06-08-2019, 08:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: UAE
Member: 157870 Status: Offline Thanks Meter: 29 | Sony C3 D2502 Boot Repair NEED HELP my log is: Code: ---------- eMMC Device Information ---------- eMMC CID : 1501004D384731474303E1CE6A5062D8 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2015 Rev.0x3 eMMC NAME: M8G1GC , S/N: 3788401232 eMMC NAME (HEX): 4D3847314743 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLM8G1GEAC-B001 @FBGA153 Possible IC Name[1]: Samsung , KLM8G1GEAC-B031 @FBGA153 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: M8G1GC_3788401232_20190608_0957.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 15269854 Partition info successfully found Found Data areas (firmware parts) count is: 24 --------------------------------------------- P0 (TA) [0x20000 0x200000] Size: 2.0MB P1 (SBL1) [0x220000 0x80000] Size: 512.0KB P2 (S1SBL) [0x2a0000 0x40000] Size: 256.0KB P3 (DBI) [0x2e0000 0x10000] Size: 64.0KB P4 (ABOOT) [0x2f0000 0x80000] Size: 512.0KB P5 (RPM) [0x370000 0x80000] Size: 512.0KB P6 (TZ) [0x3f0000 0x80000] Size: 512.0KB P7 (ALT_SBL1) [0x470000 0x80000] Size: 512.0KB P8 (ALT_S1SBL) [0x4f0000 0x40000] Size: 256.0KB P9 (ALT_DBI) [0x530000 0x10000] Size: 64.0KB P10 (ALT_ABOOT) [0x540000 0x80000] Size: 512.0KB P11 (ALT_RPM) [0x5c0000 0x80000] Size: 512.0KB P12 (ALT_TZ) [0x640000 0x80000] Size: 512.0KB P13 (BOOT) [0x6c0000 0x1400000] Size: 20.0MB P14 (RAMDUMP) [0x1ac0000 0xa00000] Size: 10.0MB P15 (FOTAKERNEL) [0x24c0000 0x1000000] Size: 16.0MB P16 (DDR) [0x34c0000 0x8000] Size: 32.0KB P17 (LTALABEL) [0x3800000 0x1000000] Size: 16.0MB P18 (MODEMST1) [0x4800000 0x180000] Size: 1.500MB P19 (MODEMST2) [0x4c00000 0x180000] Size: 1.500MB P20 (FSG) [0x5000000 0x180000] Size: 1.500MB P21 (APPS_LOG) [0x5400000 0x800000] Size: 8.0MB P22 (SYSTEM) [0x5c00000 0x73a00000] Size: 1.806GB P23 (CACHE) [0x79800000 0xc800000] Size: 200.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0005C00000 (1.806GB) Product ID: D2502 Build Description: D2502-user 5.0.2 19.3.A.0.472 3126580855 release-keys Device Name: D2502 Release Incremental ID: 3126580855 Build ID: 19.3.A.0.472 Display Build ID: 19.3.A.0.472 Device Model: D2502 Release Base ID: 5.0.2 Architecture ABI: armeabi-v7a Device manufacturer: Sony Device Platform: msm8226 --------------------------------------------- Done. Selected eMMC Interface phone can not boot and can not flash. |
