03-10-2021, 13:09 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Custom Binary Blocked By Oem Lock I flashed phone with 4 files also pit but same. flashing complete but no luck. Even after Flashing Combination same. then i decided to do thing with Easy Jtag Plus. i have done these steps. 1-Read dump 2-backup efs 3-erase emmc 4-universal factory format 5-write PIT and BL 6-write efs Then put phone in download mode. and flash 4 files but same. Check Emmc complete logs from easy jtag plus 3/10/2021 11:45:12 AM> Looking for EasyJTAG box... 3/10/2021 11:45:12 AM> EasyJTAG API ver. 3403 3/10/2021 11:45:12 AM> Setting IO Levels to 1.8V 3/10/2021 11:45:12 AM> Setting frequence to 36 MHz 3/10/2021 11:45:12 AM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 11:45:12 AM> EasyJTAG Box Firmware = 2.5301 3/10/2021 11:45:13 AM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 11:45:13 AM> Setting bus width to 1 Bit 3/10/2021 11:45:13 AM> HiPower mode is ON 3/10/2021 11:45:13 AM> Setting frequence to 36 MHz 3/10/2021 11:45:13 AM> CMD Pullup Level: 480 mV 3/10/2021 11:45:13 AM> CMD Active Level: 1188 mV 3/10/2021 11:45:14 AM> eMMC Init returned = 0 3/10/2021 11:45:14 AM> EMMC Device Information : 3/10/2021 11:45:14 AM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 11:45:14 AM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 11:45:14 AM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 11:45:14 AM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 11:45:14 AM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 11:45:14 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 11:45:14 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 11:45:14 AM> EMMC Permanent Write Protection: No 3/10/2021 11:45:14 AM> EMMC Temporary Write Protection: No 3/10/2021 11:45:14 AM> Extended CSD Information : 3/10/2021 11:45:14 AM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 11:45:14 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 11:45:14 AM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 11:45:14 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 11:45:14 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 11:45:14 AM> Device supports partitioning features 3/10/2021 11:45:14 AM> Device can have enhanced technological features in partitions and user data area 3/10/2021 11:45:14 AM> Device can have extended partitions attribute 3/10/2021 11:45:14 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 11:45:14 AM> Backup saved: DG4008_BF323E0D_20210310_114514.extcsd 3/10/2021 11:45:14 AM> EMMC Init completed. 3/10/2021 11:45:14 AM> 3/10/2021 11:45:14 AM> Scanning soft partitions 3/10/2021 11:45:14 AM> GPT header is found and is valid 3/10/2021 11:45:14 AM> Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) 3/10/2021 11:45:14 AM> Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) 3/10/2021 11:45:14 AM> Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) 3/10/2021 11:45:14 AM> Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) 3/10/2021 11:45:14 AM> Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) 3/10/2021 11:45:14 AM> Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) 3/10/2021 11:45:14 AM> Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) 3/10/2021 11:45:14 AM> Partition: NAD_REFER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) 3/10/2021 11:45:14 AM> Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) 3/10/2021 11:45:14 AM> Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) 3/10/2021 11:45:14 AM> Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) 3/10/2021 11:45:14 AM> Partition: RADIO, [000008300000 - 00000DB00000], size: 000005800000 (88.0 MB) 3/10/2021 11:45:14 AM> Partition: PERSISTENT, [00000DB00000 - 00000DB80000], size: 000000080000 (512. KB) 3/10/2021 11:45:14 AM> Partition: STEADY, [00000DB80000 - 00000DF80000], size: 000000400000 (4.00 MB) 3/10/2021 11:45:14 AM> Partition: MISC, [00000DF80000 - 00000E080000], size: 000000100000 (1.00 MB) 3/10/2021 11:45:14 AM> Partition: DTBO, [00000E080000 - 00000E280000], size: 000000200000 (2.00 MB) 3/10/2021 11:45:14 AM> Partition: RESERVED2, [00000E280000 - 00000E800000], size: 000000580000 (5.50 MB) 3/10/2021 11:45:14 AM> Partition: SYSTEM, [00000E800000 - 000062800000], size: 000054000000 (1.31 GB) 3/10/2021 11:45:14 AM> Partition: VENDOR, [000062800000 - 00006D800000], size: 00000B000000 (176. MB) 3/10/2021 11:45:14 AM> Partition: ODM, [00006D800000 - 000070800000], size: 000003000000 (48.0 MB) 3/10/2021 11:45:14 AM> Partition: CACHE, [000070800000 - 000073000000], size: 000002800000 (40.0 MB) 3/10/2021 11:45:14 AM> Partition: HIDDEN, [000073000000 - 000074100000], size: 000001100000 (17.0 MB) 3/10/2021 11:45:14 AM> Partition: OMR, [000074100000 - 000075900000], size: 000001800000 (24.0 MB) 3/10/2021 11:45:14 AM> Partition: CP_DEBUG, [000075900000 - 000075E00000], size: 000000500000 (5.00 MB) 3/10/2021 11:45:15 AM> Partition: NAD_FW, [000075E00000 - 000077200000], size: 000001400000 (20.0 MB) 3/10/2021 11:45:15 AM> Partition: USERDATA, [000077200000 - 0001D1A00000], size: 00015A800000 (5.41 GB) 3/10/2021 11:45:15 AM> GPT header successfully parsed 3/10/2021 11:45:15 AM> 3/10/2021 11:45:15 AM> Get firmware version 3/10/2021 11:45:15 AM> 3/10/2021 11:45:16 AM> Brand = samsung 3/10/2021 11:45:16 AM> Manufacturer = samsung 3/10/2021 11:45:16 AM> Device = a2corelte 3/10/2021 11:45:16 AM> Model = SM-A260F 3/10/2021 11:45:16 AM> CPU Abi = armeabi-v7a 3/10/2021 11:45:16 AM> Android release = 8.1.0 3/10/2021 11:45:16 AM> Security Patch = 2020-12-01 3/10/2021 11:45:16 AM> Firmware version = OPR6.A260FXXS8ATK1 3/10/2021 11:45:16 AM> Firmware date = Wed Nov 18 06:26:45 KST 2020 3/10/2021 11:46:28 AM> 3/10/2021 11:46:28 AM> Looking for EasyJTAG box... 3/10/2021 11:46:28 AM> EasyJTAG API ver. 3403 3/10/2021 11:46:28 AM> Setting IO Levels to 1.8V 3/10/2021 11:46:28 AM> Setting frequence to 36 MHz 3/10/2021 11:46:28 AM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 11:46:28 AM> EasyJTAG Box Firmware = 2.5301 3/10/2021 11:46:29 AM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 11:46:29 AM> Setting bus width to 1 Bit 3/10/2021 11:46:29 AM> HiPower mode is ON 3/10/2021 11:46:29 AM> Setting frequence to 36 MHz 3/10/2021 11:46:29 AM> CMD Pullup Level: 483 mV 3/10/2021 11:46:29 AM> CMD Active Level: 1187 mV 3/10/2021 11:46:29 AM> eMMC Init returned = 0 3/10/2021 11:46:29 