05-12-2015, 16:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2012 Location: china
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | E-MATE BOX tutorial best work with easyjtag imge piugin 1.What is e-mats box?this box is a sd carder.easyjtag support sd imge tool. why do you need e-mate box? emmc chip hvae about 4GB 8GB 16GB 32GB 64GB.if you write full dump file have 1MB/s by easyjtag box.flash 16GB need a long time..so you can fast flash emc chip by e-mate,about 16-32mb/s to flash userdata.but e-mate cant flash boot1 boot2..easyjtag can support boot and repair samsung emmc chip fw. now do you know what is e-mate?EASYJTAG mate EMMC mate.!!!! 2 how to use E-mate 5 in 1? look at the photo. picture 1 open eastjtag tool run plugin:SD/USBeMMC/E-MATE IMAGIN TOOL picture 2 E-MATE connection Will pop-up window picture 3 refresh drives you can see 14.6GB drives picture 4 Set the file directory. picture 4 read and write |
The Following User Says Thank You to MOORC For This Useful Post: |
05-12-2015, 16:49 | #2 (permalink) |
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | Easyjtag support bga221 Box S/N: 150040150D49C44C, ,FW Ver.: 01.52 CMD Pullup Level:2145 mV CMD Active Level:2454 mV eMMC Device Information EMMC CID : 90014A4841473464040502A121238180 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 08/2014 Rev.0x5 EMMC NAME: HAG4d , S/N: 44114211 EMMC NAME (HEX): 48414734642000 EMMC ROM1 (Main User Data) Capacity: 15032 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: HAG4d _ 44114211_20150402_2345.extcsd Done. THIS is a BGA221 chip.work whith easyjatg and e-mate box. |
05-12-2015, 17:21 | #3 (permalink) |
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | how to Cleaning maintenance E-SOCKET BAG how to Cleaning AND maintenance E-SOCKE? 1.After cleaning the probe, must, in accordance with the state of the picture 1. only picture 1 state you can install panel.Otherwise the probe will be broken. Please strict installation images 1, 2, 3, 4, 5 cleaning maintenance |
The Following 2 Users Say Thank You to MOORC For This Useful Post: |
10-06-2015, 22:34 | #8 (permalink) |
Junior Member Join Date: May 2008
Member: 781696 Status: Offline Thanks Meter: 0 | I have SM-A500FU downgrade it from 5.0.2 to 4.4.4 don't make f/swipe m/reset, finish fine, but phone never wakeup, pc cant found it, so I brick it. now have dead bootlouder, or it have some disision fix my phone? |
