07-12-2021, 09:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | NOKIA 2 TA-1007 || 1SIM || LOGO HANG || eMMC WARNING HEALTH REPORT IS VERY BAD || FIX How Do the Do it. Code: When it was tried to flash with InfinityBox BEST2 but Fail. When I Connect with Easy JTAG Warning: Health report is very BAD. Then do a Google search to create a secure data backup with expert guidance. When I repartition eMMC / Fix Warning: Health report is very BAD Problem. When it has flash the firmware Nokia TA-1007 When it' has restore All Secure data by Partition with xml config file. When create Dump file From a live Phone. Video Tutorial. Before Repair Log:- Code: eMMC_tool Suite ver. 1.6.4.0 (release date: 30.12.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = F6F272D292237F2E Card Serial = AA2778BA EasyJTAG Box Firmware = 2.5301 Changelog: 30.12.2020 (ver 1.6.4.0) Add: New keys for Oppo unpack Fix: Fix LG Parser Fix: Bugs that have been found through your crash report Add: new version 2.0.0.0 (qualcomm, samsung) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1826 mV CMD Active Level: 1864 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2163 mV CMD Active Level: 2312 mV Can't init device. Reason: CARD Ready Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 2147 mV CMD Active Level: 2297 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4a2_C6984D33_20210709_190934.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000004400 - 000000084400], size: 000000080000 (512. KB) Partition: sbl1bak, [000000084400 - 000000104400], size: 000000080000 (512. KB) Partition: aboot, [000000104400 - 000000204400], size: 000000100000 (1.00 MB) Partition: abootbak, [000000204400 - 000000304400], size: 000000100000 (1.00 MB) Partition: rpm, [000000304400 - 000000384400], size: 000000080000 (512. KB) Partition: rpmbak, [000000384400 - 000000404400], size: 000000080000 (512. KB) Partition: tz, [000000404400 - 0000004C4400], size: 0000000C0000 (768. KB) Partition: tzbak, [0000004C4400 - 000000584400], size: 0000000C0000 (768. KB) Partition: DDR, [000000584400 - 00000058C400], size: 000000008000 (32.0 KB) Partition: pad, [00000058C400 - 00000068C400], size: 000000100000 (1.00 MB) Partition: ssd, [00000068C400 - 00000068E400], size: 000000002000 (8.00 KB) Partition: sutinfo, [00000068E400 - 00000068E800], size: 000000000400 (1.00 KB) Partition: systeminfo, [00000068E800 - 0000006CE800], size: 000000040000 (256. KB) Partition: splash, [0000006CE800 - 0000009CE800], size: 000000300000 (3.00 MB) Partition: reserved, [0000009CE800 - 000000A00000], size: 000000031800 (198. KB) Partition: fsg, [000000A00000 - 000000B80000], size: 000000180000 (1.50 MB) Partition: modemst1, [000000C00000 - 000000D80000], size: 000000180000 (1.50 MB) Partition: modemst2, [000000E00000 - 000000F80000], size: 000000180000 (1.50 MB) Partition: fsc, [000001000000 - 000001000800], size: 000000000800 (2.00 KB) Partition: rf_nv, [000001000800 - 000001200800], size: 000000200000 (2.00 MB) Partition: deviceinfo, [000001200800 - 000001300800], size: 000000100000 (1.00 MB) Partition: securefs, [000001300800 - 000001500800], size: 000000200000 (2.00 MB) Partition: cust_nv, [000001500800 - 000001700800], size: 000000200000 (2.00 MB) Partition: ftmlog, [000001700800 - 000003700800], size: 000002000000 (32.0 MB) Partition: box, [000003700800 - 000003F00800], size: 000000800000 (8.00 MB) Partition: ftm, [000003F00800 - 000005F00800], size: 000002000000 (32.0 MB) Partition: hidden, [000005F00800 - 000007900800], size: 000001A00000 (26.0 MB) Partition: cda, [000007900800 - 000008100800], size: 000000800000 (8.00 MB) Partition: logdump, [000008100800 - 000008B00800], size: 000000A00000 (10.0 MB) Partition: elabel, [000008B00800 - 000008F00800], size: 000000400000 (4.00 MB) Partition: reserved_bak, [000008F00800 - 000009100800], size: 000000200000 (2.00 MB) Partition: recovery, [000009100800 - 00000B100800], size: 000002000000 (32.0 MB) Partition: sec, [00000B100800 - 00000B104800], size: 000000004000 (16.0 KB) Partition: boot, [00000B104800 - 00000D104800], size: 000002000000 (32.0 MB) Partition: modem, [00000D104800 - 000011104800], size: 000004000000 (64.0 MB) Partition: system, [000011104800 - 0000C4504800], size: 0000B3400000 (2.80 GB) Partition: misc, [0000C4504800 - 0000C4604800], size: 000000100000 (1.00 MB) Partition: cache, [0000C4604800 - 0000CAA04800], size: 000006400000 (100. MB) Partition: persist, [0000CAA04800 - 0000CCA04800], size: 000002000000 (32.0 MB) Partition: devinfo, [0000CD000000 - 0000CD100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000CD800000 - 0000CD880000], size: 000000080000 (512. KB) Partition: config, [0000CD880000 - 0000CD900000], size: 000000080000 (512. KB) Partition: cmnlib, [0000CE000000 - 0000CE040000], size: 000000040000 (256. KB) Partition: cmnlibbak, [0000CE040000 - 0000CE080000], size: 000000040000 (256. KB) Partition: keymaster, [0000CE080000 - 0000CE0C0000], size: 000000040000 (256. KB) Partition: keymasterbak, [0000CE0C0000 - 0000CE100000], size: 000000040000 (256. KB) Partition: userdata, [0000CE800000 - 0001D1FFBE00], size: 0001037FBE00 (4.05 GB) GPT header successfully parsed Get firmware version Brand = Unknown Manufacturer = FIH Device = Unknown Model = Unknown Phone platform = msm8909 CPU Abi = armeabi-v7a Android release = 7.1.1 Security Patch = 2018-01-01 Firmware version = 00WW_0_64A Firmware date = Sun Jan 7 18:45:49 CST 2018 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2155 mV CMD Active Level: 2303 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4a2_C6984D33_20210709_191344.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000004400 - 000000084400], size: 000000080000 (512. KB) Partition: sbl1bak, [000000084400 - 000000104400], size: 000000080000 (512. KB) Partition: aboot, [000000104400 - 000000204400], size: 000000100000 (1.00 MB) Partition: abootbak, [000000204400 - 000000304400], size: 000000100000 (1.00 MB) Partition: rpm, [000000304400 - 000000384400], size: 000000080000 (512. KB) Partition: rpmbak, [000000384400 - 000000404400], size: 000000080000 (512. KB) Partition: tz, [000000404400 - 0000004C4400], size: 0000000C0000 (768. KB) Partition: tzbak, [0000004C4400 - 000000584400], size: 0000000C0000 (768. KB) Partition: DDR, [000000584400 - 00000058C400], size: 000000008000 (32.0 KB) Partition: pad, [00000058C400 - 00000068C400], size: 000000100000 (1.00 MB) Partition: ssd, [00000068C400 - 00000068E400], size: 000000002000 (8.00 KB) Partition: sutinfo, [00000068E400 - 00000068E800], size: 000000000400 (1.00 KB) Partition: systeminfo, [00000068E800 - 0000006CE800], size: 000000040000 (256. KB) Partition: splash, [0000006CE800 - 0000009CE800], size: 000000300000 (3.00 MB) Partition: reserved, [0000009CE800 - 000000A00000], size: 000000031800 (198. KB) Partition: fsg, [000000A00000 - 000000B80000], size: 000000180000 (1.50 MB) Partition: modemst1, [000000C00000 - 000000D80000], size: 000000180000 (1.50 MB) Partition: modemst2, [000000E00000 - 000000F80000], size: 000000180000 (1.50 MB) Partition: fsc, [000001000000 - 000001000800], size: 000000000800 (2.00 KB) Partition: rf_nv, [000001000800 - 000001200800], size: 000000200000 (2.00 MB) Partition: deviceinfo, [000001200800 - 000001300800], size: 000000100000 (1.00 MB) Partition: securefs, [000001300800 - 000001500800], size: 000000200000 (2.00 MB) Partition: cust_nv, [000001500800 - 000001700800], size: 000000200000 (2.00 MB) Partition: ftmlog, [000001700800 - 000003700800], size: 000002000000 (32.0 MB) Partition: box, [000003700800 - 000003F00800], size: 000000800000 (8.00 MB) Partition: ftm, [000003F00800 - 000005F00800], size: 000002000000 (32.0 MB) Partition: hidden, [000005F00800 - 000007900800], size: 000001A00000 (26.0 MB) Partition: cda, [000007900800 - 000008100800], size: 000000800000 (8.00 MB) Partition: logdump, [000008100800 - 000008B00800], size: 000000A00000 (10.0 MB) Partition: elabel, [000008B00800 - 000008F00800], size: 000000400000 (4.00 MB) Partition: reserved_bak, [000008F00800 - 000009100800], size: 000000200000 (2.00 MB) Partition: recovery, [000009100800 - 00000B100800], size: 000002000000 (32.0 MB) Partition: sec, [00000B100800 - 00000B104800], size: 000000004000 (16.0 KB) Partition: boot, [00000B104800 - 00000D104800], size: 000002000000 (32.0 MB) Partition: modem, [00000D104800 - 000011104800], size: 000004000000 (64.0 MB) Partition: system, [000011104800 - 0000C4504800], size: 0000B3400000 (2.80 GB) Partition: misc, [0000C4504800 - 0000C4604800], size: 000000100000 (1.00 MB) Partition: cache, [0000C4604800 - 0000CAA04800], size: 000006400000 (100. MB) Partition: persist, [0000CAA04800 - 0000CCA04800], size: 000002000000 (32.0 MB) Partition: devinfo, [0000CD000000 - 0000CD100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000CD800000 - 0000CD880000], size: 000000080000 (512. KB) Partition: config, [0000CD880000 - 0000CD900000], size: 000000080000 (512. KB) Partition: cmnlib, [0000CE000000 - 0000CE040000], size: 000000040000 (256. KB) Partition: cmnlibbak, [0000CE040000 - 0000CE080000], size: 000000040000 (256. KB) Partition: keymaster, [0000CE080000 - 0000CE0C0000], size: 000000040000 (256. KB) Partition: keymasterbak, [0000CE0C0000 - 0000CE100000], size: 000000040000 (256. KB) Partition: userdata, [0000CE800000 - 0001D1FFBE00], size: 0001037FBE00 (4.05 GB) GPT header successfully parsed Get firmware version Brand = Unknown Manufacturer = FIH Device = Unknown Model = Unknown Phone platform = msm8909 CPU Abi = armeabi-v7a Android release = 7.1.1 Security Patch = 2018-01-01 Firmware version = 00WW_0_64A Firmware date = Sun Jan 7 18:45:49 CST 2018 After Repair Log Code: eMMC_tool Suite ver. 1.6.4.0 (release date: 30.12.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = F6F272D292237F2E Card Serial = AA2778BA EasyJTAG Box Firmware = 2.5301 Changelog: 30.12.2020 (ver 1.6.4.0) Add: New keys for Oppo unpack Fix: Fix LG Parser Fix: Bugs that have been found through your crash report Add: new version 2.0.0.0 (qualcomm, samsung) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2176 mV CMD Active Level: 2324 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_222537.extcsd EMMC Init completed. Scanning soft partitions Error reading at address: 000000000000 , error: -2, CMD CRC Error ... Retry #1 Error reading at address: 000000000000 , error: -2, CMD CRC Error ... Retry #2 GPT header is found and is valid Partition: sbl1, [000000004400 - 000000084400], size: 000000080000 (512. KB) Partition: sbl1bak, [000000084400 - 000000104400], size: 000000080000 (512. KB) Partition: aboot, [000000104400 - 000000204400], size: 000000100000 (1.00 MB) Partition: abootbak, [000000204400 - 000000304400], size: 000000100000 (1.00 MB) Partition: rpm, [000000304400 - 000000384400], size: 000000080000 (512. KB) Partition: rpmbak, [000000384400 - 000000404400], size: 000000080000 (512. KB) Partition: tz, [000000404400 - 0000004C4400], size: 0000000C0000 (768. KB) Partition: tzbak, [0000004C4400 - 000000584400], size: 0000000C0000 (768. KB) Partition: DDR, [000000584400 - 00000058C400], size: 000000008000 (32.0 KB) Partition: pad, [00000058C400 - 00000068C400], size: 000000100000 (1.00 MB) Partition: ssd, [00000068C400 - 00000068E400], size: 000000002000 (8.00 KB) Partition: sutinfo, [00000068E400 - 00000068E800], size: 000000000400 (1.00 KB) Partition: systeminfo, [00000068E800 - 0000006CE800], size: 000000040000 (256. KB) Partition: splash, [0000006CE800 - 0000009CE800], size: 000000300000 (3.00 MB) Partition: reserved, [0000009CE800 - 000000A00000], size: 000000031800 (198. KB) Partition: fsg, [000000A00000 - 000000B80000], size: 000000180000 (1.50 MB) Partition: modemst1, [000000C00000 - 000000D80000], size: 000000180000 (1.50 MB) Partition: modemst2, [000000E00000 - 000000F80000], size: 000000180000 (1.50 MB) Partition: fsc, [000001000000 - 000001000800], size: 000000000800 (2.00 KB) Partition: rf_nv, [000001000800 - 000001200800], size: 000000200000 (2.00 MB) Partition: deviceinfo, [000001200800 - 000001300800], size: 000000100000 (1.00 MB) Partition: securefs, [000001300800 - 000001500800], size: 000000200000 (2.00 MB) Partition: cust_nv, [000001500800 - 000001700800], size: 000000200000 (2.00 MB) Partition: ftmlog, [000001700800 - 000003700800], size: 000002000000 (32.0 MB) Partition: box, [000003700800 - 000003F00800], size: 000000800000 (8.00 MB) Partition: ftm, [000003F00800 - 000005F00800], size: 000002000000 (32.0 MB) Partition: hidden, [000005F00800 - 000007900800], size: 000001A00000 (26.0 MB) Partition: cda, [000007900800 - 000008100800], size: 000000800000 (8.00 MB) Partition: logdump, [000008100800 - 000008B00800], size: 000000A00000 (10.0 MB) Partition: elabel, [000008B00800 - 000008F00800], size: 000000400000 (4.00 MB) Partition: reserved_bak, [000008F00800 - 000009100800], size: 000000200000 (2.00 