AM> EMMC Device Information : 3/10/2021 11:46:29 AM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 11:46:29 AM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 11:46:29 AM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 11:46:29 AM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 11:46:29 AM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 11:46:30 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 11:46:30 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 11:46:30 AM> EMMC Permanent Write Protection: No 3/10/2021 11:46:30 AM> EMMC Temporary Write Protection: No 3/10/2021 11:46:30 AM> Extended CSD Information : 3/10/2021 11:46:30 AM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 11:46:30 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 11:46:30 AM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 11:46:30 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 11:46:30 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 11:46:30 AM> Device supports partitioning features 3/10/2021 11:46:30 AM> Device can have enhanced technological features in partitions and user data area 3/10/2021 11:46:30 AM> Device can have extended partitions attribute 3/10/2021 11:46:30 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 11:46:30 AM> Backup saved: DG4008_BF323E0D_20210310_114630.extcsd 3/10/2021 11:46:30 AM> EMMC Init completed. 3/10/2021 11:46:30 AM> 3/10/2021 11:46:30 AM> Operation: Reading from eMMC... 3/10/2021 11:46:30 AM> 3/10/2021 11:46:40 AM> Reading from: ROM1 , start: 0x000000000000 , size: 0x0001D2000000 3/10/2021 11:46:40 AM> Output file: H:\pati son\EMMC_DG4008_ROM1_000000000000_0001D2000000.bin 3/10/2021 11:46:40 AM> eMMC switching to ROM1 3/10/2021 11:46:40 AM> Reading partition... 3/10/2021 12:12:10 PM> Error reading at address: 00018E3C0000 , error: -2, CMD CRC Error ... Retry #1 3/10/2021 12:12:11 PM> Error result: -2 3/10/2021 12:16:31 PM> Done reading partition. Read speed: 4263.66 Kb/s 3/10/2021 12:16:31 PM> 3/10/2021 12:16:33 PM> All done time: [00:29:52:582] 3/10/2021 12:16:33 PM> 3/10/2021 12:16:40 PM> Looking for EasyJTAG box... 3/10/2021 12:16:40 PM> EasyJTAG API ver. 3403 3/10/2021 12:16:40 PM> Setting IO Levels to 1.8V 3/10/2021 12:16:40 PM> Setting frequence to 36 MHz 3/10/2021 12:16:40 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:16:40 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:16:41 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:16:41 PM> Setting bus width to 1 Bit 3/10/2021 12:16:41 PM> HiPower mode is ON 3/10/2021 12:16:41 PM> Setting frequence to 36 MHz 3/10/2021 12:16:41 PM> CMD Pullup Level: 482 mV 3/10/2021 12:16:41 PM> CMD Active Level: 1184 mV 3/10/2021 12:16:42 PM> eMMC Init returned = 0 3/10/2021 12:16:42 PM> EMMC Device Information : 3/10/2021 12:16:42 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:16:42 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:16:42 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:16:42 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:16:42 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:16:42 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:16:42 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:16:42 PM> EMMC Permanent Write Protection: No 3/10/2021 12:16:42 PM> EMMC Temporary Write Protection: No 3/10/2021 12:16:42 PM> Extended CSD Information : 3/10/2021 12:16:42 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:16:42 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:16:42 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:16:42 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:16:42 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:16:42 PM> Device supports partitioning features 3/10/2021 12:16:42 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:16:42 PM> Device can have extended partitions attribute 3/10/2021 12:16:42 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:16:42 PM> Backup saved: DG4008_BF323E0D_20210310_121642.extcsd 3/10/2021 12:16:42 PM> EMMC Init completed. 3/10/2021 12:16:42 PM> 3/10/2021 12:16:42 PM> Operation: Reading from eMMC... 3/10/2021 12:16:42 PM> 3/10/2021 12:16:44 PM> Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 3/10/2021 12:16:44 PM> Output file: H:\pati son\EMMC_DG4008_ROM2_000000000000_000000400000.bin 3/10/2021 12:16:44 PM> eMMC switching to ROM2 3/10/2021 12:16:45 PM> Reading partition... 3/10/2021 12:16:46 PM> Done reading partition. Read speed: 2918.91 Kb/s 3/10/2021 12:16:46 PM> 3/10/2021 12:16:48 PM> All done time: [00:00:03:290] 3/10/2021 12:16:48 PM> 3/10/2021 12:16:53 PM> Looking for EasyJTAG box... 3/10/2021 12:16:53 PM> EasyJTAG API ver. 3403 3/10/2021 12:16:53 PM> Setting IO Levels to 1.8V 3/10/2021 12:16:53 PM> Setting frequence to 36 MHz 3/10/2021 12:16:53 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:16:53 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:16:54 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:16:54 PM> Setting bus width to 1 Bit 3/10/2021 12:16:54 PM> HiPower mode is ON 3/10/2021 12:16:54 PM> Setting frequence to 36 MHz 3/10/2021 12:16:54 PM> CMD Pullup Level: 482 mV 3/10/2021 12:16:54 PM> CMD Active Level: 1185 mV 3/10/2021 12:16:54 PM> eMMC Init returned = 0 3/10/2021 12:16:55 PM> EMMC Device Information : 3/10/2021 12:16:55 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:16:55 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:16:55 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:16:55 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:16:55 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:16:55 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:16:55 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:16:55 PM> EMMC Permanent Write Protection: No 3/10/2021 12:16:55 PM> EMMC Temporary Write Protection: No 3/10/2021 12:16:55 PM> Extended CSD Information : 3/10/2021 12:16:55 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:16:55 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:16:55 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:16:55 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:16:55 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:16:55 PM> Device supports partitioning features 3/10/2021 12:16:55 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:16:55 PM> Device can have extended partitions attribute 3/10/2021 12:16:55 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:16:55 PM> Backup saved: DG4008_BF323E0D_20210310_121655.extcsd 3/10/2021 12:16:55 PM> EMMC Init completed. 