Old 10-01-2019, 23:05   #1 (permalink)
Member: 1789551
Thanks Meter: 90
LG M700TV Q6+ QDLoader via Test Point
Hi is possible full backup and write flash using Test Point ?
QC Core Version 2.10
Using Port :COM42
Detecting Device mode...
Connecting to device without external programmers...
Device Class: sahara
Device Protocol: firehose
Emergency Mode: true
Reading QC Device information...
SerialNumber: 0xD400C330
MSM_HW_ID: 0x0006B0E1
OEM_PK_HASH: 0x2CF7619A278D26073F7EEA79BB7F4B7949C221487FEA058E A072CFFE38CE1496
SBL SW Version: 0x00000000
You must select loader to get access to EDL functions
Operation status: 0 Sucesso
Using Port :COM42
Using EDL Programmer :C:\Program Files\Z3X\EASYJTAG\Loaders\prog_emmc_firehose_8937 _lite.mbn
Sahara Connectting To Device
Sahara Downloading flash programmer: C:\Program Files\Z3X\EASYJTAG\Loaders\prog_emmc_firehose_8937 _lite.mbn
Waiting for flash programmer to boot
Error call virtual function open_wrapper
Warning! Can't open source to read GPT
Partition info not found
Operation status: -4 COM port read error...
Old 10-02-2019, 02:00   #2 (permalink)
Member: 1789551
Thanks Meter: 90
I am creating a backup of this device. It shows the logo and reboots, does not go into download mode and the customer needs the device data. How can I repair it?
Warning: Health report is very BAD
Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used
Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used
Pre EOL information [267]: 0x03 Urgent
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 24 MHz
CMD Pullup Level: 1822 mV
CMD Active Level: 1878 mV
EMMC Device Information :
EMMC CID: 90014A484347386134A22986DA722581
EMMC CSD: D02701328F5903FFFFFFFFEF8A400027
EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2986DA72 , rev. 0xA2
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2018
   EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1187 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HCG8a4_2986DA72_20191001_194338.extcsd
EMMC Init completed.
Operation: Find table from emmc
Vendor: Qualcomm
Searching GPT ...
GPT header is found and is valid
Checking for ROM2 ...
ROM2 is blank
Checking for ROM3 ...
ROM3 is blank
GPT header successfully parsed
Old 10-02-2019, 13:30   #3 (permalink)
Member: 1789551
Thanks Meter: 90
BAD EMMC?
Operation: Reading S.M.A.R.T Report ...
Optimal Read Size [266]: 0x40   256 KB
Optimal Write Size [265]: 0x40   256 KB
Optimal Trim Unit Size [264]: 0x07   28 KB
Operation: Random verify eMMC ...
If your restore data error occurs - the original data can be found in a folder:
\Backups\RandomVerify\HCG8a4_2986DA72_20191002_092619
eMMC switching to ROM1
Address: 000000000000, size: 000000004000 - FAIL
Address: 000000004000, size: 000000004000 - FAIL
Address: 000000008000, size: 000000004000 - FAIL
Address: 00000000C000, size: 000000004000 - FAIL
Address: 000000010000, size: 000000004000 - FAIL
Address: 000000014000, size: 000000004000 - FAIL
Address: 000000018000, size: 000000004000 - FAIL
Address: 00000001C000, size: 000000004000 - FAIL
Address: 000000020000, size: 000000004000 - FAIL
Address: 000000024000, size: 000000004000 - FAIL
Address: 000000028000, size: 000000004000 - FAIL
Address: 00000002C000, size: 000000004000 - FAIL
Address: 000000030000, size: 000000004000 - FAIL
Address: 000000034000, size: 000000004000 - FAIL
Address: 000000038000, size: 000000004000 - FAIL
Address: 00000003C000, size: 000000004000 - FAIL
Address: 000000040000, size: 000000004000 - FAIL
Address: 000000044000, size: 000000004000 - FAIL
Address: 000000048000, size: 000000004000 - FAIL
Address: 00000004C000, size: 000000004000 - FAIL
Write Speed - Max : 2574,87 KB/s , Min : 2412,36 KB/s , Avg : 2691,43 KB/s ,  Slow blocks: 0 of 19 (0,00 %) ,  Verified: 304,00 KB
Read Speed - Max : 2490,54 KB/s , Min : 2381,52 KB/s , Avg : 2595,62 KB/s ,  Slow blocks: 0 of 19 (0,00 %) ,  Verified: 304,00 KB
Exceeded limit for errors
Verified 0 MB. Errors - 20
Old 10-02-2019, 17:24   #4 (permalink)
Member: 1789551
Thanks Meter: 90
Hi
I need extract userdata this phone is possible?
