02-01-2023, 09:08 | #17 (permalink) |
No Life Poster Join Date: Sep 2008 Location: in your hart Age: 40
Member: 864102 Status: Offline Sonork: 100.1617637 Thanks Meter: 146 | up up up my problem is same not detecting micron ufs chip on easyjtag classic suite, easyjtag emmc plus or plus 2 but easyjytag emmc manger detect perfect here is some screeshot:- |
The Following 2 Users Say Thank You to moinuddin111 For This Useful Post: |
02-03-2023, 18:39 | #19 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
and oldest API dll some API version, like 3403 not work with some MICRON IC but oldest 3401 API have problems with some Toshiba UFS Micron UFS will be fixing at new API versions but now we have big bugs at current API and working for fix it | |
The Following User Says Thank You to layder For This Useful Post: |
03-07-2023, 10:21 | #20 (permalink) |
No Life Poster Join Date: Jan 2009 Location: obamas village
Member: 952862 Status: Offline Thanks Meter: 48 | a047f some chips read some dont those which dont read do this Z3X EasyJtag Software ver. 3.8.0.1 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 93E8964E6FA82E9E, ,FW Ver.: 02.53 CMD Pullup Level:1851 mV CMD Active Level:1850 mV Box IO Level:1800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010044563644424200CAC36AE189FF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2006 Rev.0x0 eMMC NAME: DV6DBB , S/N: 3401804513 eMMC NAME (HEX): 445636444242 Can't init EMMC, Reason: DATA RCV Timeout Error Check Data Line! Done. Can't init device, Reason: Initialization failed Done. Error. Please select init first. Z3X EasyJtag Software ver. 3.8.0.1 Loading eMMC GEN2 Firmware... IO: 2200 mV Box S/N: 93E8964E6FA82E9E, ,FW Ver.: 02.53 CMD Pullup Level:2012 mV CMD Active Level:2115 mV Box IO Level:2200 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010044563644424200CAC36AE189FF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2006 Rev.0x0 eMMC NAME: DV6DBB , S/N: 3401804513 eMMC NAME (HEX): 445636444242 Can't init EMMC, Reason: DATA RCV Timeout Error Check Data Line! Done. Can't init device, Reason: Initialization failed Done. |