3/10/2021 12:16:55 PM> 3/10/2021 12:16:55 PM> Operation: Reading from eMMC... 3/10/2021 12:16:55 PM> 3/10/2021 12:16:57 PM> Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 3/10/2021 12:16:57 PM> Output file: H:\pati son\EMMC_DG4008_ROM3_000000000000_000000400000.bin 3/10/2021 12:16:57 PM> eMMC switching to ROM3 3/10/2021 12:16:57 PM> Reading partition... 3/10/2021 12:16:58 PM> Done reading partition. Read speed: 2985.93 Kb/s 3/10/2021 12:16:58 PM> 3/10/2021 12:17:00 PM> All done time: [00:00:03:224] 3/10/2021 12:17:00 PM> 3/10/2021 12:17:03 PM> Looking for EasyJTAG box... 3/10/2021 12:17:03 PM> EasyJTAG API ver. 3403 3/10/2021 12:17:03 PM> Setting IO Levels to 1.8V 3/10/2021 12:17:03 PM> Setting frequence to 36 MHz 3/10/2021 12:17:03 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:17:03 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:17:05 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:17:05 PM> Setting bus width to 1 Bit 3/10/2021 12:17:05 PM> HiPower mode is ON 3/10/2021 12:17:05 PM> Setting frequence to 36 MHz 3/10/2021 12:17:05 PM> CMD Pullup Level: 480 mV 3/10/2021 12:17:05 PM> CMD Active Level: 1184 mV 3/10/2021 12:17:05 PM> eMMC Init returned = 0 3/10/2021 12:17:05 PM> EMMC Device Information : 3/10/2021 12:17:05 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:17:05 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:17:05 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:17:05 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:17:05 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:17:05 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:17:05 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:17:05 PM> EMMC Permanent Write Protection: No 3/10/2021 12:17:05 PM> EMMC Temporary Write Protection: No 3/10/2021 12:17:05 PM> Extended CSD Information : 3/10/2021 12:17:05 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:17:05 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:17:05 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:17:05 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:17:05 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:17:05 PM> Device supports partitioning features 3/10/2021 12:17:05 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:17:05 PM> Device can have extended partitions attribute 3/10/2021 12:17:05 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:17:05 PM> Backup saved: DG4008_BF323E0D_20210310_121705.extcsd 3/10/2021 12:17:05 PM> EMMC Init completed. 3/10/2021 12:17:05 PM> 3/10/2021 12:17:06 PM> Operation: Find table from emmc 3/10/2021 12:17:06 PM> 3/10/2021 12:17:06 PM> Vendor: Qualcomm 3/10/2021 12:17:06 PM> Searching GPT ... 3/10/2021 12:17:06 PM> GPT header is found and is valid 3/10/2021 12:17:06 PM> Checking for ROM2 ... 3/10/2021 12:17:06 PM> ROM2 is not blank 3/10/2021 12:17:06 PM> Checking for ROM3 ... 3/10/2021 12:17:07 PM> ROM3 is not blank 3/10/2021 12:17:07 PM> GPT header successfully parsed 3/10/2021 12:17:07 PM> 3/10/2021 12:17:23 PM> Operation: Read by vendor... 3/10/2021 12:17:23 PM> Destination dir: H:\pati son\ 3/10/2021 12:17:23 PM> 3/10/2021 12:17:23 PM> Looking for EasyJTAG box... 3/10/2021 12:17:23 PM> EasyJTAG API ver. 3403 3/10/2021 12:17:23 PM> Setting IO Levels to 1.8V 3/10/2021 12:17:23 PM> Setting frequence to 36 MHz 3/10/2021 12:17:23 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:17:23 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:17:25 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:17:25 PM> Setting bus width to 1 Bit 3/10/2021 12:17:25 PM> HiPower mode is ON 3/10/2021 12:17:25 PM> Setting frequence to 36 MHz 3/10/2021 12:17:25 PM> CMD Pullup Level: 483 mV 3/10/2021 12:17:25 PM> CMD Active Level: 1185 mV 3/10/2021 12:17:25 PM> eMMC Init returned = 0 3/10/2021 12:17:25 PM> EMMC Device Information : 3/10/2021 12:17:25 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:17:25 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:17:25 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:17:25 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:17:25 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:17:25 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:17:25 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:17:25 PM> EMMC Permanent Write Protection: No 3/10/2021 12:17:25 PM> EMMC Temporary Write Protection: No 3/10/2021 12:17:25 PM> Extended CSD Information : 3/10/2021 12:17:25 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:17:25 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:17:25 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:17:25 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:17:25 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:17:25 PM> Device supports partitioning features 3/10/2021 12:17:25 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:17:25 PM> Device can have extended partitions attribute 3/10/2021 12:17:25 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:17:25 PM> Backup saved: DG4008_BF323E0D_20210310_121725.extcsd 3/10/2021 12:17:25 PM> EMMC Init completed. 3/10/2021 12:17:25 PM> 3/10/2021 12:17:27 PM> Backup partition: 8xxx_msimage 3/10/2021 12:17:27 PM> Address: 000000004400, size: 0000003FBC00 3/10/2021 12:17:27 PM> eMMC switching to ROM1 3/10/2021 12:17:27 PM> Reading partition... 3/10/2021 12:17:28 PM> Done reading partition. Read speed: 4202.24 Kb/s 3/10/2021 12:17:28 PM> 3/10/2021 12:17:28 PM> XML-file created successfully 3/10/2021 12:17:28 PM> 3/10/2021 12:17:28 PM> Backup partition: PrimaryGPT 3/10/2021 12:17:28 PM> Address: 000000000000, size: 000000004400 3/10/2021 12:17:28 PM> GPTHeader is valid 3/10/2021 12:17:28 PM> 3/10/2021 12:17:28 PM> Partition name: EFS 3/10/2021 12:17:28 PM> Address: 000000C00000, size: 000001400000 3/10/2021 12:17:28 PM> eMMC switching to ROM1 3/10/2021 12:17:29 PM> Reading partition... 