Android 7.1.1 It no power, shown logo LG and restart. I did full dump with user partitons without fails.
Old 10-05-2019, 08:31   #5 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
1) backup partititons
2) try this method: http://forum.gsmhosting.com/vbb/f672...ution-2585863/
3) restore partititons
4) solder eMMC, run phone, backup data
Old 10-05-2019, 15:11   #6 (permalink)
Member: 1789551
Thanks Meter: 90
Hi Mr Layder
I tried but no sucess
I did type : "Confirm" , But alway got same error.
I need remove EMMC and use socket for this operation ?
Z3X EasyJtag Software ver. 3.6.1.4
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: 15AEEBC0126DD0AB, ,FW Ver.: 02.44
CMD Pullup Level:1821 mV
CMD Active Level:1877 mV
Box IO Level:1800 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A484347386134A22986DA722581
eMMC CSD : D02701328F5903FFFFFFFFEF8A400027
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 02/2018  Rev.0xA2
eMMC NAME: HCG8a4 , S/N:  696703602
eMMC NAME (HEX): 484347386134
EMMC ROM1 (Main User Data)   Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 1187 times
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HCG8a4_ 696703602_20191004_2316.extcsd
Done.
Operation not allowed , confirmation password not match!
Old 10-05-2019, 15:46   #7 (permalink)
Member: 1789551
Thanks Meter: 90
using emmc tool suite 1.6.2.0
HiPower mode is ON
CMD Pullup Level: 1820 mV
CMD Active Level: 1877 mV
Backup saved: HCG8a4_2986DA72_20191004_235320.extcsd
Operation: Changing GP sizes (test mode) ...
GP1 size: 0 MB , WR_REL: 1 , ENH 1
GP2 size: 0 MB , WR_REL: 1 , ENH 0
GP3 size: 0 MB , WR_REL: 1 , ENH 0
GP4 size: 0 MB , WR_REL: 1 , ENH 0
Zero sizes. This may damage your eMMC
Do you want to continue?
HW_PART error. Reason: CMD Timeout Error
Old 10-06-2019, 12:44   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
1) CONFIRM - All big letters
2) some eMMC is strange - try classic software
Old 10-07-2019, 02:55   #9 (permalink)
Member: 1789551
Thanks Meter: 90
I need remove emmc for this operation? Because i am using isp.
I tried CONFIRM all big letters but got same error.
Old 10-07-2019, 09:04   #10 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Not need remove
may be this eMMC can't be repaired via this method
Old 10-07-2019, 13:44   #11 (permalink)
Member: 1789551
Thanks Meter: 90
Hi
I am trying use EasyJtag Tool , But alway got same error "Operation not allowed , confirmation password not match!"
I already tried these password below:
confirm
Confirm
CONFIRM
Old 10-08-2019, 14:41   #12 (permalink)
Member: 1789551
Thanks Meter: 90
Hi Layder
Can you help me about wrong password ?
I want try use easy tool too
Old 10-12-2019, 15:49   #13 (permalink)
Member: 1789551
Thanks Meter: 90
Hi Layder
Phone is alive now. more when starting he asked to restore the data. and I need to get the data from the phone (I backed up and went back all the partitions) but still when I turned on the phone to restore the phone.
