Easy Jtag - activated 2014-01-01 Easy Jtag Plus - NOT available, update possible how to activate |
Hi Team, We understand that Z3x does not want to give full support to U-Sockets or E-Sockets adapters from other brands, when it comes to some kind of compatibility with Chips in general. Sometimes a common BGA-153 Model XX chip is read by original Z3x E-Socket and cannot be read by ICFRIEND (MOORC) E-Scket, due to some kind of incompatibility that we users are not aware! The question is because if the reading is with the same chip and you are the owners of all the extra adapters. What is the difference?; Are they construction errors? Factory errors? Miscalculation of the node map of the different chips? Or is it just plain bad luck? We would really like to know what is the problem of these adapters with some chip models among other brand adapters. If you can answer a few questions, I would greatly appreciate it; For example:: 1. In the E-Socket BGA-153, ChipXX, Pin A-3 (Data0) layout adapter, this node connects with Pin #12 of the 20PIN connector of Z3x, but the Pinout of the Z3x connector is a (NC)? But it works and you get chip reading! :confused: 2. In the E-Socket BGA-153, ChipXX, Pin M-5 layout adapter (according to the Z3x pinout is the CMD) in the original E-Socket Z3x, this node connects with Pin #8 of the Z3x 20PIN connector, but the Pinout of the Z3x connector is a (NC)? But it works and you get chip reading! :confused: Question! The pinout of the 20-pin connector of Z3x internally HAS function and connects internally in the box, even if the pinout says NON Connect (NC) on the external 20Pin of Z3x Box? :confused: |
EasyJTAG box have progremmed pins I/O connector type of pinouts and voltage is selected via software Only 20 pin have GND always U-sockets adapter need to connect UFI sockets to Z3x EasyJTAG box E-socket adapter need to connect old sockets without capacitor at power lines this adapter have only 2 capacitors for VCC/VCCQ MOORC have all documentation from our team for create correct adapters, but it create adapters like his own mind We can't blocked it for create his different adapters |
as I said, Moorc is constantly reworking its sockets. if he had made everything work the first time, then he would not have had to redo anything later. but the Chinese love to make new versions. that's why he does it. |
Hello I bought EasyGitech Plus box in Iran And the salesman did not tell me how it worked Please guide me to train with your very good box Thanks a lot |
In this site stock is not available.... When stock is available kindly tell, I am waiting from 2month, but did not available. |
i am trying to clean rpmb for a107f. i successfully backup rom2 and rom 3 but rom 1 is very slow and with errors someone pliz help. 8/16/2021 2:06:58 PM> Looking for EasyJTAG box... 8/16/2021 2:06:58 PM> EasyJTAG API ver. 3403 8/16/2021 2:06:58 PM> Setting IO Levels to 2.8V 8/16/2021 2:06:58 PM> Setting frequence to 6 MHz 8/16/2021 2:06:58 PM> EasyJTAG Box Serial = 3D358578033FFFDB 8/16/2021 2:06:58 PM> EasyJTAG Box Firmware = 2.5302 8/16/2021 2:07:00 PM> Setting interface to EasyJtag2/ISP 8/16/2021 2:07:00 PM> Setting bus width to 1 Bit 8/16/2021 2:07:00 PM> Setting frequence to 6 MHz 8/16/2021 2:07:00 PM> CMD Pullup Level: 2092 mV 8/16/2021 2:07:00 PM> CMD Active Level: 2427 mV 8/16/2021 2:07:00 PM> eMMC Init returned = 0 8/16/2021 2:07:00 PM> EMMC Device Information : 8/16/2021 2:07:00 PM> EMMC CID: 150100514436334D42039F5568623755 8/16/2021 2:07:00 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 8/16/2021 2:07:00 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: QD63MB , HEX: 514436334D42 , S/N: 9F556862 , rev. 0x03 8/16/2021 2:07:00 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2020 8/16/2021 2:07:00 PM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 8/16/2021 2:07:00 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 8/16/2021 2:07:00 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 105602 , Response: Not Clean 8/16/2021 2:07:00 PM> EMMC Permanent Write Protection: No 8/16/2021 2:07:00 PM> EMMC Temporary Write Protection: No 8/16/2021 2:07:00 PM> Extended CSD Information : 8/16/2021 2:07:00 PM> Extended CSD rev: 1.8 (MMC 5.1) 8/16/2021 2:07:00 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 8/16/2021 2:07:00 PM> Boot Bus Config: 0x02 , width 8bit 8/16/2021 2:07:00 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 8/16/2021 2:07:00 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 8/16/2021 2:07:01 PM> Device supports partitioning features 8/16/2021 2:07:01 PM> Device can have enhanced technological features in partitions and user data area 8/16/2021 2:07:01 PM> Device can have extended partitions attribute 8/16/2021 2:07:01 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 8/16/2021 2:07:01 PM> Backup saved: QD63MB_9F556862_20210816_140701.extcsd 8/16/2021 2:07:01 PM> EMMC Init completed. 8/16/2021 2:07:01 PM> 8/16/2021 2:07:01 PM> Operation: Reading from eMMC... 8/16/2021 2:07:01 PM> 8/16/2021 2:07:05 PM> Reading from: ROM1 , start: 0x000000000000 , size: 0x000747C00000 8/16/2021 2:07:05 PM> Output file: G:\a107f backup\EMMC_QD63MB_ROM1_000000000000_000747C00000. bin 8/16/2021 2:07:05 PM> eMMC switching to ROM1 8/16/2021 2:07:06 PM> Reading partition... 8/16/2021 2:07:30 PM> Error reading at address: 000000930000 , error: -4, DATA RCV CRC Error ... Retry #1 8/16/2021 2:07:30 PM> Error result: -4 8/16/2021 2:08:34 PM> Error reading at address: 000002C70000 , error: -3, DATA RCV Timeout Error ... Retry #1 8/16/2021 2:08:34 PM> Error result: -3 8/16/2021 2:09:48 PM> Error reading at address: 000004FB0000 , error: -3, DATA RCV Timeout Error ... Retry #1 8/16/2021 2:09:48 PM> Error result: -3 8/16/2021 2:10:41 PM> Error reading at address: 000006BD0000 , error: -4, DATA RCV CRC Error ... Retry #1 8/16/2021 2:10:41 PM> Error result: -4 8/16/2021 2:11:55 PM> Error reading at address: 000008F40000 , error: -3, DATA RCV Timeout Error ... Retry #1 8/16/2021 2:11:55 PM> Error result: -3 8/16/2021 2:12:58 PM> Error reading at address: 00000AB60000 , error: -3, DATA RCV Timeout Error ... Retry #1 8/16/2021 2:12:59 PM> Error result: -3 8/16/2021 2:14:02 PM> Error reading at address: 00000C750000 , error: -3, DATA RCV Timeout Error ... Retry #1 8/16/2021 2:14:02 PM> Error result: -3 8/16/2021 2:14:44 PM> Error reading at address: 00000E400000 , error: -1, CMD Timeout Error ... Retry #1 8/16/2021 2:14:44 PM> Error result: -1 |
where we buy this in india, |
When coming stock and letest hardwer |
Hi mr Layder Did you have any plan for update easy plus software Or made a new box for 2022 ? |
Sounds good thanks:);):eek: |
thanks thanks for good update nice work like always |