MB) Partition: recovery, [000009100800 - 00000B100800], size: 000002000000 (32.0 MB) Partition: sec, [00000B100800 - 00000B104800], size: 000000004000 (16.0 KB) Partition: boot, [00000B104800 - 00000D104800], size: 000002000000 (32.0 MB) Partition: modem, [00000D104800 - 000011104800], size: 000004000000 (64.0 MB) Partition: system, [000011104800 - 0000C4504800], size: 0000B3400000 (2.80 GB) Partition: misc, [0000C4504800 - 0000C4604800], size: 000000100000 (1.00 MB) Partition: cache, [0000C4604800 - 0000CAA04800], size: 000006400000 (100. MB) Partition: persist, [0000CAA04800 - 0000CCA04800], size: 000002000000 (32.0 MB) Partition: devinfo, [0000CD000000 - 0000CD100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000CD800000 - 0000CD880000], size: 000000080000 (512. KB) Partition: config, [0000CD880000 - 0000CD900000], size: 000000080000 (512. KB) Partition: cmnlib, [0000CE000000 - 0000CE040000], size: 000000040000 (256. KB) Partition: cmnlibbak, [0000CE040000 - 0000CE080000], size: 000000040000 (256. KB) Partition: keymaster, [0000CE080000 - 0000CE0C0000], size: 000000040000 (256. KB) Partition: keymasterbak, [0000CE0C0000 - 0000CE100000], size: 000000040000 (256. KB) Partition: userdata, [0000CE800000 - 0001D1FFBE00], size: 0001037FBE00 (4.05 GB) GPT header successfully parsed Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2176 mV CMD Active Level: 2325 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_222547.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000004400 - 000000084400], size: 000000080000 (512. KB) Partition: sbl1bak, [000000084400 - 000000104400], size: 000000080000 (512. KB) Partition: aboot, [000000104400 - 000000204400], size: 000000100000 (1.00 MB) Partition: abootbak, [000000204400 - 000000304400], size: 000000100000 (1.00 MB) Partition: rpm, [000000304400 - 000000384400], size: 000000080000 (512. KB) Partition: rpmbak, [000000384400 - 000000404400], size: 000000080000 (512. KB) Partition: tz, [000000404400 - 0000004C4400], size: 0000000C0000 (768. KB) Partition: tzbak, [0000004C4400 - 000000584400], size: 0000000C0000 (768. KB) Partition: DDR, [000000584400 - 00000058C400], size: 000000008000 (32.0 KB) Partition: pad, [00000058C400 - 00000068C400], size: 000000100000 (1.00 MB) Partition: ssd, [00000068C400 - 00000068E400], size: 000000002000 (8.00 KB) Partition: sutinfo, [00000068E400 - 00000068E800], size: 000000000400 (1.00 KB) Partition: systeminfo, [00000068E800 - 0000006CE800], size: 000000040000 (256. KB) Partition: splash, [0000006CE800 - 0000009CE800], size: 000000300000 (3.00 MB) Partition: reserved, [0000009CE800 - 000000A00000], size: 000000031800 (198. KB) Partition: fsg, [000000A00000 - 000000B80000], size: 000000180000 (1.50 MB) Partition: modemst1, [000000C00000 - 000000D80000], size: 000000180000 (1.50 MB) Partition: modemst2, [000000E00000 - 000000F80000], size: 000000180000 (1.50 MB) Partition: fsc, [000001000000 - 000001000800], size: 000000000800 (2.00 KB) Partition: rf_nv, [000001000800 - 000001200800], size: 000000200000 (2.00 MB) Partition: deviceinfo, [000001200800 - 000001300800], size: 000000100000 (1.00 MB) Partition: securefs, [000001300800 - 000001500800], size: 000000200000 (2.00 MB) Partition: cust_nv, [000001500800 - 000001700800], size: 000000200000 (2.00 MB) Partition: ftmlog, [000001700800 - 000003700800], size: 000002000000 (32.0 MB) Partition: box, [000003700800 - 000003F00800], size: 000000800000 (8.00 MB) Partition: ftm, [000003F00800 - 000005F00800], size: 000002000000 (32.0 MB) Partition: hidden, [000005F00800 - 000007900800], size: 000001A00000 (26.0 MB) Partition: cda, [000007900800 - 000008100800], size: 000000800000 (8.00 MB) Partition: logdump, [000008100800 - 000008B00800], size: 000000A00000 (10.0 MB) Partition: elabel, [000008B00800 - 000008F00800], size: 000000400000 (4.00 MB) Partition: reserved_bak, [000008F00800 - 000009100800], size: 000000200000 (2.00 MB) Partition: recovery, [000009100800 - 00000B100800], size: 000002000000 (32.0 MB) Partition: sec, [00000B100800 - 00000B104800], size: 000000004000 (16.0 KB) Partition: boot, [00000B104800 - 00000D104800], size: 000002000000 (32.0 MB) Partition: modem, [00000D104800 - 000011104800], size: 000004000000 (64.0 MB) Partition: system, [000011104800 - 0000C4504800], size: 