3/10/2021 12:17:33 PM> Done reading partition. Read speed: 4251.40 Kb/s 3/10/2021 12:17:33 PM> 3/10/2021 12:17:33 PM> All done time: [00:00:10:516] 3/10/2021 12:17:33 PM> 3/10/2021 12:18:21 PM> Looking for EasyJTAG box... 3/10/2021 12:18:21 PM> EasyJTAG API ver. 3403 3/10/2021 12:18:21 PM> Setting IO Levels to 1.8V 3/10/2021 12:18:21 PM> Setting frequence to 36 MHz 3/10/2021 12:18:21 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:18:21 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:18:22 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:18:22 PM> Setting bus width to 1 Bit 3/10/2021 12:18:22 PM> HiPower mode is ON 3/10/2021 12:18:22 PM> Setting frequence to 36 MHz 3/10/2021 12:18:22 PM> CMD Pullup Level: 483 mV 3/10/2021 12:18:22 PM> CMD Active Level: 1184 mV 3/10/2021 12:18:23 PM> eMMC Init returned = 0 3/10/2021 12:18:23 PM> EMMC Device Information : 3/10/2021 12:18:23 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:18:23 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:18:23 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:18:23 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:18:23 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:18:23 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:18:23 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:18:23 PM> EMMC Permanent Write Protection: No 3/10/2021 12:18:23 PM> EMMC Temporary Write Protection: No 3/10/2021 12:18:23 PM> Extended CSD Information : 3/10/2021 12:18:23 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:18:23 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:18:23 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:18:23 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:18:23 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:18:23 PM> Device supports partitioning features 3/10/2021 12:18:23 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:18:23 PM> Device can have extended partitions attribute 3/10/2021 12:18:23 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:18:23 PM> Backup saved: DG4008_BF323E0D_20210310_121823.extcsd 3/10/2021 12:18:23 PM> EMMC Init completed. 3/10/2021 12:18:23 PM> 3/10/2021 12:18:23 PM> This operation is only performed for the Samsung eMMC 3/10/2021 12:18:23 PM> 3/10/2021 12:18:29 PM> Looking for EasyJTAG box... 3/10/2021 12:18:29 PM> EasyJTAG API ver. 3403 3/10/2021 12:18:29 PM> Setting IO Levels to 1.8V 3/10/2021 12:18:29 PM> Setting frequence to 36 MHz 3/10/2021 12:18:29 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:18:29 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:18:31 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:18:31 PM> Setting bus width to 1 Bit 3/10/2021 12:18:31 PM> HiPower mode is ON 3/10/2021 12:18:31 PM> Setting frequence to 36 MHz 3/10/2021 12:18:31 PM> CMD Pullup Level: 482 mV 3/10/2021 12:18:31 PM> CMD Active Level: 1184 mV 3/10/2021 12:18:31 PM> eMMC Init returned = 0 3/10/2021 12:18:31 PM> EMMC Device Information : 3/10/2021 12:18:31 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:18:31 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:18:31 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:18:31 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:18:31 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:18:31 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:18:31 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:18:31 PM> EMMC Permanent Write Protection: No 3/10/2021 12:18:31 PM> EMMC Temporary Write Protection: No 3/10/2021 12:18:31 PM> Extended CSD Information : 3/10/2021 12:18:31 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:18:31 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:18:31 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:18:31 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:18:31 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:18:31 PM> Device supports partitioning features 3/10/2021 12:18:31 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:18:31 PM> Device can have extended partitions attribute 3/10/2021 12:18:31 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:18:31 PM> Backup saved: DG4008_BF323E0D_20210310_121831.extcsd 3/10/2021 12:18:31 PM> EMMC Init completed. 3/10/2021 12:18:31 PM> 3/10/2021 12:18:32 PM> Operation: Erasing eMMC... 3/10/2021 12:18:32 PM> 3/10/2021 12:18:32 PM> Erasing for: ROM3 , start: 0x000000000000 , size: 0x000000400000 3/10/2021 12:18:32 PM> eMMC switching to ROM3 3/10/2021 12:18:32 PM> Erasing partition... 3/10/2021 12:18:36 PM> Done erasing partition. 3/10/2021 12:18:36 PM> 3/10/2021 12:18:42 PM> Looking for EasyJTAG box... 3/10/2021 12:18:42 PM> EasyJTAG API ver. 3403 3/10/2021 12:18:42 PM> Setting IO Levels to 1.8V 3/10/2021 12:18:42 PM> Setting frequence to 36 MHz 3/10/2021 12:18:42 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:18:42 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:18:44 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:18:44 PM> Setting bus width to 1 Bit 3/10/2021 12:18:44 PM> HiPower mode is ON 3/10/2021 12:18:44 PM> Setting frequence to 36 MHz 3/10/2021 12:18:44 PM> CMD Pullup Level: 480 mV 3/10/2021 12:18:44 PM> CMD Active Level: 1186 mV 3/10/2021 12:18:44 PM> eMMC Init returned = 0 3/10/2021 12:18:44 PM> EMMC Device Information : 3/10/2021 12:18:44 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:18:44 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:18:44 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:18:44 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:18:44 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:18:44 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:18:44 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:18:44 PM> EMMC Permanent Write Protection: No 3/10/2021 12:18:44 PM> EMMC Temporary Write Protection: No 3/10/2021 12:18:44 PM> Extended CSD Information : 3/10/2021 12:18:44 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:18:44 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:18:44 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:18:45 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:18:45 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:18:45 PM> Device supports partitioning features 3/10/2021 12:18:45 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:18:45 PM> Device can have extended partitions attribute 3/10/2021 12:18:45 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:18:45 PM> Backup saved: DG4008_BF323E0D_20210310_121845.extcsd 3/10/2021 12:18:45 PM> EMMC Init completed. 