07-14-2021, 07:24 | #3 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 1616120653F9FBE6, ,FW Ver.: 01.63 CMD Pullup Level:360 mV CMD Active Level:1980 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. i have the same problem. all phones i connect with easyjtag box i get same error i also change adapter but still same error i used other tool it connect fine.could it be box problem? if yes how to fix? |
07-15-2021, 15:52 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | z3x old box is produced at 2014 -2017 this box was disigned for JTAG, not eMMC eMMC function is been added later and need external third-party power adapter I can't know that adapter you use and that type of connection you use anybody can't help you without detail describe you situation Last edited by layder; 07-15-2021 at 16:04. |
07-16-2021, 08:45 | #5 (permalink) |
Member: 83397 Status: Offline Thanks Meter: 204 | same adapters i used before and used to work perfectly fine for emmc i even bought new emmc adapter but same error.maybe box is the problem or new software updates not compatible with old box |
07-19-2021, 16:27 | #6 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
software work with box firmware and box firmware for old box 1.63 is not changed from 2017 (+_) | |