HiPower mode is ON
Setting frequence to 18 MHz
CMD Pullup Level: 592 mV
CMD Active Level: 1867 mV
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1200 , Response: Not Clean
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: HCG8a4_2986DA72_20191011_102443.extcsd
Scanning soft partitions
Partition: modem, [000000800000 - 000006000000], size: 000005800000 (88,0 MB)
Partition: aboot, [000006000000 - 000006200000], size: 000000200000 (2,00 MB)
Partition: abootbak, [000006200000 - 000006400000], size: 000000200000 (2,00 MB)
Partition: tz, [000006400000 - 000006600000], size: 000000200000 (2,00 MB)
Partition: tzbak, [000006600000 - 000006800000], size: 000000200000 (2,00 MB)
Partition: sbl1, [000006800000 - 000006900000], size: 000000100000 (1,00 MB)
Partition: sbl1bak, [000006900000 - 000006A00000], size: 000000100000 (1,00 MB)
Partition: rpm, [000006A00000 - 000006A80000], size: 000000080000 (512 KB)
Partition: rpmbak, [000006A80000 - 000006B00000], size: 000000080000 (512 KB)
Partition: devcfg, [000006B00000 - 000006B80000], size: 000000080000 (512 KB)
Partition: devcfgbak, [000006B80000 - 000006C00000], size: 000000080000 (512 KB)
Partition: cmnlib, [000006C00000 - 000006C80000], size: 000000080000 (512 KB)
Partition: cmnlibbak, [000006C80000 - 000006D00000], size: 000000080000 (512 KB)
Partition: cmnlib64, [000006D00000 - 000006D80000], size: 000000080000 (512 KB)
Partition: cmnlib64bak, [000006D80000 - 000006E00000], size: 000000080000 (512 KB)
Partition: keymaster, [000006E00000 - 000006E80000], size: 000000080000 (512 KB)
Partition: keymasterbak, [000006E80000 - 000006F00000], size: 000000080000 (512 KB)
Partition: spare1, [000006F00000 - 000006F80000], size: 000000080000 (512 KB)
Partition: spare2, [000006F80000 - 000007000000], size: 000000080000 (512 KB)
Partition: persistent, [000007000000 - 000007080000], size: 000000080000 (512 KB)
Partition: devinfo, [000007080000 - 000007180000], size: 000000100000 (1,00 MB)
Partition: spare3, [000007180000 - 000007800000], size: 000000680000 (6,50 MB)
Partition: modemst1, [000007800000 - 000007980000], size: 000000180000 (1,50 MB)
Partition: modemst2, [000007980000 - 000007B00000], size: 000000180000 (1,50 MB)
Partition: mcfg, [000007B00000 - 000007F00000], size: 000000400000 (4,00 MB)
Partition: fsc, [000007F00000 - 000007F80000], size: 000000080000 (512 KB)
Partition: ssd, [000007F80000 - 000008000000], size: 000000080000 (512 KB)
Partition: fsg, [000008000000 - 000008180000], size: 000000180000 (1,50 MB)
Partition: spare4, [000008180000 - 000008800000], size: 000000680000 (6,50 MB)
Partition: dsp, [000008800000 - 000009800000], size: 000001000000 (16,0 MB)
Partition: ftm, [000009800000 - 00000A000000], size: 000000800000 (8,00 MB)
Partition: misc, [00000A000000 - 00000A800000], size: 000000800000 (8,00 MB)
Partition: drm, [00000A800000 - 00000B000000], size: 000000800000 (8,00 MB)
Partition: sns, [00000B000000 - 00000B800000], size: 000000800000 (8,00 MB)
Partition: fota, [00000B800000 - 00000C200000], size: 000000A00000 (10,0 MB)
Partition: sec, [00000C200000 - 00000C280000], size: 000000080000 (512 KB)
Partition: keystore, [00000C280000 - 00000C300000], size: 000000080000 (512 KB)
Partition: rct, [00000C300000 - 00000C380000], size: 000000080000 (512 KB)
Partition: encrypt, [00000C380000 - 00000C400000], size: 000000080000 (512 KB)
Partition: eksst, [00000C400000 - 00000C480000], size: 000000080000 (512 KB)
Partition: apdp, [00000C480000 - 00000C500000], size: 000000080000 (512 KB)
Partition: msadp, [00000C500000 - 00000C580000], size: 000000080000 (512 KB)
Partition: dpo, [00000C580000 - 00000C600000], size: 000000080000 (512 KB)
Partition: DDR, [00000C600000 - 00000C680000], size: 000000080000 (512 KB)
Partition: spare5, [00000C680000 - 00000C800000], size: 000000180000 (1,50 MB)
Partition: boot, [00000C800000 - 00000E800000], size: 000002000000 (32,0 MB)
