Old 04-25-2014, 12:47   #1 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
direct eMMC connection failed. pinout wrong?
I need some help to establish a connection to eMMC KMVYLOOOLM-B503.
i soldered directly some wires.
I used this eMMC adapter from Multi-Com.
When i try to connect eMMC via easyJTag i get this screen.
Z3X EasyJtag Software ver. 1.1.0.1
Loading eMMC Addon Firmware...
Box S/N: xxx, ,FW Ver.: 01.49
Warning: CMD Pullup Level (30 mV) too low , check cables etc.!!!
CMD Active Level:216 mV
Can't init EMMC, Reason: CMD Timeout Error
Done.
what i do wrong? i hope somebody can help me.
thx & br
The Following User Says Thank You to huzein For This Useful Post:
Old 04-26-2014, 12:17   #2 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
can please somebody help me?!
Old 04-27-2014, 16:45   #3 (permalink)
Member: 142949
Thanks Meter: 71
l thing adapter gpg not good
The Following User Says Thank You to nguyenhuu For This Useful Post:
Old 04-27-2014, 17:48   #4 (permalink)
Member: 1012390
Thanks Meter: 95
His adaptor is multicom.pl product
The Following User Says Thank You to Hoayeu105 For This Useful Post:
Old 04-27-2014, 17:52   #5 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
with this adapter i could already establish eMMC connection when i soldered to pins on pcb. but also in this way i get very often this error message which i wrote in first post.
something can be wrong with my adapter? too short wires? what this can be?
Old 04-28-2014, 11:44   #6 (permalink)
Member: 1815849
Thanks Meter: 17
you put wrong the adapter
tienes que poner el adaptador al reves
The Following User Says Thank You to a65333002 For This Useful Post:
Old 04-28-2014, 12:15   #7 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
what you mean with this? really a very qualified answer.
Gesendet von meinem GT-I9100 mit Tapatalk
Old 04-28-2014, 12:47   #8 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
oh i see what you mean. shame on me. i will try it this way. thanks for the hint.
Old 04-28-2014, 13:00   #9 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
i have done now as said and now it seems to be good but CMD Timeout Error appeared.
Z3X EasyJtag Software ver. 1.2.0.0
CMD Pullup Level:2650 mV
CMD Active Level:2732 mV
What can be this problem?
br
Old 05-02-2014, 08:19   #10 (permalink)
Member: 257372
I though I/O speed too high , and the quality of the adapter .
Old 05-02-2014, 10:36   #11 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Hi, check if all power domains connected together. I mean if chip have different points for VCC and VCCQ - they must connected together same - VSS points. I can give here photo how they are connected in adapter.
Old 05-02-2014, 11:22   #12 (permalink)
Member: 2085623
Thanks Meter: 221
I got same problem with multi-com.pl adapter emmc direct and i9300 can someone give here solution, my soldering is perfect and got same error like I see there, this is adapter problem or what ??
Old 05-02-2014, 11:22   #13 (permalink)
Member: 2085623
Thanks Meter: 221
sorry for double post
Old 05-03-2014, 22:21   #14 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
please give a photo sir. this would help much i think.
br
Old 05-04-2014, 15:18   #15 (permalink)
Member: 695166
Thanks Meter: 24
same problem
Done.
Z3X EasyJtag Software ver. 1.3.1.0
Loading eMMC Addon Firmware... IO: 1850 mV
Box S/N: xxxxxxxxxxxxxxx, ,FW Ver.: 01.49
Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!!
CMD Active Level:1619 mV
Done.
Page generated in 0.19923 seconds with 10 queries