3/10/2021 12:18:45 PM> 3/10/2021 12:18:45 PM> This operation is only performed for the Samsung eMMC 3/10/2021 12:18:45 PM> 3/10/2021 12:18:46 PM> Looking for EasyJTAG box... 3/10/2021 12:18:46 PM> EasyJTAG API ver. 3403 3/10/2021 12:18:46 PM> Setting IO Levels to 1.8V 3/10/2021 12:18:46 PM> Setting frequence to 36 MHz 3/10/2021 12:18:46 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:18:46 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:18:48 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:18:48 PM> Setting bus width to 1 Bit 3/10/2021 12:18:48 PM> HiPower mode is ON 3/10/2021 12:18:48 PM> Setting frequence to 36 MHz 3/10/2021 12:18:48 PM> CMD Pullup Level: 482 mV 3/10/2021 12:18:48 PM> CMD Active Level: 1186 mV 3/10/2021 12:18:48 PM> eMMC Init returned = 0 3/10/2021 12:18:48 PM> EMMC Device Information : 3/10/2021 12:18:48 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:18:48 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:18:48 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:18:48 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:18:48 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:18:48 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:18:48 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:18:48 PM> EMMC Permanent Write Protection: No 3/10/2021 12:18:48 PM> EMMC Temporary Write Protection: No 3/10/2021 12:18:48 PM> Extended CSD Information : 3/10/2021 12:18:48 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:18:48 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:18:48 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:18:48 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:18:48 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:18:48 PM> Device supports partitioning features 3/10/2021 12:18:48 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:18:49 PM> Device can have extended partitions attribute 3/10/2021 12:18:49 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:18:49 PM> Backup saved: DG4008_BF323E0D_20210310_121849.extcsd 3/10/2021 12:18:49 PM> EMMC Init completed. 3/10/2021 12:18:49 PM> 3/10/2021 12:18:50 PM> Operation: Universal Factory Format 3/10/2021 12:18:50 PM> Please, wait ... 3/10/2021 12:18:51 PM> 3/10/2021 12:18:51 PM> Successfully 3/10/2021 12:18:58 PM> 3/10/2021 12:18:58 PM> Looking for EasyJTAG box... 3/10/2021 12:18:58 PM> EasyJTAG API ver. 3403 3/10/2021 12:18:58 PM> Setting IO Levels to 1.8V 3/10/2021 12:18:58 PM> Setting frequence to 36 MHz 3/10/2021 12:18:58 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:18:58 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:18:59 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:18:59 PM> Setting bus width to 1 Bit 3/10/2021 12:18:59 PM> HiPower mode is ON 3/10/2021 12:18:59 PM> Setting frequence to 36 MHz 3/10/2021 12:18:59 PM> CMD Pullup Level: 483 mV 3/10/2021 12:18:59 PM> CMD Active Level: 1184 mV 3/10/2021 12:19:00 PM> eMMC Init returned = 0 3/10/2021 12:19:00 PM> EMMC Device Information : 3/10/2021 12:19:00 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:19:00 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:19:00 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:19:00 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:19:00 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:19:00 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:19:00 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:19:00 PM> EMMC Permanent Write Protection: No 3/10/2021 12:19:00 PM> EMMC Temporary Write Protection: No 3/10/2021 12:19:00 PM> Extended CSD Information : 3/10/2021 12:19:00 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:19:00 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:19:00 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:19:00 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:19:00 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:19:00 PM> Device supports partitioning features 3/10/2021 12:19:00 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:19:00 PM> Device can have extended partitions attribute 3/10/2021 12:19:00 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:19:00 PM> Backup saved: DG4008_BF323E0D_20210310_121900.extcsd 3/10/2021 12:19:00 PM> EMMC Init completed. 3/10/2021 12:19:00 PM> 3/10/2021 12:19:00 PM> Operation: Reading S.M.A.R.T Report ... 3/10/2021 12:19:00 PM> 3/10/2021 12:19:00 PM> Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used 3/10/2021 12:19:00 PM> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used 3/10/2021 12:19:00 PM> Pre EOL information [267]: 0x01 Normal 3/10/2021 12:19:00 PM> 3/10/2021 12:19:00 PM> Optimal Read Size [266]: 0x08 32 KB 3/10/2021 12:19:00 PM> Optimal Write Size [265]: 0x08 32 KB 3/10/2021 12:19:00 PM> Optimal Trim Unit Size [264]: 0x08 32 KB 3/10/2021 12:19:00 PM> 3/10/2021 12:19:07 PM> Looking for EasyJTAG box... 3/10/2021 12:19:07 PM> EasyJTAG API ver. 3403 3/10/2021 12:19:07 PM> Setting IO Levels to 1.8V 3/10/2021 12:19:07 PM> Setting frequence to 36 MHz 3/10/2021 12:19:07 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:19:07 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:19:08 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:19:08 PM> Setting bus width to 1 Bit 3/10/2021 12:19:08 PM> HiPower mode is ON 3/10/2021 12:19:08 PM> Setting frequence to 36 MHz 3/10/2021 12:19:08 PM> CMD Pullup Level: 480 mV 3/10/2021 12:19:08 PM> CMD Active Level: 1184 mV 3/10/2021 12:19:08 PM> eMMC Init returned = 0 3/10/2021 12:19:08 PM> EMMC Device Information : 3/10/2021 12:19:08 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:19:08 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:19:08 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:19:09 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:19:09 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:19:09 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:19:09 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:19:09 PM> EMMC Permanent Write Protection: No 3/10/2021 12:19:09 PM> EMMC Temporary Write Protection: No 3/10/2021 12:19:09 PM> Extended CSD Information : 3/10/2021 12:19:09 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:19:09 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:19:09 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:19:09 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:19:09 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:19:09 PM> Device supports partitioning features 3/10/2021 12:19:09 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:19:09 PM> Device can have extended partitions attribute 3/10/2021 12:19:09 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:19:09 PM> Backup saved: DG4008_BF323E0D_20210310_121909.extcsd 3/10/2021 12:19:09 PM> EMMC Init completed. 3/10/2021 12:19:09 PM> 3/10/2021 12:19:20 PM> Filename: DG4008_BF323E0D_20210310_121631.extcsd 3/10/2021 12:19:20 PM> 3/10/2021 12:19:20 PM> Operation: Repairing ExtCsd ... 3/10/2021 12:19:39 PM> Successfully 3/10/2021 12:19:39 PM> 3/10/2021 12:20:18 PM> Looking for EasyJTAG box... 3/10/2021 12:20:18 PM> EasyJTAG API ver. 3403 3/10/2021 12:20:18 PM> Setting IO Levels to 1.8V 3/10/2021 12:20:18 PM> Setting frequence to 36 MHz 3/10/2021 12:20:18 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:20:18 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:20:19 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:20:19 PM> Setting bus width to 1 Bit 3/10/2021 12:20:19 PM> HiPower mode is ON 3/10/2021 12:20:19 PM> Setting frequence to 36 MHz 3/10/2021 12:20:19 PM> CMD Pullup Level: 483 mV 3/10/2021 12:20:19 PM> CMD Active Level: 1184 mV 3/10/2021 12:20:20 PM> eMMC Init returned = 0 3/10/2021 12:20:20 PM> EMMC Device Information : 3/10/2021 12:20:20 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:20:20 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:20:20 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:20:20 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:20:20 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:20:20 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:20:20 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:20:20 PM> EMMC Permanent Write Protection: No 3/10/2021 12:20:20 PM> EMMC Temporary Write Protection: No 3/10/2021 12:20:20 PM> Extended CSD Information : 3/10/2021 12:20:20 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:20:20 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:20:20 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:20:20 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:20:20 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:20:20 PM> Device supports partitioning features 3/10/2021 12:20:20 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:20:20 PM> Device can have extended partitions attribute 3/10/2021 12:20:20 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:20:20 PM> Backup saved: DG4008_BF323E0D_20210310_122020.extcsd 3/10/2021 12:20:20 PM> EMMC Init completed. 3/10/2021 12:20:20 PM> 3/10/2021 12:20:20 PM> Opening file: H:\EFT\FTP_File_v2.6\downloads\A260FXXS8ATK1_8.1.0 _4File_Multi CSC (OJM)\New folder\A2CORELTE_MEA_OPEN.pit 3/10/2021 12:20:20 PM> 3/10/2021 12:20:20 PM> Pit: A2CORELTE_MEA_OPEN.pit 3/10/2021 12:20:20 PM> Entry count: 31 3/10/2021 12:20:20 PM> 3/10/2021 12:20:20 PM> The size of the last section has been updated 3/10/2021 12:20:24 PM> Selected file: H:\EFT\FTP_File_v2.6\downloads\A260FXXS8ATK1_8.1.0 _4File_Multi CSC (OJM)\New folder\BL_A260FXXS8ATK1_CL15641782_QB36022482_REV0 0_user_low_ship.tar.md5 3/10/2021 12:20:24 PM> 3/10/2021 12:20:24 PM> BL_A260FXXS8ATK1_CL15641782_QB36022482_REV00_user_ low_ship.tar.md5 3/10/2021 12:20:24 PM> The list of files in the firmware: 3/10/2021 12:20:24 PM> sboot.bin.lz4 3/10/2021 12:20:24 PM> param.bin.lz4 3/10/2021 12:20:24 PM> cm.bin.lz4 3/10/2021 12:20:24 PM> 3/10/2021 12:20:26 PM> Looking for EasyJTAG box... 3/10/2021 12:20:26 PM> EasyJTAG API ver. 3403 3/10/2021 12:20:26 PM> Setting IO Levels to 1.8V 3/10/2021 12:20:26 PM> Setting frequence to 36 MHz 3/10/2021 12:20:26 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:20:26 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:20:28 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:20:28 PM> Setting bus width to 1 Bit 3/10/2021 12:20:28 PM> HiPower mode is ON 3/10/2021 12:20:28 PM> Setting frequence to 36 MHz 3/10/2021 12:20:28 PM> CMD Pullup Level: 482 mV 3/10/2021 12:20:28 PM> CMD Active Level: 1186 mV 3/10/2021 12:20:28 PM> eMMC Init returned = 0 3/10/2021 12:20:28 PM> EMMC Device Information : 3/10/2021 12:20:28 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:20:28 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:20:28 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:20:28 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:20:28 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:20:28 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:20:28 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:20:28 PM> EMMC Permanent Write Protection: No 3/10/2021 12:20:28 PM> EMMC Temporary Write Protection: No 3/10/2021 12:20:28 PM> Extended CSD Information : 3/10/2021 12:20:28 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:20:28 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:20:28 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:20:28 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:20:28 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:20:28 PM> Device supports partitioning features 3/10/2021 12:20:28 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:20:28 PM> Device can have extended partitions attribute 3/10/2021 12:20:28 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:20:28 PM> Backup saved: DG4008_BF323E0D_20210310_122028.extcsd 3/10/2021 12:20:28 PM> EMMC Init completed. 3/10/2021 12:20:28 PM> 3/10/2021 12:20:29 PM> Operation: Write by vendor (Samsung) 3/10/2021 12:20:29 PM> 3/10/2021 12:20:29 PM> Creating GPT-partitioninig 3/10/2021 12:20:29 PM> Writing PrimaryGPT at address: 000000000000 3/10/2021 12:20:29 PM> Writing BackupGPT at address: 0001D1FFBE00 3/10/2021 12:20:29 PM> Writing PIT at address: 000000004400 3/10/2021 12:20:29 PM> GPT-partitioning done 3/10/2021 12:20:29 PM> 3/10/2021 12:20:29 PM> Unpacking file: cm.bin 3/10/2021 12:20:29 PM> Unpacking Lz4: cm.bin.lz4 3/10/2021 12:20:29 PM> Unpacking file: sboot.bin 3/10/2021 12:20:29 PM> Unpacking Lz4: sboot.bin.lz4 3/10/2021 12:20:29 PM> Unpacking file: param.bin 3/10/2021 12:20:29 PM> Unpacking Lz4: param.bin.lz4 3/10/2021 12:20:29 PM> 3/10/2021 12:20:29 PM> Partition name: CM 3/10/2021 12:20:29 PM> Filename: cm.bin , Offset: 000000000000 , filesize: 2445840 bytes 3/10/2021 12:20:29 PM> eMMC switching to ROM3 3/10/2021 12:20:29 PM> Erasing partition... 3/10/2021 12:20:32 PM> Writing partition... 