Partition: laf, [00000E800000 - 000010800000], size: 000002000000 (32,0 MB)
Partition: lafbak, [000010800000 - 000012800000], size: 000002000000 (32,0 MB)
Partition: recovery, [000012800000 - 000014800000], size: 000002000000 (32,0 MB)
Partition: recoverybak, [000014800000 - 000016800000], size: 000002000000 (32,0 MB)
Partition: factory, [000016800000 - 00001A000000], size: 000003800000 (56,0 MB)
Partition: raw_resources, [00001A000000 - 00001A400000], size: 000000400000 (4,00 MB)
Partition: raw_resourcesbak, [00001A400000 - 00001A800000], size: 000000400000 (4,00 MB)
Partition: persist, [00001A800000 - 00001C800000], size: 000002000000 (32,0 MB)
Partition: mpt, [00001C800000 - 00001E800000], size: 000002000000 (32,0 MB)
Partition: srtc, [00001E800000 - 00001F000000], size: 000000800000 (8,00 MB)
Partition: system, [00001F000000 - 00015F000000], size: 000140000000 (5,00 GB)
Partition: cache, [00015F000000 - 00017F000000], size: 000020000000 (512 MB)
Partition: OP, [00017F000000 - 000186000000], size: 000007000000 (112 MB)
Partition: userdata, [000186000000 - 000E8F7FBC00], size: 000D097FBC00 (52,1 GB)
Partition: grow, [000E8F7FBC00 - 000E8F7FBE00], size: 000000000200 (512 B)
Get firmware version
Brand = lge
Manufacturer = LGE
Device = mh
Model = LG-M700
Phone platform = msm8937
CPU Abi = armeabi-v7a
Android release = 7.1.1
Firmware version = NMF26X
Firmware date = Thu Jul 11 11:57:18 IST 2019
HiPower mode is ON
Backup saved: HCG8a4_2986DA72_20191011_102453.extcsd
Operation: Write by vendor (Qualcomm/HiSilicon/Omap)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 000E8F7FBE00
GPT-partitioning done
Partition name: modem
Filename: modem.bin , Offset: 000000800000 , filesize: 92274688 bytes
Erasing partition...
Writing partition...
Done writing partition. Write speed: 1950,79 KB/s
Partition name: aboot
Filename: aboot.bin , Offset: 000006000000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1982,18 KB/s
Partition name: abootbak
Filename: abootbak.bin , Offset: 000006200000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1953,94 KB/s
Partition name: tz
Filename: tz.bin , Offset: 000006400000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1969,85 KB/s
Partition name: tzbak
Filename: tzbak.bin , Offset: 000006600000 , filesize: 2097152 bytes
Done writing partition. Write speed: 1995,36 KB/s
Partition name: sbl1
Filename: sbl1.bin , Offset: 000006800000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1986,40 KB/s
Partition name: sbl1bak
Filename: sbl1bak.bin , Offset: 000006900000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1934,14 KB/s
Partition name: rpm
Filename: rpm.bin , Offset: 000006A00000 , filesize: 524288 bytes
Done writing partition. Write speed: 1896,61 KB/s
Partition name: rpmbak
Filename: rpmbak.bin , Offset: 000006A80000 , filesize: 524288 bytes
Done writing partition. Write speed: 1880,44 KB/s
Partition name: devcfg
Filename: devcfg.bin , Offset: 000006B00000 , filesize: 524288 bytes
Done writing partition. Write speed: 1897,96 KB/s
Partition name: devcfgbak
Filename: devcfgbak.bin , Offset: 000006B80000 , filesize: 524288 bytes
Done writing partition. Write speed: 1935,29 KB/s
Partition name: cmnlib
Filename: cmnlib.bin , Offset: 000006C00000 , filesize: 524288 bytes
Done writing partition. Write speed: 1900,24 KB/s
Partition name: cmnlibbak
Filename: cmnlibbak.bin , Offset: 000006C80000 , filesize: 524288 bytes
Done writing partition. Write speed: 1885,79 KB/s
Partition name: cmnlib64
Filename: cmnlib64.bin , Offset: 000006D00000 , filesize: 524288 bytes
Done writing partition. Write speed: 1829,15 KB/s
Partition name: cmnlib64bak
Filename: cmnlib64bak.bin , Offset: 000006D80000 , filesize: 524288 bytes
Done writing partition. Write speed: 1888,39 KB/s
Partition name: keymaster
Filename: keymaster.bin , Offset: 000006E00000 , filesize: 524288 bytes