0000B3400000 (2.80 GB) Partition: misc, [0000C4504800 - 0000C4604800], size: 000000100000 (1.00 MB) Partition: cache, [0000C4604800 - 0000CAA04800], size: 000006400000 (100. MB) Partition: persist, [0000CAA04800 - 0000CCA04800], size: 000002000000 (32.0 MB) Partition: devinfo, [0000CD000000 - 0000CD100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000CD800000 - 0000CD880000], size: 000000080000 (512. KB) Partition: config, [0000CD880000 - 0000CD900000], size: 000000080000 (512. KB) Partition: cmnlib, [0000CE000000 - 0000CE040000], size: 000000040000 (256. KB) Partition: cmnlibbak, [0000CE040000 - 0000CE080000], size: 000000040000 (256. KB) Partition: keymaster, [0000CE080000 - 0000CE0C0000], size: 000000040000 (256. KB) Partition: keymasterbak, [0000CE0C0000 - 0000CE100000], size: 000000040000 (256. KB) Partition: userdata, [0000CE800000 - 0001D1FFBE00], size: 0001037FBE00 (4.05 GB) GPT header successfully parsed Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2177 mV CMD Active Level: 2326 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_222606.extcsd EMMC Init completed. Opening file: Program_Def.xml Error: eMMC has a small size The size of the last section has been updated Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2176 mV CMD Active Level: 2325 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_222613.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001CCFFBE00 GPT-partitioning done Partition name: sbl1 Filename: sbl1.mbn , Offset: 000000004400 , filesize: 249856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1054.35 KB/s Partition name: sbl1bak Filename: sbl1.mbn , Offset: 000000084400 , filesize: 249856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1015.46 KB/s Partition name: aboot Filename: emmc_appsboot.mbn , Offset: 000000104400 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1407.27 KB/s Partition name: abootbak Filename: emmc_appsboot.mbn , Offset: 000000204400 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1994.60 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 000000304400 , filesize: 151552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1795.06 KB/s Partition name: rpmbak Filename: rpm.mbn , Offset: 000000384400 , filesize: 151552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1662.49 KB/s Partition name: tz Filename: tz.mbn , Offset: 000000404400 , filesize: 532480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1850.59 KB/s Partition name: tzbak Filename: tz.mbn , Offset: 0000004C4400 , filesize: 532480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1910.89 KB/s Partition name: splash Filename: splash.img , Offset: 0000006CE800 , filesize: 1470464 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2001.43 KB/s Partition name: fsg Filename: fsg.bin , Offset: 000000A00000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1960.71 KB/s Partition name: modemst1 Filename: modemst1.bin , Offset: 000000C00000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1951.62 KB/s Partition name: modemst2 Filename: modemst2.bin , Offset: 000000E00000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1995.53 KB/s Partition name: fsc Filename: fsc.bin , Offset: 000001000000 , filesize: 2048 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 147.92 KB/s Partition name: ftm Filename: ftm.img , Offset: 000003F00800 , filesize: 13172736 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2029.68 KB/s Partition name: hidden Filename: hidden.img , Offset: 000005F00800 , filesize: 26779648 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2024.61 KB/s Partition name: cda Filename: cda.img , Offset: 000007900800 , filesize: 4546560 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2015.19 KB/s Partition name: recovery Filename: recovery.img , Offset: 000009100800 , filesize: 16277504 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2018.46 KB/s Partition name: sec Filename: sec.bin , Offset: 00000B100800 , filesize: 16384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 779.39 KB/s Partition name: boot Filename: boot.img , Offset: 00000B104800 , filesize: 16195584 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2016.33 KB/s Partition name: modem Filename: NON-HLOS.bin , Offset: 00000D104800 , filesize: 