01-23-2021, 11:03 | #1 (permalink) |
Junior Member Join Date: Jan 2020 Location: earth
Member: 2944398 Status: Offline Thanks Meter: 9 | Easy Jtag classic Suite Tool Can Detect Phone But Emmc Tool Suite Not Detect need to flash combination on A105FN But cant detect phone on easy jtag Emmc Tool suite where have to flash combination , but yes phone can detect on Jtag Classic Suite what can be problem sir if all same conected but on 1 software phone detected and at other no i have black box easyjtag plus and blue color adapter Log OF Classic Suite EasyJtag Suite Classic ver.: 3.7.0.20 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 18363), 64-bit edition. Admin rights OK Android Explorer ver:1.0.0.24 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.11.3 QUALCOMM Direct ver:1.0.6306.57125 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.18362.1 Z3X Card Serial : AAD4-F70B , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 2 serial devices COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) COM16 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM16) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2000 mV Box S/N: 3792B35832655B16, ,FW Ver.: 02.53 CMD Pullup Level:986 mV CMD Active Level:1573 mV Box IO Level:2000 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100424A544434520046528D32C68D eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2019 Rev.0x0 eMMC NAME: BJTD4R , S/N: 1179815218 eMMC NAME (HEX): 424A54443452 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or NO Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: BJTD4R_1179815218_20210123_1450.extcsd Caution: invalid backup GPT header, but valid main header! EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (3.312GB) Short EXT fs info: Size: 3.259GB Block size: 4.0KB Inode size: 256 Inodes: 213840 Short Android info: Blocks Reading Error (0x12F12000 , 8 , Reason: DATA RCV CRC Error ) Unable to read prop.plist , code : 5 --------------------------------------------- Detected USERDATA USERDATA : 0x0133300000 (24.316GB) Blocks Reading Error (0x133300400 , 2 , Reason: DATA RCV CRC Error ) Unable to mount USERDATA , code : 5 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Log OF Emmc Tool Suite eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 10 (64 bit) build 18363 (10.0.18362.1316) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = 3792B35832655B16 Card Serial = AAD4F70B EasyJTAG Box Firmware = 2.5301 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 430 mV CMD Active Level: 1156 mV Can't init device. Reason: CMD Timeout Error Error: Previous operation is not finished yet. Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 12 MHz CMD Pullup Level: 430 mV CMD Active Level: 1154 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 9 MHz CMD Pullup Level: 428 mV CMD Active Level: 1153 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Error: Previous operation is not finished yet. Setting bus width to 1 Bit Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 429 mV CMD Active Level: 1156 mV Can't init device. Reason: CMD Timeout Error Error: Previous operation is not finished yet. Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 9 MHz CMD Pullup Level: 430 mV CMD Active Level: 1154 mV Can't init device. Reason: CMD Timeout Error Error: Previous operation is not finished yet. Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 9 MHz CMD Pullup Level: 429 mV CMD Active Level: 1156 mV Can't init device. Reason: CMD Timeout Error Best Regards |
01-23-2021, 16:05 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
you can try ust it (include with 1.6.4 version) | |