Done writing partition. Write speed: 1923,74 KB/s
Partition name: keymasterbak
Filename: keymasterbak.bin , Offset: 000006E80000 , filesize: 524288 bytes
Done writing partition. Write speed: 1934,17 KB/s
Partition name: spare1
Filename: spare1.bin , Offset: 000006F00000 , filesize: 524288 bytes
Done writing partition. Write speed: 1862,15 KB/s
Partition name: spare2
Filename: spare2.bin , Offset: 000006F80000 , filesize: 524288 bytes
Done writing partition. Write speed: 1897,80 KB/s
Partition name: persistent
Filename: persistent.bin , Offset: 000007000000 , filesize: 524288 bytes
Done writing partition. Write speed: 1873,09 KB/s
Partition name: devinfo
Filename: devinfo.bin , Offset: 000007080000 , filesize: 1048576 bytes
Done writing partition. Write speed: 1934,50 KB/s
Partition name: spare3
Filename: spare3.bin , Offset: 000007180000 , filesize: 6815744 bytes
Done writing partition. Write speed: 1987,25 KB/s
Partition name: modemst1
Filename: modemst1.bin , Offset: 000007800000 , filesize: 1572864 bytes
Done writing partition. Write speed: 1962,94 KB/s
Partition name: modemst2
Filename: modemst2.bin , Offset: 000007980000 , filesize: 1572864 bytes
Done writing partition. Write speed: 1969,79 KB/s
Partition name: mcfg
Filename: mcfg.bin , Offset: 000007B00000 , filesize: 4194304 bytes
Done writing partition. Write speed: 1947,44 KB/s
Partition name: fsc
Filename: fsc.bin , Offset: 000007F00000 , filesize: 524288 bytes
Done writing partition. Write speed: 1903,52 KB/s
Partition name: ssd
Filename: ssd.bin , Offset: 000007F80000 , filesize: 524288 bytes
Done writing partition. Write speed: 1913,95 KB/s
Partition name: fsg
Filename: fsg.bin , Offset: 000008000000 , filesize: 1572864 bytes
Done writing partition. Write speed: 1939,90 KB/s
Partition name: spare4
Filename: spare4.bin , Offset: 000008180000 , filesize: 6815744 bytes
Done writing partition. Write speed: 1978,35 KB/s
Partition name: dsp
Filename: dsp.bin , Offset: 000008800000 , filesize: 16777216 bytes
Done writing partition. Write speed: 1978,49 KB/s
Partition name: ftm
Filename: ftm.bin , Offset: 000009800000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1974,71 KB/s
Partition name: misc
Filename: misc.bin , Offset: 00000A000000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1966,09 KB/s
Partition name: drm
Filename: drm.bin , Offset: 00000A800000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1979,94 KB/s
Partition name: sns
Filename: sns.bin , Offset: 00000B000000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1982,21 KB/s
Partition name: fota
Filename: fota.bin , Offset: 00000B800000 , filesize: 10485760 bytes
Done writing partition. Write speed: 1973,87 KB/s
Partition name: sec
Filename: sec.bin , Offset: 00000C200000 , filesize: 524288 bytes
Done writing partition. Write speed: 1867,06 KB/s
Partition name: keystore
Filename: keystore.bin , Offset: 00000C280000 , filesize: 524288 bytes
Done writing partition. Write speed: 1889,75 KB/s
Partition name: rct
Filename: rct.bin , Offset: 00000C300000 , filesize: 524288 bytes
Done writing partition. Write speed: 1920,22 KB/s
Partition name: encrypt
Filename: encrypt.bin , Offset: 00000C380000 , filesize: 524288 bytes
Done writing partition. Write speed: 1925,05 KB/s
Partition name: eksst
Filename: eksst.bin , Offset: 00000C400000 , filesize: 524288 bytes
Done writing partition. Write speed: 1916,81 KB/s
Partition name: apdp
Filename: apdp.bin , Offset: 00000C480000 , filesize: 524288 bytes
Done writing partition. Write speed: 1921,70 KB/s
Partition name: msadp
Filename: msadp.bin , Offset: 00000C500000 , filesize: 524288 bytes
Done writing partition. Write speed: 1892,86 KB/s
Partition name: dpo
Filename: dpo.bin , Offset: 00000C580000 , filesize: 524288 bytes
Done writing partition. Write speed: 1884,98 KB/s
Partition name: DDR
