Old 08-29-2013, 11:27   #1 (permalink)
Member: 1742913
Sonork: 100.1604070
Thanks Meter: 328
i9300 emmc reprire need help
hallo guyes, need i9300 emmc repire guid. i cannot write boot file.
here is log
EasyJtag Suite ver.: 1.0.61.1 started.
Operating system ver.: Windows XP (build 2600, Service Pack 3).
Successefuly connected to box on COM96
Box S/N: xxxxxxxxxxxxx, ,FW Ver.: 01.47
Box Working Mode: JTAG Box.
Box Drivers version: 2.2.5.0, are to old, please update to 3.0.0.0
Z3X Card Serial : xxxxxxxxx
Z3X Card Version : 22
Z3X Card Activation [JTAG] : 1
Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com
Box S/N: 1414100FF53720E8, ,FW Ver.: 01.47
Loading eMMC Addon Firmware...
CMD Pullup Level:422 mV
CMD Active Level:2227 mV
EMMC CID 1501003030303030300020110726589D
EMMC CSD 902701320F5903FFF6DBFFEF8A404023
EMMC Manufactorer ID: 15
EMMC OEM ID: 0100
EMMC Date: 05/2005 FW rev.0x0 HW rev.0x0
EMMC Serial #: 537986854
EMMC NAME: 000000
EMMC Capacity: 16384 MB (High Density Card)
Extended CSD rev 1.5 (MMC 4.41)
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x03]:
implementation based on CMD12
Background operations support [BKOPS_SUPPORT: 0x01]
Background operations status [BKOPS_STATUS: 0x00]
TRIM Multiplier [TRIM_MULT: 0x01]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x15]
Secure Erase Multiplier [SEC_ERASE_MULT: 0x04]
Secure TRIM Multiplier [SEC_TRIM_MULT: 0x07]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x04]
Access size [ACC_SIZE: 0x08]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x90]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x13]
Sector Count [SEC_COUNT: 0x02000000]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x01]
Card Type [CARD_TYPE: 0x07]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x00]
Not boot enable
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x01
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
H/W reset function [RST_N_FUNCTION]: 0x00
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0xd38000
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
General Purpose Partition Size
[GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Writing file...C:\Program Files\Z3X\EASYJTAG\Repair Files\Repair Files\EMMC_ROM2_00000000_00200000.bin
Box S/N: xxxxxxxxxxx, ,FW Ver.: 01.47
CMD Pullup Level:412 mV
CMD Active Level:2248 mV
EMMC OEM ID: 0100
EMMC NAME: 000000
Writing 00200000 bytes to 00000000 ...ROM1
Old 08-29-2013, 16:44   #2 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
Clear case Of eMMC Damaged.
EMMC NAME: 000000
Software cant help you, you should replace eMMC.
Old 08-29-2013, 16:56   #3 (permalink)
Member: 804793
Sonork: perotskie
Thanks Meter: 3
replace the EMMC 100% working
get from the note2 its working tested.
check this logs.
Successefuly connected to box on COM3
Box S/N: ***************9F, ,FW Ver.: 01.47
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA3B-2511
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.47
CMD Pullup Level:1722 mV
CMD Active Level:2371 mV
EMMC CID 15010056545530304D00262B595B1179
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC OEM ID: 0100
EMMC Date: 01/1998 FW rev.0x0 HW rev.0x0
EMMC Serial #: 640375131
EMMC NAME: VTU00M
EMMC Capacity: 15028 MB (High Density Card)
Extended CSD rev 1.6 (MMC 4.5)
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x04]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot partition size [BOOT_SIZE_MULTI: 0x10]
Access size [ACC_SIZE: 0x07]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x50]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x01d5a000]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02]
I/O Driver Strength [DRIVER_STRENGTH: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x48]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000bb
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be Released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin
CMD Pullup Level:1711 mV
CMD Active Level:2382 mV
EMMC OEM ID: 0100
EMMC NAME: VTU00M
Writing 00200000 bytes to 00000000 ...ROM2
Write Speed: 158 kB/s
Done !!!
Old 08-29-2013, 18:07   #4 (permalink)
Member: 1742913
Sonork: 100.1604070
Thanks Meter: 328
it means emmc problum?
Page generated in 0.19362 seconds with 8 queries
