01-12-2020, 07:38 | #17 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:3083 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E03C720EAB6B584 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 11/2018 Rev.0x3 eMMC NAME: hB8aP> , S/N: 3340823222 eMMC NAME (HEX): 68423861503E Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line! Done. |
The Following User Says Thank You to pintu_das For This Useful Post: |
01-12-2020, 10:10 | #19 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Check you wires connection | |
The Following User Says Thank You to layder For This Useful Post: |
01-12-2020, 17:32 | #20 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | cant connect j110h HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1742 mV CMD Active Level: 1804 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error |
06-10-2020, 08:47 | #22 (permalink) | |
Try to use Hipower CLK, try to add 2 resistors to CMD/Dat_0 to adapter as at z3x pinout pictures | |
11-25-2020, 17:36 | #24 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 4 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 2099 mV CMD Active Level: 2294 mV Can't init device. Reason: DATA RCV Timeout Error |
05-29-2021, 20:10 | #25 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | Mr Layder Help me i have now reached this stage with A8 2018 SM-A530F Dual sim The error is "Partition info not found" Z3X EasyJtag Software ver. 3.7.0.23 Loading eMMC GEN2 Firmware... IO: 2200 mV Box S/N: 447541118F10xxxx, ,FW Ver.: 02.53 CMD Pullup Level:465 mV CMD Active Level:1375 mV Box IO Level:2200 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100424A54443452000684ECE174xx eMMC CSD : 902701320F5903FFF6DB7FE08A4040xx eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2017 Rev.0x0 eMMC NAME: BJTD4R , S/N: 109374689 eMMC NAME (HEX): 424A54443452 IC Name: Samsung , KLMBG2JETD-B041/32GB @FBGA169 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC RPMB is not yet programmed (clear) or NO Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: BJTD4R_ 109374689_20210529_2103.extcsd Partition info not found Done. May you explain how to go about from here |
06-01-2021, 11:08 | #26 (permalink) | |
you flash ic may be dead - rom2-3-rpmb size is zero | |
11-30-2021, 18:45 | #27 (permalink) | |
Junior Member Join Date: Aug 2006 Location: EGYPT Age: 43
Member: 340450 Status: Offline Thanks Meter: 4 | same in a21s with kg broken Quote:
ism sure that that my emmc got partitions but it is some how not detected on easy jtag maybe iam not sure but maybe the reason is that kg became stored in lster verisions (bit6,7) in emcp unlike b4 it was just in rpmb ..so while it is locked or disable /broken jtag becomes disabled off the emmc any way here is my logs wiring is 100 pct tested and granted 7 pins cmd clk d0 rst 1.8 2.8 gnd ************* Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting Frequence to 36 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 2055 mV CMD Active Level: 2224 mV Setting HS Timing to Enabled Warning: Failed to set BusWidth. Check eMMC connection EMMC Device Information : EMMC CID: 1501004448364441420030C6D098C719 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D Manufacturer: SAMSUNG , NAME: DH6DAB , HEX: 444836444142 , S/N: 30C6D098 , Rev: 00 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (0x000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (0x000000400000) EMMC RPMB Capacity: 16384 KB (0x000001000000) , Counter: 0 , Response: Maybe not Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x01 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 EMMC Init completed Extcsd backup saved: DH6DAB_30C6D098_20211130_031924.extcsd (old backup) Connected successfully Operation: Scan PartitionTable from Source (Vendor: Samsung) Scanning soft partitions from ROM2 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #3 Canceled | |
12-12-2021, 09:39 | #28 (permalink) | |
Member: 340450 Status: Offline Thanks Meter: 4 | Quote:
