01-17-2014, 12:06 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | easy jtag 1st setup - driver problem i need to install my new jtag box, when ask for driver i choose in prgrm file> z3x > jtag driver and no driver found for my easy jtag box. anybobdy can send me the driver plz? btw im using xp sp2 thanks in advance |
01-17-2014, 12:26 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | c: programfiles\z3x\jtag drivers\x86 folder or CCID XP folder... for mine i used X86 folder Last edited by chmsc_ELX; 01-17-2014 at 12:27. Reason: missing |
The Following User Says Thank You to chmsc_ELX For This Useful Post: |
01-19-2014, 04:42 | #5 (permalink) |
Member: 1741973 Status: Offline Thanks Meter: 115 | can i ask a little easy jtag master? why my smart card of my easy jtag is not fully inserted on the socket, back of the card almost .5 cm reach comparae to the smart card of z3x samsung box that is inside. sometimes my card is fully inserted inside that causing my card not to be shown, card not detected/card not found/wrong card. i RTS this a weeks pass, supplier not replace my box. what should i do make card fully ionserted and work fine. so that card not be touch. my question is, is this the design of z3x jtag box that the card almost seen outside? 1/4 card space seen, is it safe or not? what should i do with this even box fully work, the card is annoying on my job.. |
01-19-2014, 13:39 | #6 (permalink) |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | yes i update my card using pkey or mxkey i think then re insert it into the box and thats works for me.. i also move to sp3 easy update |
