05-29-2022, 18:24 | #4 (permalink) |
No Life Poster Join Date: Dec 2007 Location: egypt
Member: 648590 Status: Offline Thanks Meter: 267 | Identify UFS Chip. UFS Chip Voltage: Low Check ISP connect. Calibrate ISP for BGA153. VCC: 3255mV VCCQ2: 1929mV Chip Info: Manufacturer: SAMSUNG ProductName: KLUCG4J1ED-B0C1 SerialNumber: 0x1895277B22027EE76AD884DDFD81533557435A4D4D414131 OemID: SAMSUNG_OEM_ID Firmware Version: 0.03 UFS Version: 2.1 Maximum Number of LUs: 8 Number of LUs found: 5 LUN 0: Block size: 0x1000 Size: 0xEE4800000 / 59,584,000,000B / 59GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 3: Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 4: Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB Number of W-LUs found: 1 W-LUN 0xC4 (RPMB): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0xEE6800000 / 59,616,000,000B / 59GB RPMB: Counter: 50231 Health: Device life time method A: 0x03 (20%-30% device life time used) Device life time method B: 0x03 (20%-30% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Chip config is OTP Checking LU0 for partitioning LUN0 Have 21 partitions LUN1 Have no partitions LUN2 Have no partitions LUN3 Have 1 partitions LUN4 Have no partitions ------ Detected 22 partitions ------ LUN0 (BOTA0) [0x400000 0x400000] Size: 4.0MB LUN0 (BOTA1) [0x800000 0x800000] Size: 8.0MB LUN0 (EFS) [0x1000000 0x1400000] Size: 20.0MB LUN0 (PARAM) [0x2400000 0x800000] Size: 8.0MB LUN0 (UP_PARAM) [0x2c00000 0x800000] Size: 8.0MB LUN0 (BOTA2) [0x3400000 0x800000] Size: 8.0MB LUN0 (BOOT) [0x3c00000 0x2800000] Size: 40.0MB LUN0 (RECOVERY) [0x6400000 0x2e00000] Size: 46.0MB LUN0 (RADIO) [0x9200000 0x2a00000] Size: 42.0MB LUN0 (NAD_REFER) [0xbc00000 0x100000] Size: 1.0MB LUN0 (PERSISTENT) [0xbd00000 0x80000] Size: 512.0KB LUN0 (MISC) [0xbd80000 0x100000] Size: 1.0MB LUN0 (STEADY) [0xbe80000 0x400000] Size: 4.0MB LUN0 (DQMDBG) [0xc280000 0x1000000] Size: 16.0MB LUN0 (SYSTEM) [0xd280000 0x140000000] Size: 5.0GB LUN0 (CACHE) [0x14d280000 0x25800000] Size: 600.0MB LUN0 (HIDDEN) [0x172a80000 0xa00000] Size: 10.0MB LUN0 (OMR) [0x173480000 0x3200000] Size: 50.0MB LUN0 (CP_DEBUG) [0x176680000 0x500000] Size: 5.0MB LUN0 (NAD_FW) [0x176b80000 0x1400000] Size: 20.0MB LUN0 (USERDATA) [0x177f80000 0xd6c400000] Size: 53.691GB LUN3 (CPEFS) [0x6000 0x600000] Size: 6.0MB ------------------------------------ Read SYSTEM from LUN0. ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000D280000 (5.0GB) Short EXT fs info: Size: 4.911GB Block size: 4.0KB Inode size: 256 Inodes: 321920 Short Android info: Build ID: PPR1.180610.011 Display Build ID: PPR1.180610.011.N950FXXSGDUG8 Release Incremental ID: N950FXXSGDUG8 Release Base ID: 9 Security Path: 2021-08-01 Device Model: SM-N950F Device Manufacturer: samsung Product ID: greatlte Device Name A: greatltexx Device Name B: greatlte Architecture ABI: arm64-v8a Device manufacturer: samsung Build Description: greatltexx-user 9 PPR1.180610.011 N950FXXSGDUG8 release-keys PDA ver.: N950FXXSGDUG8 FRP Partition Path: /dev/block/persistent Backup saved: BuildProp_20220529_1918.txt thanx is done |
