Old 05-05-2022, 08:49   #16 (permalink)
Member: 2287102
Thanks Meter: 119
Originally Posted by layder View Post
try to copy EasyAPI.dll from efm folder to plus soft folder
after copy the easyapi.dll software not open brother
Old 02-01-2023, 09:08   #17 (permalink)
moinuddin111's Avatar
Member: 864102
Sonork: 100.1617637
Thanks Meter: 145
up up up
my problem is same not detecting micron ufs chip on easyjtag classic suite, easyjtag emmc plus or plus 2 but easyjytag emmc manger detect perfect
here is some screeshot:-
The Following User Says Thank You to moinuddin111 For This Useful Post:
Old 02-03-2023, 14:00   #18 (permalink)
Member: 864102
Sonork: 100.1617637
Thanks Meter: 145
no reply to any product supporters?
Old 02-03-2023, 18:39   #19 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,836
Originally Posted by moinuddin111 View Post
up up up
you use oldest EFM version from 2020
and oldest API dll
some API version, like 3403 not work with some MICRON IC
but oldest 3401 API have problems with some Toshiba UFS
Micron UFS will be fixing at new API versions
but now we have big bugs at current API and working for fix it
Old 03-07-2023, 10:21   #20 (permalink)
obama2's Avatar
Member: 952862
Thanks Meter: 46
a047f some chips read some dont those which dont read do this
Z3X EasyJtag Software ver. 3.8.0.1
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: 93E8964E6FA82E9E, ,FW Ver.: 02.53
CMD Pullup Level:1851 mV
CMD Active Level:1850 mV
Box IO Level:1800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 15010044563644424200CAC36AE189FF
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 08/2006 Rev.0x0
eMMC NAME: DV6DBB , S/N: 3401804513
eMMC NAME (HEX): 445636444242
Can't init EMMC, Reason: DATA RCV Timeout Error
Check Data Line!
Done.
Can't init device, Reason: Initialization failed
Done.
Error. Please select init first.
Loading eMMC GEN2 Firmware... IO: 2200 mV
CMD Pullup Level:2012 mV
CMD Active Level:2115 mV
Box IO Level:2200 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Check Data Line!
Done.
Done.
Old 03-07-2023, 10:25   #21 (permalink)
obama2's Avatar
Member: 952862
Thanks Meter: 46
The bad thing when phone reads half way it goes dead
Old 03-22-2023, 15:07   #22 (permalink)
Member: 2252970
Thanks Meter: 7
have solution
i have solution if you want pm me
Old 03-22-2023, 15:13   #23 (permalink)
Member: 2252970
Thanks Meter: 7
can fix it
Originally Posted by zack winstone View Post
Any one can help me please ��
i can contact me at telegram @unlockbynav
Old 03-23-2023, 16:17   #24 (permalink)
Member: 2494408
Thanks Meter: 110
trying modify ufs socket or only chip off
Page generated in 0.16618 seconds with 9 queries
