Old 12-29-2020, 13:11   #1 (permalink)
Member: 993718
Thanks Meter: 91
Can't init EMMC, Reason: DATA RCV Timeout Error
this error comes when i work with Samsung mobiles
other brand oppo vivo mi working good
please tell me some solution
Z3X EasyJtag Software ver. 3.7.0.20
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: 8C30F9F3F3B1121F, ,FW Ver.: 02.53
CMD Pullup Level:1804 mV
CMD Active Level:1826 mV
Box IO Level:1800 mV
CLK Rate:12000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 15010051333133424200B5FBB8842497
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 02/2017 Rev.0x0
eMMC NAME: Q313BB , S/N: 3053172868
eMMC NAME (HEX): 513331334242
Check Data Line!
Done.
Can't init device, Reason: Initialization failed
Done.
Loading eMMC GEN2 Firmware... IO: 2800 mV
CMD Pullup Level:1818 mV
CMD Active Level:2119 mV
Box IO Level:2800 mV
CLK Rate:12000 kHz
Bus Width:1bit,SDR
Can't init device, Reason: CMD Timeout Error
Done.
Thank You
Old 12-29-2020, 17:41   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
CLK Rate:12000 kHz
Bus Width:1bit,SDR
Check Data Line!
Done.
Done.
Thank You
Check you connection
Try to use pull-up resistors
The Following User Says Thank You to layder For This Useful Post:
Old 12-30-2020, 06:40   #3 (permalink)
Member: 993718
Thanks Meter: 91
all connection is ok
i have attached two 100 Oms pull-up resistors 1.8v to cmd and data
Old 12-30-2020, 06:50   #4 (permalink)
Crazy Poster
Member: 2577517
Sonork: 100.1681425
Thanks Meter: 16
Try connect witout vcc and vccq connection, select hipower mode and connect usb power cable to phone
The Following 2 Users Say Thank You to movilexpert For This Useful Post:
Old 12-30-2020, 07:02   #5 (permalink)
Member: 993718
Thanks Meter: 91
i tryed but same issue
Old 01-02-2021, 14:43   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Try to use didderent VIO.
If ISP not work correctly - desolder chips and use sockets
https://forum.gsmhosting.com/vbb/f67.../#post14298347
Page generated in 0.17640 seconds with 9 queries