3/10/2021 12:20:34 PM> Error writing at address: 000000255200 , error: -100, CARD Status Error ... Retry #1 3/10/2021 12:20:34 PM> Error writing at address: 000000255200 , error: -100, CARD Status Error ... Retry #2 3/10/2021 12:20:34 PM> Error writing at address: 000000255200 , error: -100, CARD Status Error ... Retry #3 3/10/2021 12:20:34 PM> Too many errors. Writing has been stopped 3/10/2021 12:20:35 PM> 3/10/2021 12:20:41 PM> Looking for EasyJTAG box... 3/10/2021 12:20:41 PM> EasyJTAG API ver. 3403 3/10/2021 12:20:41 PM> Setting IO Levels to 1.8V 3/10/2021 12:20:41 PM> Setting frequence to 18 MHz 3/10/2021 12:20:41 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:20:41 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:20:43 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:20:43 PM> Setting bus width to 1 Bit 3/10/2021 12:20:43 PM> HiPower mode is ON 3/10/2021 12:20:43 PM> Setting frequence to 18 MHz 3/10/2021 12:20:43 PM> CMD Pullup Level: 483 mV 3/10/2021 12:20:43 PM> CMD Active Level: 1186 mV 3/10/2021 12:20:43 PM> eMMC Init returned = 0 3/10/2021 12:20:43 PM> EMMC Device Information : 3/10/2021 12:20:43 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:20:43 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:20:43 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:20:43 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:20:43 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:20:43 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:20:43 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:20:43 PM> EMMC Permanent Write Protection: No 3/10/2021 12:20:43 PM> EMMC Temporary Write Protection: No 3/10/2021 12:20:43 PM> Extended CSD Information : 3/10/2021 12:20:43 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:20:43 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:20:43 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:20:43 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:20:43 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:20:43 PM> Device supports partitioning features 3/10/2021 12:20:43 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:20:43 PM> Device can have extended partitions attribute 3/10/2021 12:20:43 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:20:43 PM> Backup saved: DG4008_BF323E0D_20210310_122043.extcsd 3/10/2021 12:20:43 PM> EMMC Init completed. 3/10/2021 12:20:43 PM> 3/10/2021 12:20:43 PM> Operation: Write by vendor (Samsung) 3/10/2021 12:20:43 PM> 3/10/2021 12:20:43 PM> Creating GPT-partitioninig 3/10/2021 12:20:43 PM> Writing PrimaryGPT at address: 000000000000 3/10/2021 12:20:43 PM> Writing BackupGPT at address: 0001D1FFBE00 3/10/2021 12:20:43 PM> Writing PIT at address: 000000004400 3/10/2021 12:20:44 PM> GPT-partitioning done 3/10/2021 12:20:44 PM> 3/10/2021 12:20:44 PM> Unpacking file: cm.bin 3/10/2021 12:20:44 PM> Unpacking Lz4: cm.bin.lz4 3/10/2021 12:20:44 PM> Unpacking file: sboot.bin 3/10/2021 12:20:44 PM> Unpacking Lz4: sboot.bin.lz4 3/10/2021 12:20:44 PM> Unpacking file: param.bin 3/10/2021 12:20:44 PM> Unpacking Lz4: param.bin.lz4 3/10/2021 12:20:44 PM> 3/10/2021 12:20:44 PM> Partition name: CM 3/10/2021 12:20:44 PM> Filename: cm.bin , Offset: 000000000000 , filesize: 2445840 bytes 3/10/2021 12:20:44 PM> eMMC switching to ROM3 3/10/2021 12:20:44 PM> Erasing partition... 3/10/2021 12:20:49 PM> Writing partition... 3/10/2021 12:20:51 PM> Done writing partition. Write speed: 875.03 KB/s 3/10/2021 12:20:51 PM> Partition name: BOOTLOADER 3/10/2021 12:20:51 PM> Filename: sboot.bin , Offset: 000000000000 , filesize: 1921552 bytes 3/10/2021 12:20:52 PM> eMMC switching to ROM2 3/10/2021 12:20:52 PM> Erasing partition... 3/10/2021 12:20:57 PM> Writing partition... 3/10/2021 12:20:59 PM> Done writing partition. Write speed: 853.68 KB/s 3/10/2021 12:20:59 PM> Partition name: PARAM 3/10/2021 12:20:59 PM> Filename: param.bin , Offset: 000003500000 , filesize: 624640 bytes 3/10/2021 12:20:59 PM> eMMC switching to ROM1 3/10/2021 12:21:00 PM> Erasing partition... 3/10/2021 12:21:01 PM> Writing partition... 3/10/2021 12:21:02 PM> Done writing partition. Write speed: 974.83 KB/s 3/10/2021 12:21:05 PM> 3/10/2021 12:21:05 PM> Partition EFS : formatting as EXT4. Please wait ... 3/10/2021 12:21:06 PM> Formatting completed 3/10/2021 12:21:06 PM> 3/10/2021 12:21:06 PM> Partition CACHE : formatting as EXT4. Please wait ... 3/10/2021 12:21:07 PM> Formatting completed 3/10/2021 12:21:07 PM> Partition HIDDEN : formatting as EXT4. Please wait ... 3/10/2021 12:21:08 PM> Formatting completed 3/10/2021 12:21:09 PM> Partition USERDATA : formatting as EXT4. Please wait ... 3/10/2021 12:21:15 PM> Formatting completed 3/10/2021 12:21:15 PM> 3/10/2021 12:21:15 PM> Check BootConfig for the selected vendor 3/10/2021 12:21:15 PM> 3/10/2021 12:21:15 PM> All done time: [00:00:31:088] 3/10/2021 12:21:15 PM> 3/10/2021 12:21:19 PM> Missing file for partition: EFS 3/10/2021 12:21:38 PM> 3/10/2021 12:21:38 PM> Looking for EasyJTAG box... 3/10/2021 12:21:38 PM> EasyJTAG API ver. 3403 3/10/2021 12:21:38 PM> Setting IO Levels to 1.8V 3/10/2021 12:21:38 PM> Setting frequence to 18 MHz 3/10/2021 12:21:38 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:21:38 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:21:40 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:21:40 PM> Setting bus width to 1 Bit 3/10/2021 12:21:40 PM> HiPower mode is ON 3/10/2021 12:21:40 PM> Setting frequence to 18 MHz 3/10/2021 12:21:40 PM> CMD Pullup Level: 482 mV 3/10/2021 12:21:40 PM> CMD Active Level: 1187 mV 3/10/2021 12:21:40 PM> eMMC Init returned = 0 3/10/2021 12:21:40 PM> EMMC Device Information : 3/10/2021 12:21:40 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:21:40 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:21:40 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:21:40 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:21:40 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:21:40 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:21:40 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:21:40 PM> EMMC Permanent Write Protection: No 3/10/2021 12:21:40 PM> EMMC Temporary Write Protection: No 3/10/2021 12:21:40 PM> Extended CSD Information : 3/10/2021 12:21:40 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:21:40 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:21:40 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:21:40 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:21:40 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:21:40 PM> Device supports partitioning features 3/10/2021 12:21:40 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:21:40 PM> Device can have extended partitions attribute 3/10/2021 12:21:40 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:21:40 PM> Backup saved: DG4008_BF323E0D_20210310_122140.extcsd 3/10/2021 12:21:40 PM> EMMC Init completed. 