file with BL part from software and write it. Sent from my iPhone using Tapatalk |
Problem Not Solved :( |
Please tell me eMMC can detect or not?Can read or not? Also Did you use latest BL ?+pit? |
Hi Do you have readed dump before any touch? |
one of my connections find a working one and he is going to make a working dump file 1 Gb or 512 Mb. i will try writing this dump on my devices as soon as possible... for making sure this device is set on no boot and configuration is Boot 1: 4 Mb Boot 2: 4 Mb RPMB: 4 Mb Yes? this is what i understood by reading info of dead device's eMMC... |
i need pinout for this model. |
u check medusa box......... |
I need solution for dead boot sm c7000 |
C7000 dead repair. ( maybe this one is frist) Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.60 CMD Pullup Level:1794 mV CMD Active Level:2402 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 150100525831344D4200A25AD4B173B2 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2016 Rev.0x0 EMMC NAME: RX14MB , S/N: 2723861681 EMMC NAME (HEX): 525831344D4200 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RX14MB_2723861681_20170730_1603.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Found Data areas (firmware parts) count is: 40 Partition info successfully found --------------------------------------------- P0 (SBL1) [0x400000 0x80000] Size: 512.0KB P1 (SBL1BAK) [0x480000 0x80000] Size: 512.0KB P2 (DDR) [0x500000 0x80000] Size: 512.0KB P3 (RPM) [0x580000 0x80000] Size: 512.0KB P4 (TZ) [0x600000 0x200000] Size: 2.0MB P5 (ABOOT) [0x800000 0x200000] Size: 2.0MB P6 (SEC) [0xa00000 0x40000] Size: 256.0KB P7 (LKSECAPP) [0xa40000 0x80000] Size: 512.0KB P8 (KEYMASTER) [0xac0000 0x40000] Size: 256.0KB P9 (CMNLIB) [0xb00000 0x40000] Size: 256.0KB P10 (CMNLIB64) [0xb40000 0x40000] Size: 256.0KB P11 (FSG) [0xb80000 0x400000] Size: 4.0MB P12 (PAD) [0xf80000 0x80000] Size: 512.0KB P13 (MODEMST1) [0x1000000 0x400000] Size: 4.0MB P14 (MODEMST2) [0x1400000 0x400000] Size: 4.0MB P15 (EFS) [0x1c00000 0x1000000] Size: 16.0MB P16 (FSC) [0x2c00000 0x340000] Size: 3.250MB P17 (SSD) [0x2f40000 0x40000] Size: 256.0KB P18 (DEVCFG) [0x2f80000 0x40000] Size: 256.0KB P19 (APDP) [0x2fc0000 0x20000] Size: 128.0KB P20 (MSADP) [0x2fe0000 0x20000] Size: 128.0KB P21 (PARAM) [0x3000000 0xc00000] Size: 12.0MB P22 (BACKUP) [0x3c00000 0x400000] Size: 4.0MB P23 (BOOT) [0x4000000 0x2000000] Size: 32.0MB P24 (RECOVERY) [0x6000000 0x2000000] Size: 32.0MB P25 (BOTA) [0x8000000 0x800000] Size: 8.0MB P26 (FOTA) [0x8800000 0x400000] Size: 4.0MB P27 (PERSIST) [0x8c00000 0x2000000] Size: 32.0MB P28 (PERSISTENT) [0xac00000 0x100000] Size: 1.0MB P29 (STEADY) [0xad00000 0x100000] Size: 1.0MB P30 (KEYSTORE) [0xae00000 0x100000] Size: 1.0MB P31 (CONFIG) [0xaf00000 0x100000] Size: 1.0MB P32 (DSP) [0xb000000 0x1000000] Size: 16.0MB P33 (MODEM) [0xc000000 0x6000000] Size: 96.0MB P34 (APNHLOS) [0x12000000 0x2000000] Size: 32.0MB P35 (PERSDATA) [0x14000000 0xc00000] Size: 12.0MB P36 (RESERVED2) [0x14c00000 0x400000] Size: 4.0MB P37 (SYSTEM) [0x15000000 0xe1000000] Size: 3.515GB P38 (CACHE) [0xf6000000 0xc800000] Size: 200.0MB P39 (USERDATA) [0x102800000 0x6453fb000] Size: 25.81GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0015000000 (3.515GB) Build ID: MMB29M Display Build ID: MMB29M.C7000ZHU2APK5 Release ID: 6.0.1 Device Model: SM-C7000 Device Name: c7ltezh Architecture ABI: arm64-v8a Device manufacturer: samsung Device Platform: msm8953 Product ID: c7ltechn Build Description: c7ltezh-user 6.0.1 MMB29M C7000ZHU2APK5 release-keys Samsung CPU: MSM8953 --------------------------------------------- Done. https://image.ibb.co/dksRS5/e469c01e...17bce95ed5.jpg http://i66.tinypic.com/op7ev9.jpg https://image.ibb.co/cLdY75/C7000_FLASHING.jpg |
