09-07-2016, 07:58 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Samsung GT-I9195 ( S4 MINI ) eMMC Repair Easy JTAG Log Here: No boot partition configured. Code: Z3X EasyJtag Software ver. 2.3.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0B0170135E37F259, ,FW Ver.: 01.55 CMD Pullup Level:2557 mV CMD Active Level:2526 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 02000053444D30333290FFFFFFFF29BC EMMC CSD : 8C0F002A015981E9B6D9FC1F8A4040AA EMMC Manufacturer ID: 0002 , OEM ID: 0000 EMMC Date: 02/2006 Rev.0x90 EMMC NAME: <b>SDM032</b> , S/N: 4294967295 EMMC NAME (HEX): 53444D30333200 EMMC ROM1 (Main User Data) Capacity: 30 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x00 Device NOT support partitioning feature Device cannot have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SDM032_4294967295_20160906_1257.extcsd When Repair Via SDC Method This Error Coming: When FLASH In z3x Box Again-10 This Error Coming" Set PIT file... Error Note:Please Give Me Full eMMC Dump File With ROM1 & 2 So Please Help Me Thanks & Regards By: Gopal Parmar |
09-07-2016, 08:58 | #3 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | When Connect This Mobile To PC In Device Manger This Showing: "Qualcomm HS-USB QDLoader 9008" |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
09-07-2016, 09:07 | #4 (permalink) | |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Quote:
Because I Chane eMMC IC Where eMMC IC Remove Ball Mismatch In This Condition Mobile May Be Damage. If You Have SAFE Way Change eMMC IC Please Tell Me Here Please | |
09-07-2016, 14:26 | #5 (permalink) |
Freak Poster Join Date: Jun 2012 Location: bali
Member: 1778254 Status: Offline Sonork: sornork id Thanks Meter: 36 | its easy bro just replease blank emmc like: klm8g>8gb kmvtu/kmv3w 16gb kmv2 32gb set boot for 2mb and rpmb 128kb no boot config after replease u can repair via sdc |
The Following User Says Thank You to putu1996 For This Useful Post: |
09-10-2016, 11:55 | #8 (permalink) |
Freak Poster Join Date: Apr 2016
Member: 2566174 Status: Offline Thanks Meter: 9 | i will join this thread also because getting lot of phones like this and no way to repair them , so my question is after replace emmc if set still showing boot dead then what ? |
The Following User Says Thank You to gsmfonefun For This Useful Post: |
01-10-2017, 20:26 | #10 (permalink) |
Junior Member Join Date: Mar 2007 Location: BULGARIA,KARDJALI
Member: 461085 Status: Offline Thanks Meter: 1 | I9195 emmc problem hellp REPLACE EMMC S3 MINI TO I9195,BUTH NOT BOOT AFTER FLASHING DIRECT WITH ATF NITRO ( FULL FLASH WITH MD5) ENIY IDEAS FRIENDS |
The Following User Says Thank You to Boom777 For This Useful Post: |
02-16-2017, 16:16 | #13 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | Quote:
MMC ROM1 (Main User Data) Capacity: 30 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB need to change emmc. | |