59912192 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2024.78 KB/s Partition name: system Filename: system.img , Offset: 000011104800 , filesize: 2367113604 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 8734 Done writing partition. Write speed: 1975.01 KB/s Partition name: misc Filename: misc.img , Offset: 0000C4504800 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1455.74 KB/s Partition name: cache Filename: cache.img , Offset: 0000C4604800 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1343.12 KB/s Partition name: persist Filename: persist.bin , Offset: 0000CAA04800 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2025.80 KB/s Partition name: cmnlib Filename: cmnlib.mbn , Offset: 0000CE000000 , filesize: 167936 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1354.53 KB/s Partition name: cmnlibbak Filename: cmnlib.mbn , Offset: 0000CE040000 , filesize: 167936 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1768.05 KB/s Partition name: keymaster Filename: keymaster.mbn , Offset: 0000CE080000 , filesize: 151552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1558.20 KB/s Partition name: keymasterbak Filename: keymaster.mbn , Offset: 0000CE0C0000 , filesize: 151552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2036.62 KB/s Partition name: userdata Filename: userdata.img , Offset: 0000CE800000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1605.97 KB/s Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:25:11:474] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2174 mV CMD Active Level: 2324 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_225139.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000004400 - 000000084400], size: 000000080000 (512. KB) Partition: sbl1bak, [000000084400 - 000000104400], size: 000000080000 (512. KB) Partition: aboot, [000000104400 - 000000204400], size: 000000100000 (1.00 MB) Partition: abootbak, [000000204400 - 000000304400], size: 000000100000 (1.00 MB) Partition: rpm, [000000304400 - 000000384400], size: 000000080000 (512. KB) Partition: rpmbak, [000000384400 - 000000404400], size: 000000080000 (512. KB) Partition: tz, [000000404400 - 0000004C4400], size: 0000000C0000 (768. KB) Partition: tzbak, [0000004C4400 - 000000584400], size: 0000000C0000 (768. KB) Partition: DDR, [000000584400 - 00000058C400], size: 000000008000 (32.0 KB) Partition: pad, [00000058C400 - 00000068C400], size: 000000100000 (1.00 MB) Partition: ssd, [00000068C400 - 00000068E400], size: 000000002000 (8.00 KB) Partition: sutinfo, [00000068E400 - 00000068E800], size: 000000000400 (1.00 KB) Partition: systeminfo, [00000068E800 - 0000006CE800], size: 000000040000 (256. KB) Partition: splash, [0000006CE800 - 0000009CE800], size: 000000300000 (3.00 MB) Partition: reserved, [0000009CE800 - 000000A00000], size: 000000031800 (198. KB) Partition: fsg, [000000A00000 - 000000B80000], size: 000000180000 (1.50 MB) Partition: modemst1, [000000C00000 - 000000D80000], size: 000000180000 (1.50 MB) Partition: modemst2, [000000E00000 - 000000F80000], size: 000000180000 (1.50 MB) Partition: fsc, [000001000000 - 000001000800], size: 000000000800 (2.00 KB) Partition: rf_nv, [000001000800 - 000001200800], size: 000000200000 (2.00 MB) Partition: deviceinfo, [000001200800 - 000001300800], size: 000000100000 (1.00 MB) Partition: securefs, [000001300800 - 000001500800], size: 000000200000 (2.00 MB) Partition: cust_nv, [000001500800 - 000001700800], size: 000000200000 (2.00 MB) Partition: ftmlog, [000001700800 - 000003700800], size: 000002000000 (32.0 MB) Partition: box, [000003700800 - 000003F00800], size: 000000800000 (8.00 MB) Partition: ftm, [000003F00800 - 000005F00800], size: 000002000000 (32.0 MB) Partition: hidden, [000005F00800 - 000007900800], size: 000001A00000 (26.0 MB) Partition: cda, [000007900800 - 000008100800], size: 000000800000 (8.00 MB) Partition: logdump, [000008100800 - 000008B00800], size: 000000A00000 (10.0 MB) Partition: elabel, [000008B00800 - 000008F00800], size: 000000400000 (4.00 MB) Partition: reserved_bak, [000008F00800 - 000009100800], size: 000000200000 (2.00 MB) Partition: recovery, [000009100800 - 00000B100800], size: 000002000000 (32.0 MB) Partition: sec, [00000B100800 - 00000B104800], size: 000000004000 (16.0 KB) Partition: