07-08-2021, 23:32 | #1 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2630445 Status: Offline Thanks Meter: 1 | Can't Create Output File Error Code: Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Skip loading eMMC Addon Firmware CMD Pullup Level:1817 mV CMD Active Level:1833 mV Box IO Level:1800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR Reading 0x000800000000 (32.0GB) from 0x000000000000 ...ROM1 ( USER ROM) Read Length has been corrected to 0x000747C00000 (29.121GB)... Can't create output file F:\ClientData\removed\EMMC_ROM1_QX13MB_921479196_00000000_747C00000.bin Done. Thanks |
07-10-2021, 10:02 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | check for you filesystem is NTFS ckeck admin rights for SW Last edited by layder; 07-10-2021 at 11:04. |
The Following User Says Thank You to layder For This Useful Post: |
03-31-2023, 15:49 | #6 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: India
Member: 1095362 Status: Offline Thanks Meter: 70 | Quote:
The Following User Says Thank You to khanraheem143 For This Useful Post: |