3/10/2021 12:21:41 PM> 3/10/2021 12:21:41 PM> Operation: Write by vendor (Samsung) 3/10/2021 12:21:41 PM> 3/10/2021 12:21:41 PM> Partition name: EFS 3/10/2021 12:21:41 PM> Filename: EFS.bin , Offset: 000000C00000 , filesize: 20971520 bytes 3/10/2021 12:21:41 PM> eMMC switching to ROM1 3/10/2021 12:21:41 PM> Writing partition... 3/10/2021 12:21:54 PM> Done writing partition. Write speed: 1634.40 KB/s 3/10/2021 12:21:54 PM> 3/10/2021 12:21:54 PM> Check BootConfig for the selected vendor 3/10/2021 12:21:54 PM> 3/10/2021 12:21:54 PM> All done time: [00:00:13:688] 3/10/2021 12:21:54 PM> 3/10/2021 12:21:58 PM> Looking for EasyJTAG box... 3/10/2021 12:21:58 PM> EasyJTAG API ver. 3403 3/10/2021 12:21:58 PM> Setting IO Levels to 1.8V 3/10/2021 12:21:58 PM> Setting frequence to 18 MHz 3/10/2021 12:21:58 PM> EasyJTAG Box Serial = 553E579F73FF53EF 3/10/2021 12:21:58 PM> EasyJTAG Box Firmware = 2.5301 3/10/2021 12:21:59 PM> Setting interface to EasyJtag2/ISP_HiPower 3/10/2021 12:21:59 PM> Setting bus width to 1 Bit 3/10/2021 12:21:59 PM> HiPower mode is ON 3/10/2021 12:21:59 PM> Setting frequence to 18 MHz 3/10/2021 12:21:59 PM> CMD Pullup Level: 483 mV 3/10/2021 12:22:00 PM> CMD Active Level: 1185 mV 3/10/2021 12:22:00 PM> eMMC Init returned = 0 3/10/2021 12:22:00 PM> EMMC Device Information : 3/10/2021 12:22:00 PM> EMMC CID: 45010044473430303801BF323E0D561F 3/10/2021 12:22:00 PM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/10/2021 12:22:00 PM> EMMC Manufacture : SANDISK , EMMC NAME: DG4008 , HEX: 444734303038 , S/N: BF323E0D , rev. 0x01 3/10/2021 12:22:00 PM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 3/10/2021 12:22:00 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 3/10/2021 12:22:00 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/10/2021 12:22:00 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 3/10/2021 12:22:00 PM> EMMC Permanent Write Protection: No 3/10/2021 12:22:00 PM> EMMC Temporary Write Protection: No 3/10/2021 12:22:00 PM> Extended CSD Information : 3/10/2021 12:22:00 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/10/2021 12:22:00 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 3/10/2021 12:22:00 PM> Boot Bus Config: 0x01 , width 4bit 3/10/2021 12:22:00 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 3/10/2021 12:22:00 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/10/2021 12:22:00 PM> Device supports partitioning features 3/10/2021 12:22:00 PM> Device can have enhanced technological features in partitions and user data area 3/10/2021 12:22:00 PM> Device can have extended partitions attribute 3/10/2021 12:22:00 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/10/2021 12:22:00 PM> Backup saved: DG4008_BF323E0D_20210310_122200.extcsd 3/10/2021 12:22:00 PM> EMMC Init completed. 3/10/2021 12:22:00 PM> 3/10/2021 12:22:00 PM> Scanning soft partitions 3/10/2021 12:22:00 PM> GPT header is found and is valid 3/10/2021 12:22:00 PM> Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) 3/10/2021 12:22:00 PM> Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) 3/10/2021 12:22:00 PM> Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) 3/10/2021 12:22:00 PM> Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) 3/10/2021 12:22:00 PM> Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) 3/10/2021 12:22:01 PM> Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) 3/10/2021 12:22:01 PM> Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) 3/10/2021 12:22:01 PM> Partition: NAD_REFER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) 3/10/2021 12:22:01 PM> Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) 3/10/2021 12:22:01 PM> Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) 3/10/2021 12:22:01 PM> Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) 3/10/2021 12:22:01 PM> Partition: RADIO, [000008300000 - 00000DB00000], size: 000005800000 (88.0 MB) 3/10/2021 12:22:01 PM> Partition: PERSISTENT, [00000DB00000 - 00000DB80000], size: 000000080000 (512. KB) 3/10/2021 12:22:01 PM> Partition: STEADY, [00000DB80000 - 00000DF80000], size: 000000400000 (4.00 MB) 3/10/2021 12:22:01 PM> Partition: MISC, [00000DF80000 - 00000E080000], size: 000000100000 (1.00 MB) 3/10/2021 12:22:01 PM> Partition: DTBO, [00000E080000 - 00000E280000], size: 000000200000 (2.00 MB) 3/10/2021 12:22:01 PM> Partition: RESERVED2, [00000E280000 - 00000E800000], size: 000000580000 (5.50 MB) 3/10/2021 12:22:01 PM> Partition: SYSTEM, [00000E800000 - 000062800000], size: 000054000000 (1.31 GB) 3/10/2021 12:22:01 PM> Partition: VENDOR, [000062800000 - 00006D800000], size: 00000B000000 (176. MB) 3/10/2021 12:22:01 PM> Partition: ODM, [00006D800000 - 000070800000], size: 000003000000 (48.0 MB) 3/10/2021 12:22:01 PM> Partition: CACHE, [000070800000 - 000073000000], size: 000002800000 (40.0 MB) 3/10/2021 12:22:01 PM> Partition: HIDDEN, [000073000000 - 000074100000], size: 000001100000 (17.0 MB) 3/10/2021 12:22:01 PM> Partition: OMR, [000074100000 - 000075900000], size: 000001800000 (24.0 MB) 3/10/2021 12:22:01 PM> Partition: CP_DEBUG, [000075900000 - 000075E00000], size: 000000500000 (5.00 MB) 3/10/2021 12:22:01 PM> Partition: NAD_FW, [000075E00000 - 000077200000], size: 000001400000 (20.0 MB) 3/10/2021 12:22:01 PM> Partition: USERDATA, [000077200000 - 0001D1FFBE00], size: 00015ADFBE00 (5.42 GB) 3/10/2021 12:22:01 PM> GPT header successfully parsed 3/10/2021 12:22:01 PM> 3/10/2021 12:22:01 PM> Get firmware version 3/10/2021 12:22:01 PM> 3/10/2021 12:22:02 PM> Firmware info not found |
The Following User Says Thank You to alamgarh For This Useful Post: |
03-20-2021, 06:52 | #5 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
Dear sir i did these steps but still no luck. Universal Factory Format Erase EMMC Repartation EMMC if i have done these steps it means there is no data store . but yes you are right maybe efs because i write efs backup. i want to know is it possible that i can write efs from another phone. but still same. | |
