Old 07-10-2020, 08:58   #1 (permalink)
Member: 687836
Thanks Meter: 29
cph1969 dead in oppo reset..help layder
Layder pls help
oppo cph1969 --- dead after reset oppo .... now mtk port ,,
Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used
Device Life Time Estimation (SLC) [268]: 0x00 Not defined
Pre EOL information [267]: 0x01 Normal
slc - not define is it normalll.how can i fix it..lyder pls help
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 12 MHz
CMD Pullup Level: 1810 mV
CMD Active Level: 1846 mV
EMMC Device Information :
EMMC CID: 90014A68444561503303CB16382A36C7
EMMC CSD: D02700328F5903FFFFFFFFEF8E400043
EMMC Manufacture : SKHYNIX , EMMC NAME: hDEaP3 , HEX: 684445615033 , S/N: CB16382A , rev. 0x03
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2019
EMMC ROM 1 (Main User Data) Capacity: 119280 MB (001D1F000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1000 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: hDEaP3_CB16382A_20200710_135818.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB)
Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB)
Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB)
Partition: opporeserve1, [000004188000 - 000004988000], size: 000000800000 (8.00 MB)
Partition: opporeserve2, [000004988000 - 000008988000], size: 000004000000 (64.0 MB)
Partition: opporeserve3, [000008988000 - 00000C988000], size: 000004000000 (64.0 MB)
Partition: oppo_custom, [00000C988000 - 00000CA88000], size: 000000100000 (1.00 MB)
Partition: expdb, [00000CA88000 - 00000DE88000], size: 000001400000 (20.0 MB)
Partition: frp, [00000DE88000 - 00000DF88000], size: 000000100000 (1.00 MB)
Partition: nvcfg, [00000DF88000 - 00000FF88000], size: 000002000000 (32.0 MB)
Partition: nvdata, [00000FF88000 - 000013F88000], size: 000004000000 (64.0 MB)
Partition: metadata, [000013F88000 - 000015F88000], size: 000002000000 (32.0 MB)
Partition: protect1, [000015F88000 - 000016788000], size: 000000800000 (8.00 MB)
Partition: protect2, [000016788000 - 000017000000], size: 000000878000 (8.47 MB)
Partition: seccfg, [000017000000 - 000017800000], size: 000000800000 (8.00 MB)
Partition: persist, [000017800000 - 00001A800000], size: 000003000000 (48.0 MB)
Partition: sec1, [00001A800000 - 00001AA00000], size: 000000200000 (2.00 MB)
Partition: proinfo, [00001AA00000 - 00001AD00000], size: 000000300000 (3.00 MB)
Partition: md1img, [00001AD00000 - 000021100000], size: 000006400000 (100. MB)
Partition: spmfw, [000021100000 - 000021200000], size: 000000100000 (1.00 MB)
Partition: scp1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB)
Partition: scp2, [000021800000 - 000021E00000], size: 000000600000 (6.00 MB)
Partition: sspm_1, [000021E00000 - 000021F00000], size: 000000100000 (1.00 MB)
Partition: sspm_2, [000021F00000 - 000022000000], size: 000000100000 (1.00 MB)
Partition: cam_vpu1, [000022000000 - 000022F00000], size: 000000F00000 (15.0 MB)
Partition: cam_vpu2, [000022F00000 - 000023E00000], size: 000000F00000 (15.0 MB)
Partition: cam_vpu3, [000023E00000 - 000024D00000], size: 000000F00000 (15.0 MB)
Partition: gz1, [000024D00000 - 000025D00000], size: 000001000000 (16.0 MB)
Partition: gz2, [000025D00000 - 000026D00000], size: 000001000000 (16.0 MB)
Partition: nvram, [000026D00000 - 00002AD00000], size: 000004000000 (64.0 MB)
Partition: lk, [00002AD00000 - 00002B200000], size: 000000500000 (5.00 MB)
Partition: lk2, [00002B200000 - 00002B700000], size: 000000500000 (5.00 MB)
Partition: boot, [00002B700000 - 00002D700000], size: 000002000000 (32.0 MB)
Partition: logo, [00002D700000 - 00002E700000], size: 000001000000 (16.0 MB)
Partition: dtbo, [00002E700000 - 00002F700000], size: 000001000000 (16.0 MB)
Partition: tee1, [00002F700000 - 00002FC00000], size: 000000500000 (5.00 MB)
Partition: tee2, [00002FC00000 - 000030800000], size: 000000C00000 (12.0 MB)
Partition: odm, [000030800000 - 000040800000], size: 000010000000 (256. MB)
Partition: vendor, [000040800000 - 000083800000], size: 000043000000 (1.05 GB)
Partition: system, [000083800000 - 0001D0800000], size: 00014D000000 (5.20 GB)
Partition: cache, [0001D0800000 - 0001EB800000], size: 00001B000000 (432. MB)
Partition: userdata, [0001EB800000 - 001D1B4FBE00], size: 001B2FCFBE00 (108. GB)
Partition: otp, [001D1B4FBE00 - 001D1DFFBE00], size: 000002B00000 (43.0 MB)
Partition: flashinfo, [001D1DFFBE00 - 001D1EFFBE00], size: 000001000000 (16.0 MB)
GPT header successfully parsed
Get firmware version
Firmware info not found
Old 07-10-2020, 11:24   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Originally Posted by nafiz8371 View Post
Layder pls help
check cmd/clk resistors for damage
The Following 2 Users Say Thank You to layder For This Useful Post:
Page generated in 0.14644 seconds with 9 queries