boot, [00000B104800 - 00000D104800], size: 000002000000 (32.0 MB) Partition: modem, [00000D104800 - 000011104800], size: 000004000000 (64.0 MB) Partition: system, [000011104800 - 0000C4504800], size: 0000B3400000 (2.80 GB) Partition: misc, [0000C4504800 - 0000C4604800], size: 000000100000 (1.00 MB) Partition: cache, [0000C4604800 - 0000CAA04800], size: 000006400000 (100. MB) Partition: persist, [0000CAA04800 - 0000CCA04800], size: 000002000000 (32.0 MB) Partition: devinfo, [0000CD000000 - 0000CD100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000CD800000 - 0000CD880000], size: 000000080000 (512. KB) Partition: config, [0000CD880000 - 0000CD900000], size: 000000080000 (512. KB) Partition: cmnlib, [0000CE000000 - 0000CE040000], size: 000000040000 (256. KB) Partition: cmnlibbak, [0000CE040000 - 0000CE080000], size: 000000040000 (256. KB) Partition: keymaster, [0000CE080000 - 0000CE0C0000], size: 000000040000 (256. KB) Partition: keymasterbak, [0000CE0C0000 - 0000CE100000], size: 000000040000 (256. KB) Partition: userdata, [0000CE800000 - 0001D1FFBE00], size: 0001037FBE00 (4.05 GB) GPT header successfully parsed Get firmware version Brand = Unknown Manufacturer = FIH Device = Unknown Model = Unknown Phone platform = msm8909 CPU Abi = armeabi-v7a Android release = 7.1.1 Security Patch = 2017-11-01 Firmware version = 00WW_0_55B Firmware date = Fri Nov 10 19:31:15 CST 2017 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2174 mV CMD Active Level: 2324 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_225204.extcsd EMMC Init completed. Opening file: H8G4a2_rawprogram0.xml Error: eMMC has a small size The size of the last section has been updated Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2174 mV CMD Active Level: 2322 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_225222.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001CCFFBE00 GPT-partitioning done Partition name: fsg Filename: fsg.bin , Offset: 000000A00000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1104.11 KB/s Partition name: modemst1 Filename: modemst1.bin , Offset: 000000C00000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2036.75 KB/s Partition name: modemst2 Filename: modemst2.bin , Offset: 000000E00000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1966.03 KB/s Partition name: fsc Filename: fsc.bin , Offset: 000001000000 , filesize: 2048 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 148.66 KB/s Partition name: sec Filename: sec.bin , Offset: 00000B100800 , filesize: 16384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 730.53 KB/s Partition name: modem Filename: modem.bin , Offset: 00000D104800 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2019.69 KB/s Partition name: persist Filename: persist.bin , Offset: 0000CAA04800 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2015.92 KB/s Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:01:08:898] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2171 mV CMD Active Level: 2321 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_225336.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000004400 - 000000084400], size: 000000080000 (512. KB) Partition: sbl1bak, [000000084400 - 000000104400], size: 000000080000 (512. KB) Partition: aboot, [000000104400 - 000000204400], size: 000000100000 (1.00 MB) Partition: abootbak, [000000204400 - 000000304400], size: 000000100000 (1.00 MB) Partition: rpm, [000000304400 - 000000384400], size: 000000080000 (512. KB) Partition: rpmbak, [000000384400 - 000000404400], size: 000000080000 (512. KB) Partition: tz, [000000404400 - 0000004C4400], size: 0000000C0000 (768. KB) Partition: tzbak, [0000004C4400 - 000000584400], size: 0000000C0000 (768. KB) Partition: DDR, [000000584400 - 00000058C400], size: 000000008000 (32.0 KB) Partition: pad, [00000058C400 - 00000068C400], size: 000000100000 (1.00 MB) Partition: ssd, [00000068C400 - 00000068E400], size: 000000002000 (8.00 KB) Partition: sutinfo, [00000068E400 - 00000068E800], size: 000000000400 (1.00 KB) Partition: systeminfo, [00000068E800 - 0000006CE800], size: 000000040000 (256. KB) Partition: splash, [0000006CE800 - 0000009CE800], size: 000000300000 (3.00 MB) Partition: reserved, [0000009CE800 - 000000A00000], size: 000000031800 (198. KB) Partition: