GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-30-2018, 19:37   #1 (permalink)
Member: 1212133
Thanks Meter: 50
Easy Jtag pinout
Can anyone let me know
where Easy Jtag pinouts is available?
How should I connect the EasyJtag pinouts with the signals on the enclosed picture?
https://imgur.com/a/Jr1J0KJ
Thanks
Old 08-30-2018, 20:09   #2 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 499
if u have jtag isp adaptor , follow this picture
Old 08-30-2018, 21:39   #3 (permalink)
Member: 13148
Thanks Meter: 1,674
Thanks
EasyJTAG box (color box) pinout
To get 1,8 & 2,8 you need use adapter
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 08-31-2018, 08:25   #4 (permalink)
Member: 1212133
Thanks Meter: 50
@gunit1: Which picture? You probably forgot to attach it.
@layder: Which adapter do you mean? Easy Jtag adapter ? I saw a different EasyJtag emmc pinout from yours. How did you get yours? Are there really so many clock signals coming out from EasyJtag emmc pinout?
Besides, from your picture I cannot see how to connect yellow wire/pin marked VCCQ=VDD
Thnaks for the replies
Old 08-31-2018, 09:30   #5 (permalink)
Member: 13148
Thanks Meter: 1,674
old (EasyJTAG box, not EasyJTAG Plus box), is have only GND, CMD, CLK, Data0 pins. Box is requires external 2,8 & 1,8v supply eMMC power (from USB adapter), or need "Hipower CLK" conection, when power to eMMC used via board from USB power connected to it.
"HiPower CLK" mode is requires connect 4 wires CLK from box together.
VCCQ - 1,8v
VCC - 2,8v
Old 08-31-2018, 17:21   #6 (permalink)
Member: 1212133
Thanks Meter: 50
Thanks for the reply. Yet, I do not understand.
I need to JTAG N8010 ( tablet). So I found out eMMC pinout of the mainboard like this
How must I connect those signals in the picture together with EasyJtag pinouts adaptor cable
Thanks
Old 09-01-2018, 22:09   #7 (permalink)
Member: 1212133
Thanks Meter: 50
Nobody knows how to connect... ?
Old 09-01-2018, 23:28   #8 (permalink)
Member: 13148
Thanks Meter: 1,674
EasyJTAG power adapters:
schematics of adapters:
The Following User Says Thank You to layder For This Useful Post:
Old 09-03-2018, 17:19   #9 (permalink)
Member: 1212133
Thanks Meter: 50
Yes, that is what I needed.Thanks.
But what is that wide colour cable for?How is it used?I mean the colour cable I posted picture in post #6
Old 09-03-2018, 18:04   #10 (permalink)
Member: 13148
Thanks Meter: 1,674
Color cable for JTAG connection
Old 09-07-2018, 17:33   #11 (permalink)
Member: 1212133
Thanks Meter: 50
I tried to use EasyJtag with EasyJTAG power adapter to program eMMC on Samsung N8010( tablet). But I failed.
It seems to me as if EasyJtag could not see eMMC( maybe because of a faulty EasyJTAG power adapter) or an error of EasyJtag itself.
Can anyone give a clue what to check? What signals should I see on CMD pin( and other pins) with an osciloscope?
Thanks
Old 09-07-2018, 17:48   #12 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 509
Thumbs up I can help you
I can help you
Contact me in pm
Old 09-07-2018, 20:34   #13 (permalink)
Member: 13148
Thanks Meter: 1,674
You need check connection lines CMD, CLK, Dat_0 from box to eMMC, you need check voltage on eMMC power pins. If you use ISP connection, you wiil try to select 2,8v at software (for 1st box generation).
Page generated in 0.37174 seconds with 8 queries
