06-05-2020, 05:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | card reader is not detected said please check ccid driver software will be close error code -9102. in my card activated samsung tool pro and can be open working fine. i use windows 10 and already enable test mode in my os |
06-05-2020, 10:16 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
best way - buy new box and replace smart card to it -9102 - it's security error sometime solution is - repair card via shell | |
06-05-2020, 10:29 | #3 (permalink) |
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | thanks sir now i have new box easy jtag plus with icfriend socket i have ufs bga 254 from cph oppo phone with lock code then i remove put at socket but not connected say "cant open link code -56 reason box chip not connected" ufs chip h9hp52adamad i use latest update i m sure ic fine i put it back to phone still alive ask passcode. i test with other socket bga 254 with use u-socket adafter emmc chip can connected here log i get ic reball still Code: Found 2 serial devices COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) COM411 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM411) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 UFS Socket Info. Serial: 012365744E959A11EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 29.02.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. Z3X EasyJtag Software ver. 3.6.2.3 UFS Socket Info. Serial: 012365744E959A11EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 29.02.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Last edited by layder; 06-05-2020 at 11:02. Reason: merge posts |
