07-07-2017, 13:42 | #16 (permalink) |
No Life Poster Join Date: Jan 2006 Location: E a r T h
Member: 216094 Status: Offline Thanks Meter: 321 | |
The Following 2 Users Say Thank You to naushad09 For This Useful Post: |
02-17-2018, 12:10 | #20 (permalink) |
Insane Poster Join Date: Aug 2010
Member: 1363235 Status: Offline Thanks Meter: 6 | EasyJtag Suite Classic ver.: 2.9.0.1 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7600). Admin rights OK FTDI API ver:3.2.4.0 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AA05-F09A , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Setting box Pinout ... Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Compression if OFF Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BBBE1B3E86206853, ,FW Ver.: 02.21 CMD Pullup Level:2114 mV CMD Active Level:2747 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BBBE1B3E86206853, ,FW Ver.: 02.21 CMD Pullup Level:2126 mV CMD Active Level:2745 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BBBE1B3E86206853, ,FW Ver.: 02.21 CMD Pullup Level:2128 mV CMD Active Level:2749 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BBBE1B3E86206853, ,FW Ver.: 02.21 CMD Pullup Level:2127 mV CMD Active Level:2749 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BBBE1B3E86206853, ,FW Ver.: 02.21 CMD Pullup Level:2127 mV CMD Active Level:2747 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BBBE1B3E86206853, ,FW Ver.: 02.21 CMD Pullup Level:2122 mV CMD Active Level:2747 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Compression if OFF Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BBBE1B3E86206853, ,FW Ver.: 02.21 CMD Pullup Level:2126 mV CMD Active Level:2745 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. |
02-21-2018, 13:12 | #23 (permalink) |
Member: 1363235 Status: Offline Thanks Meter: 6 | eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = BBBE1B3E86206853 Card Serial = AA05-F09A EasyJTAG Box Firmware = 2.21 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 832 mV CMD Active Level: 2458 mV EMMC Device Information : EMMC CID: 90014A48384731650507B222F0DF524B EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: B222F0DF , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x40 , Boot from: no boot Boot Bus Config: 0x04 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G1e_B222F0DF_20180221_041122.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version |