Pinouts Pls bro. Br Shah. |
You Are Doing Information LOG Where Boot Repair Log So Please Upload Boot Repair LOG |
bro now a day boot repair log ds'nt mean anything. coz i dnt reset format nand of this devices. now a day emmc pinout and emmc detection is main part of jitag. if wnna play with easy jitag then u can find the why and u will understand what i try to explain you. did u ever see c7000 repair or emmc detection log yes until i post? |
not first HiPower mode is OFF CMD Pullup Level: 3176 mV CMD Active Level: 3248 mV EMMC Device Information : EMMC CID: 150100525831344D42001112D0A883DA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG EMMC NAME: RX14MB , S/N: 1112D0A8 , rev. 00 EMMC NAME (HEX): 525831344D42 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: RX14MB_1112D0A8_20170604_225409.extcsd EMMC Init completed. GPT header is found and is valid Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 Partition: ddr, [000000500000 - 000000580000], size: 000000080000 Partition: rpm, [000000580000 - 000000600000], size: 000000080000 Partition: tz, [000000600000 - 000000800000], size: 000000200000 Partition: aboot, [000000800000 - 000000A00000], size: 000000200000 Partition: sec, [000000A00000 - 000000A40000], size: 000000040000 Partition: lksecapp, [000000A40000 - 000000AC0000], size: 000000080000 Partition: keymaster, [000000AC0000 - 000000B00000], size: 000000040000 Partition: cmnlib, [000000B00000 - 000000B40000], size: 000000040000 Partition: cmnlib64, [000000B40000 - 000000B80000], size: 000000040000 Partition: fsg, [000000B80000 - 000000F80000], size: 000000400000 Partition: pad, [000000F80000 - 000001000000], size: 000000080000 Partition: modemst1, [000001000000 - 000001400000], size: 000000400000 Partition: modemst2, [000001400000 - 000001800000], size: 000000400000 Partition: efs, [000001C00000 - 000002C00000], size: 000001000000 Partition: fsc, [000002C00000 - 000002F40000], size: 000000340000 Partition: ssd, [000002F40000 - 000002F80000], size: 000000040000 Partition: devcfg, [000002F80000 - 000002FC0000], size: 000000040000 Partition: apdp, [000002FC0000 - 000002FE0000], size: 000000020000 Partition: msadp, [000002FE0000 - 000003000000], size: 000000020000 Partition: param, [000003000000 - 000003C00000], size: 000000C00000 Partition: backup, [000003C00000 - 000004000000], size: 000000400000 Partition: boot, [000004000000 - 000006000000], size: 000002000000 Partition: recovery, [000006000000 - 000008000000], size: 000002000000 Partition: bota, [000008000000 - 000008800000], size: 000000800000 Partition: fota, [000008800000 - 000008C00000], size: 000000400000 Partition: persist, [000008C00000 - 00000AC00000], size: 000002000000 Partition: persistent, [00000AC00000 - 00000AD00000], size: 000000100000 Partition: steady, [00000AD00000 - 00000AE00000], size: 000000100000 Partition: keystore, [00000AE00000 - 00000AF00000], size: 000000100000 Partition: config, [00000AF00000 - 00000B000000], size: 000000100000 Partition: dsp, [00000B000000 - 00000C000000], size: 000001000000 Partition: modem, [00000C000000 - 000012000000], size: 000006000000 Partition: apnhlos, [000012000000 - 000014000000], size: 000002000000 Partition: persdata, [000014000000 - 000014C00000], size: 000000C00000 Partition: reserved2, [000014C00000 - 000015000000], size: 000000400000 Partition: system, [000015000000 - 0000F6000000], size: 0000E1000000 Partition: cache, [0000F6000000 - 000102800000], size: 00000C800000 Partition: userdata, [000102800000 - 000747C00000], size: 000645400000 GPT header successfully parsed Brand = samsung Model = SM-C7000 Phone platform = msm8953 Android release = 6.0.1 Firmware version = MMB29M.C7000ZHS2AQC2 Firmware date = Sat Mar 25 09:44:48 KST 2017 |
