Old 08-08-2018, 12:52   #1 (permalink)
Member: 302596
Thanks Meter: 784
Samsung SM-G530h/ds GPT: damaged
anyone has solution for this problem ?
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
 [MIN_PERF_DDR_W_8_52: 0x00]
 [MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
 Device supports alternative boot method
 Device supports dual data rate during boot
 Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x04]
Access size [ACC_SIZE: 0x07]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x00e90000]
Minimum Write Performance for 8bit:
 [MIN_PERF_W_8_52: 0x00]
 [MIN_PERF_R_8_52: 0x00]
 [MIN_PERF_W_8_26_4_52: 0x00]
 [MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
 [MIN_PERF_W_4_26: 0x00]
 [MIN_PERF_R_4_26: 0x00]
Power classes registers:
 [PWR_CL_26_360: 0x00]
 [PWR_CL_52_360: 0x00]
 [PWR_CL_26_195: 0x00]
 [PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05]
I/O Driver Strength [DRIVER_STRENGTH: 0x3f]
Card Type [CARD_TYPE: 0x57]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x00]
 Not boot enabled
 No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x50
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x01
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x04
Enable background operations handshake [BKOPS_EN]: 0x00
H/W reset function [RST_N_FUNCTION]: 0x00
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0001d2
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
 [GP_SIZE_MULT_3]: 0x000000
 [GP_SIZE_MULT_2]: 0x000000
 [GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
 GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB
Logical sector size: 0x200  bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 15269854
Found Data areas (firmware parts) count is: 27
Partition info successfully found
P0 (APNHLOS) [0x400000 0xf00000] Size: 15.0MB
P1 (MODEM) [0x1300000 0x3970000] Size: 57.437MB
P2 (SBL1) [0x4c70000 0x80000] Size: 512.0KB
P3 (DDR) [0x4cf0000 0x8000] Size: 32.0KB
P4 (ABOOT) [0x4cf8000 0x200000] Size: 2.0MB
P5 (RPM) [0x4ef8000 0x80000] Size: 512.0KB
P6 (QSEE) [0x4f78000 0x80000] Size: 512.0KB
P7 (QHEE) [0x4ff8000 0x80000] Size: 512.0KB
P8 (FSG) [0x5078000 0x300000] Size: 3.0MB
P9 (SEC) [0x5378000 0x4000] Size: 16.0KB
P10 (PAD) [0x537c000 0xa84000] Size: 10.515MB
P11 (PARAM) [0x5e00000 0xa00000] Size: 10.0MB
P12 (EFS) [0x6800000 0xe00000] Size: 14.0MB
P13 (MODEMST1) [0x7600000 0x300000] Size: 3.0MB
P14 (MODEMST2) [0x7900000 0x300000] Size: 3.0MB
P15 (BOOT) [0x7c00000 0xd00000] Size: 13.0MB
P16 (RECOVERY) [0x8900000 0xf00000] Size: 15.0MB
P17 (FOTA) [0x9800000 0x500400] Size: 5.0MB
P18 (BACKUP) [0x9d00400 0x6fdc00] Size: 6.991MB
P19 (FSC) [0xa3fe000 0x300000] Size: 3.0MB
P20 (SSD) [0xa6fe000 0x2000] Size: 8.0KB
P21 (PERSIST) [0xa700000 0x800000] Size: 8.0MB
P22 (PERSDATA) [0xaf00000 0x900000] Size: 9.0MB
P23 (SYSTEM) [0xb800000 0x5d800000] Size: 1.460GB
P24 (CACHE) [0x69000000 0x12c00000] Size: 300.0MB
P25 (HIDDEN) [0x7bc00000 0xa00000] Size: 10.0MB
P26 (USERDATA) [0x7c600000 0x1559fb000] Size: 5.336GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000B800000 (1.460GB)
Unable to mount SYSTEM , code : 95
Done.
The Following User Says Thank You to maxieboy For This Useful Post:
Old 08-08-2018, 21:56   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
 GPT: damaged
Is a not seriously problem. Phone will work with it
Try to "Repair Tables" button at "Regions" page
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 08-09-2018, 07:46   #3 (permalink)
Member: 1623940
Thanks Meter: 22
Gpt problem
 Not boot enabled
 GPT: damaged
Done.
Give ur Tv bro...........
Old 08-09-2018, 09:22   #4 (permalink)
Member: 302596
Thanks Meter: 784
i just pm you bro please check your inbox
Old 08-09-2018, 09:23   #5 (permalink)
Member: 302596
Thanks Meter: 784
ive done repairing before i posted here but still the same phone has dead
Old 08-10-2018, 04:53   #6 (permalink)
Member: 1623940
Thanks Meter: 22
Not yet received
No pm received bro , check once
Page generated in 0.18986 seconds with 8 queries
