03-08-2022, 13:17 | #1 (permalink) |
Insane Poster Join Date: Apr 2014
Member: 2170126 Status: Offline Sonork: Whtas & Fb Thanks Meter: 53 | easy jtag bga 254 socket error help UFS: Voltage Info: Mode: LOW VCC : 3281 mV, VCCQ2: 1920 mV 3v3 : 3376 mV, 1v2: 1203 mV UFS: Memory Info: Connection: Socket BGA-254 Vendor: SAMSUNG Name: KM8V8001JM-B813 S/N: 450a7bb10b1d OEM ID: SAMSUNG_OEM_ID Firm Version: 1.5.0.0 UFS Version: 2.1 Size: 0x001DCC800000/119.20 GB Max LUNs: 8 LUNs Cnt: 6 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS RPMB Info: RPMB Counter: 68984 UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 -> Size: 30881792 Block(s)/117.80 GB LUN 1 (Boot A) -> Size: 2048 Block(s)/8.00 MB LUN 2 (Boot B) -> Size: 2048 Block(s)/8.00 MB LUN 3 -> Size: 8192 Block(s)/32.00 MB LUN 4 -> Size: 278528 Block(s)/1.06 GB LUN 5 -> Size: 65536 Block(s)/256.00 MB W-LUN 0xC4 (RPMB) -> Size: 65536 Block(s)/16.00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ Try Again #1 Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ Try Again #2 Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ Try Again #3 Too Many Errors. Stopped. Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ Error While Reading. Exit. Code: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ Error While Scan Partitions. Scanner Shutdown.. Scanner Thread Terminated Elapsed: 00:00:05:217 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. easy jtag error Chip Info: Manufacturer: SAMSUNG ProductName: KM8V8001JM-B813 SerialNumber: 450a7bb10b1d OemID: SAMSUNG_OEM_ID Firmware Version: 1.5.0.0 UFS Version: 2.1 Maximum Number of LUs: 8 Number of LUs found: 6 LUN 0: Block size: 0x1000 Size: 0x1D73800000 / 117,824,000,000B / 117GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 3: Block size: 0x1000 Size: 0x2000000 / 0,032,000,000B / 32MB LUN 4: Block size: 0x1000 Size: 0x44000000 / 1,064,000,000B / 1GB LUN 5: Block size: 0x1000 Size: 0x10000000 / 0,256,000,000B / 256MB Number of W-LUs found: 1 W-LUN 0xC4 (RPMB): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0x1DCC800000 / 119,200,000,000B / 119GB RPMB: Counter: 68984 Health: Device life time method A: 0x01 (0%-10% device life time used) Device life time method B: 0x01 (0%-10% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Can't stop LU, Code: -406, Reason: UAP SCSI: Command sense: UNIT_ATTENTION Done. Easyjtag plus 2 Socket Type: UFS_SOCKET_BGA_254 UFS Power Information : Mode: Low, VCC: 3260 mV, VCCQ2: 1918 mV UFS Device Information : UFS Manufacturer: SAMSUNG, UFS ProductName: KM8V8001JM-B813 UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 450a7bb10b1d Maximum Number of LUs: 8, Number of LUs found: 6, Number of WLUs found: 1, LUs Re-configure: Enabled RPMB Counter: 68984 UFS LUN 0 Capacity: 120632 MB (001D73800000) UFS LUN 1 (Boot A) Capacity: 8 MB (000000800000) UFS LUN 2 (Boot B) Capacity: 8 MB (000000800000) UFS LUN 3 Capacity: 32 MB (000002000000) UFS LUN 4 Capacity: 1088 MB (000044000000) UFS LUN 5 Capacity: 256 MB (000010000000) UFS W-LUN 0xC4 (RPMB) Capacity: 16 MB (000001000000) Device Life Time Estimation B: 0x01 0% - 10% device life time used Device Life Time Estimation A: 0x01 0% - 10% device life time used Pre EOL information: 0x01 Normal (Consumed less then 80% of reserved block) Do not turn the socket before you press "Close Session" button Connected successfully Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write) Scanning soft partitions from LUN 0 Error reading at address: 000000000000 , error: -403, UAP SCSI: Command sense: MEDIUM_ERROR ... Retry #1 Error reading at address: 000000000000 , error: -403, UAP SCSI: Command sense: MEDIUM_ERROR ... Retry #2 Error reading at address: 000000000000 , error: -403, UAP SCSI: Command sense: MEDIUM_ERROR ... Retry #3 Canceled Need Solution |