fsg, [000000A00000 - 000000B80000], size: 000000180000 (1.50 MB) Partition: modemst1, [000000C00000 - 000000D80000], size: 000000180000 (1.50 MB) Partition: modemst2, [000000E00000 - 000000F80000], size: 000000180000 (1.50 MB) Partition: fsc, [000001000000 - 000001000800], size: 000000000800 (2.00 KB) Partition: rf_nv, [000001000800 - 000001200800], size: 000000200000 (2.00 MB) Partition: deviceinfo, [000001200800 - 000001300800], size: 000000100000 (1.00 MB) Partition: securefs, [000001300800 - 000001500800], size: 000000200000 (2.00 MB) Partition: cust_nv, [000001500800 - 000001700800], size: 000000200000 (2.00 MB) Partition: ftmlog, [000001700800 - 000003700800], size: 000002000000 (32.0 MB) Partition: box, [000003700800 - 000003F00800], size: 000000800000 (8.00 MB) Partition: ftm, [000003F00800 - 000005F00800], size: 000002000000 (32.0 MB) Partition: hidden, [000005F00800 - 000007900800], size: 000001A00000 (26.0 MB) Partition: cda, [000007900800 - 000008100800], size: 000000800000 (8.00 MB) Partition: logdump, [000008100800 - 000008B00800], size: 000000A00000 (10.0 MB) Partition: elabel, [000008B00800 - 000008F00800], size: 000000400000 (4.00 MB) Partition: reserved_bak, [000008F00800 - 000009100800], size: 000000200000 (2.00 MB) Partition: recovery, [000009100800 - 00000B100800], size: 000002000000 (32.0 MB) Partition: sec, [00000B100800 - 00000B104800], size: 000000004000 (16.0 KB) Partition: boot, [00000B104800 - 00000D104800], size: 000002000000 (32.0 MB) Partition: modem, [00000D104800 - 000011104800], size: 000004000000 (64.0 MB) Partition: system, [000011104800 - 0000C4504800], size: 0000B3400000 (2.80 GB) Partition: misc, [0000C4504800 - 0000C4604800], size: 000000100000 (1.00 MB) Partition: cache, [0000C4604800 - 0000CAA04800], size: 000006400000 (100. MB) Partition: persist, [0000CAA04800 - 0000CCA04800], size: 000002000000 (32.0 MB) Partition: devinfo, [0000CD000000 - 0000CD100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000CD800000 - 0000CD880000], size: 000000080000 (512. KB) Partition: config, [0000CD880000 - 0000CD900000], size: 000000080000 (512. KB) Partition: cmnlib, [0000CE000000 - 0000CE040000], size: 000000040000 (256. KB) Partition: cmnlibbak, [0000CE040000 - 0000CE080000], size: 000000040000 (256. KB) Partition: keymaster, [0000CE080000 - 0000CE0C0000], size: 000000040000 (256. KB) Partition: keymasterbak, [0000CE0C0000 - 0000CE100000], size: 000000040000 (256. KB) Partition: userdata, [0000CE800000 - 0001D1FFBE00], size: 0001037FBE00 (4.05 GB) GPT header successfully parsed Get firmware version Brand = Unknown Manufacturer = FIH Device = Unknown Model = Unknown Phone platform = msm8909 CPU Abi = armeabi-v7a Android release = 7.1.1 Security Patch = 2017-11-01 Firmware version = 00WW_0_55B Firmware date = Fri Nov 10 19:31:15 CST 2017 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2172 mV CMD Active Level: 2321 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_225438.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM1 , start: 0x000000000000 , size: 0x000020000000 Output file: C:\Users\hp\Nokia 2\Nokia TA-1007 DUMP\EMMC_H8G4a2_ROM1_000000000000_000020000000.bin eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2126.00 Kb/s All done time: [00:04:09:904] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2171 mV CMD Active Level: 2322 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_225950.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\hp\Nokia 2\Nokia TA-1007 DUMP\EMMC_H8G4a2_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 1706.13 Kb/s All done time: [00:00:05:688] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2172 mV CMD Active Level: 2321 mV EMMC Device Information : EMMC CID: 90014A483847346132A5C6984D33255B EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: C6984D33 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 84414 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4a2_C6984D33_20210709_230018.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\hp\Nokia 2\Nokia TA-1007 DUMP\EMMC_H8G4a2_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Reading partition... Done reading partition. Read speed: 1708.90 Kb/s All done time: [00:00:05:697] |
The Following 4 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
