Old 08-26-2013, 03:13   #1 (permalink)
Member: 452521
Thanks Meter: 3
Wildfire S Easy Repair? [New RCP inside]
Hi !
I want to restore Wildfire S. BBut getting an error:
Connecting to Target...
JTAG device: MSM7227T
CPU IDCODE : 0x203C10E1 Mfg.: 0x070, Part: 0x03c1, Ver.: 0x2
CPU Manufacturer: QUALCOMM , CPU Name: MSM7227T
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting nand memory parameters ...
NAND flash device ID:00AD:00BC 'NAND 512MB 1.8V 16-bit (Hynix)' found
NAND geometry: Blocks:00001000, Page size:2048 bytes , Block size:64 pages
Restoring MIBIB
couldn't open MIBIB.bin
failed to open 'MIBIB.bin' for read access
Tried on two phones, one of them known-good. In what could be the reason?
Old 08-26-2013, 08:10   #2 (permalink)
Member: 1859138
Thanks Meter: 20
I confirm this, repair does not work, I have the same log
Old 08-26-2013, 12:54   #3 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
please post full log. we will test. i have this phone in hands.
WildFire S resurecto V2 file - try this . CLICK
Old 08-27-2013, 04:05   #4 (permalink)
Member: 452521
Thanks Meter: 3
The second file is the same.
log with the first file:
Using EasyRepair Mode...
Checking repair data...
EasyJtag Suite ver.: 1.0.61.1 started.
Operating system ver.: Windows XP (build 2600, Service Pack 3).
For support and updates visit EasyJtag , just better ? - New powerful JTAG unbrick device.
Initialising: HTC Wildfire S Config ver.:1.00
I/O Level set to : 2600 mV
Box S/N: 0E0EFC12FA73B7DD ,FW Ver.: 01.47
Halting CPU...
Restoring MIBIB
The second file:
Easy-Repair file load OK!
Halting CPU...
Restoring MIBIB
Old 08-27-2013, 10:40   #5 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
i will check now again. may be problem becouse used capital characters inside rpc file. In 1-2h i will upload v.1.02 rcp file.
Old 08-28-2013, 13:13   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
please try new rcp here
Old 08-29-2013, 06:37   #7 (permalink)
Member: 452521
Thanks Meter: 3
This file is a good (HTC_WILDFIRE_S_V1.02):
Halting CPU...
Restoring MIBIB
NAND Write OK! Elapsed time: 12.109375s (109.006 KiB/s)
Restoring QCSBL
NAND Write OK! Elapsed time: 4.828125s (109.359 KiB/s)
Restoring OEMSBL1
NAND Write OK! Elapsed time: 7.046875s (112.390 KiB/s)
Restoring OEMSBL2
Restoring HTC
NAND Write OK! Elapsed time: 19.343750s (109.183 KiB/s)
Restoring AMSS
NAND Write OK! Elapsed time: 232.296875s (109.102 KiB/s)
Restoring APPSBL
Restoring MISC_MFG
NAND Write OK! Elapsed time: 2.359375s (111.894 KiB/s)
Restoring WLAN
NAND Write OK! Elapsed time: 2.421875s (109.006 KiB/s)
All Done.
The Following 2 Users Say Thank You to nikitin78 For This Useful Post:
Page generated in 0.16449 seconds with 8 queries