Filename: DDR.bin , Offset: 00000C600000 , filesize: 524288 bytes
Done writing partition. Write speed: 1892,19 KB/s
Partition name: spare5
Filename: spare5.bin , Offset: 00000C680000 , filesize: 1572864 bytes
Done writing partition. Write speed: 1963,90 KB/s
Partition name: boot
Filename: boot.bin , Offset: 00000C800000 , filesize: 33554432 bytes
Done writing partition. Write speed: 1975,41 KB/s
Partition name: laf
Filename: laf.bin , Offset: 00000E800000 , filesize: 33554432 bytes
Done writing partition. Write speed: 1976,55 KB/s
Partition name: lafbak
Filename: lafbak.bin , Offset: 000010800000 , filesize: 33554432 bytes
Done writing partition. Write speed: 1977,43 KB/s
Partition name: recovery
Filename: recovery.bin , Offset: 000012800000 , filesize: 33554432 bytes
Done writing partition. Write speed: 1971,95 KB/s
Partition name: recoverybak
Filename: recoverybak.bin , Offset: 000014800000 , filesize: 33554432 bytes
Done writing partition. Write speed: 1981,84 KB/s
Partition name: factory
Filename: factory.bin , Offset: 000016800000 , filesize: 58720256 bytes
Done writing partition. Write speed: 1971,73 KB/s
Partition name: raw_resources
Filename: raw_resources.bin , Offset: 00001A000000 , filesize: 4194304 bytes
Done writing partition. Write speed: 1971,21 KB/s
Partition name: raw_resourcesbak
Filename: raw_resourcesbak.bin , Offset: 00001A400000 , filesize: 4194304 bytes
Done writing partition. Write speed: 1973,11 KB/s
Filename: persist.bin , Offset: 00001A800000 , filesize: 33554432 bytes
Done writing partition. Write speed: 1981,11 KB/s
Partition name: mpt
Filename: mpt.bin , Offset: 00001C800000 , filesize: 33554432 bytes
Done writing partition. Write speed: 1982,88 KB/s
Partition name: srtc
Filename: srtc.bin , Offset: 00001E800000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1977,93 KB/s
Partition name: system
Filename: system.bin , Offset: 00001F000000 , filesize: 5368709120 bytes
Done writing partition. Write speed: 1981,42 KB/s
Partition name: cache
Filename: cache.bin , Offset: 00015F000000 , filesize: 536870912 bytes
Done writing partition. Write speed: 1980,97 KB/s
Partition name: OP
Filename: OP.bin , Offset: 00017F000000 , filesize: 117440512 bytes
Done writing partition. Write speed: 1980,86 KB/s
Partition name: userdata
Filename: userdata.bin , Offset: 000186000000 , filesize: 55993940992 bytes
Done writing partition. Write speed: 1966,35 KB/s
Partition name: grow
Filename: grow.bin , Offset: 000E8F7FBC00 , filesize: 512 bytes
Done writing partition. Write speed: 29,04 KB/s
Operation: Writing BootConfig ...
Reg: 179  Value: 0x38
Reg: 177  Value: 0x00
Reg: 162  Value: 0x01
Done
All done   time: [09:10:35:231]
Old 10-15-2019, 22:17   #14 (permalink)
Member: 1789551
Thanks Meter: 90
How to restore userdata with Easy jtag?
I made a full backup of all partitions and after repairing emmc I returned the full backup. more when turning on the phone appears error that the data is corrupted that it needs to restore the same.
HiPower mode is ON
CMD Pullup Level: 587 mV
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1258 , Response: Not Clean
Backup saved: HCG8a4_2986DA72_20191015_180858.extcsd
Operation: File Explorer...
Scan from: HCG8a4
Vendor: Qualcomm
Searching GPT ...
Scan done
Mount [modem] successfully   PartType: FAT16
Mount [dsp] successfully   PartType: LINUX
Mount [persist-lg] successfully   PartType: LINUX
Mount [sns] successfully   PartType: LINUX
Mount [persist] successfully   PartType: LINUX
Mount [mpt] successfully   PartType: LINUX
Mount [srtc] successfully   PartType: LINUX
Mount [system] successfully   PartType: LINUX
Mount [cache] successfully   PartType: LINUX
Mount [OP] successfully   PartType: LINUX
Mount [data] SKIPPED   PartType: Full Disk Encryption
Brand = lge
Manufacturer = LGE
Device = mh
Model = LG-M700
Page generated in 0.36585 seconds with 8 queries
