12-29-2020, 02:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | Easy Jtag Plus Dead / Not Detected by PC / No light I was working on an oppo phone with an ISP connection. Accidentally I was started fixing the isp connection with soldering iron while the PCB was connected to the box. I heard the box disconnected sound from pc. and after that my box is dead. It is not detected by pc ( windows 10 and windows 7 ) I have tried on 4 different pcs and laptops. I have tried 3 different cables. There is no light on any of the front 4 led on the box. The device manager not showing anything if the box is connected or not. I have opened the box and check for any burn component, but all looks clean. Any guidance from where I should start checking to fix this box? Pic Attached : https://imgur.com/a/Y2yfuVr Regards, LITTLE MASTER |
01-02-2021, 14:47 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Warranty for box is resseler-depended, up to 1 year you case is not warannty case you need yourself check power components of box to repait it. check power line fom PC USB connector and try to find solution |
The Following User Says Thank You to layder For This Useful Post: |
