Old 08-04-2020, 18:51   #1 (permalink)
Member: 2213704
Thanks Meter: 22
EASY JTAG PLUS UFS BGA 254/ISP 2in1 NOT WORKING WITH ANY UFS CHIP
UFS BGA 254/ISP 2in1 ISP Pinout line do not work!! I have tried many ufs ic and is not working with good BGA 153 etc ISP or Any Ufs CHIP. Any SOLUTION??
Old 08-04-2020, 19:00   #2 (permalink)
Member: 2772222
Thanks Meter: 9
Same problem here. I thought was wrong pinout in my case.
Could you provide your pinout, please?
Old 08-04-2020, 19:16   #3 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,174
Hello, it seems something wrong with your BGA254 socket. Can you make a clear hi quality photos of both sides and post a log sample ?
The Following User Says Thank You to NoName® For This Useful Post:
Old 08-04-2020, 19:43   #4 (permalink)
Member: 2772222
Thanks Meter: 9
Log:
EasyJtag Suite Classic ver.: 3.7.0.17 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 10 (build 19041), 64-bit edition. Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6671.7138
EasyJTAG SPI Plugin ver:1.1.1.13
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 10.0.19041.1
Z3X Card Serial : AA38-4A55 , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : ACTIVATED
Z3X Card Activation [SAMS] : ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
For more information press F1 to open local help or visit our wiki
Found 3 serial devices
COM1 ACPI\VEN_PNP&DEV_0501 Porta de comunicação (COM1)
COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Dispositivo Serial USB (COM3)
COM5 FTDIBUS\COMPORT&VID_0403&PID_6001 USB Serial Port (COM5)
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.7.0.17
UFS Socket Info.
Serial: 0123BD84CE3026E4EE
Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 10.01.20
Can't open link, Code: -56, Reason: BOX: Chip not connected
Done.
Pics: https://drive.google.com/drive/folde...Om?usp=sharing
Old 08-04-2020, 20:16   #5 (permalink)
Member: 2213704
Thanks Meter: 22
EasyJtag Suite Classic ver.: 3.7.0.11 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 10 (build 18363), 64-bit edition. Admin rights FAIL
QUALCOMM Direct ver:1.0.6936.8894
Box Drivers version: 10.0.18362.1
Z3X Card Serial : AAD3-6500 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED
Found 2 serial devices
COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3)
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
Z3X EasyJtag Software ver. 3.7.0.11
UFS Socket Info.
Serial: 0123CDF31E336EBBEE
Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20
Done.
UFS Socket Info.
Done.
When VCC is not connected on Chip
Can't open link, Code: -51, Reason: BOX: Socket not detected
Done.
Done.
Done.
This log is when I solder VCC to Chip, Then Socket is NOT Detected at all withn Easy Jtag Plus Box. My UFS BGA 254/ISP Socket is the Same as in the Images of the Above Posters Socket
Old 08-04-2020, 21:09   #6 (permalink)
Member: 2213704
Thanks Meter: 22
Link to UFS BGA24/ISP SOCKET : https://drive.google.com/drive/my-drive
Old 08-05-2020, 08:05   #7 (permalink)
Member: 2213704
Thanks Meter: 22
Still Not Working, ANY SOLUTION FROM EASY JTAG SUPPORT??
UFS Socket Info.
Done.
UFS Socket Info.
Done.
UFS Socket Info.
Done.
Old 08-06-2020, 14:56   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,492
you need post correct links to photos
this link to owner (no you) drive
Old 08-06-2020, 18:04   #9 (permalink)
Member: 2772222
Thanks Meter: 9
And my case, Layder?
Old 08-08-2020, 01:03   #11 (permalink)
Member: 2772222
Thanks Meter: 9
Solved.
Changed Conductor wire (enamelled).
Source: EasyJtag Port [UFS]
Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
UFS Power Mode: LOW
Scanner Thread Created..
Running EasyJtag UFS Mode...
UFS ISP Mode: ON
UFS Safe Mode: ON
Init UFS Engine: 0/OK
EasyJtag Plus S/N: 7B190175A139DA2B
EasyJtag Plus Box FirmWare: 2.52
Box Hardware  = EasyJtag 2nd Generation
UFS: Socket Info:
 S/N: 0x0123BD84CE3026E4EE
 Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 10.01.20
 Type: EasyJtag UFS Socket BGA-254
UFS: Voltage Info:
 Mode: LOW
 VCC : 3259 mV, VCCQ2: 1916 mV
 3v3 : 3314 mV, 1v2: 1220 mV
UFS: Memory Info:
 Connection: Socket BGA-95
 Vendor: SAMSUNG
 S/N: 0xFBEC6A110C037D041395EEF3FC824E39343137413841
 OEM ID: SAMSUNG_OEM_ID
 Firm Version: 0
 Max LUNs: 8
 LUNs Cnt: 3
 W-LUNs Cnt: 1
 LUNs ReConfig: Disabled
UFS Health Info:
UFS Life Time A: 0x01 -> 0% - 10% Life Time Used
UFS Life Time B: 0x01 -> 0% - 10% Life Time Used
UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks
UFS: LUNs Info:
 LUN 0 -> Size: 7810048 Block(s)/29,79 GB
 LUN 1 (Boot A) -> Size: 1024 Block(s)/4,00 MB
 LUN 2 (Boot B) -> Size: 1024 Block(s)/4,00 MB
 W-LUN 0xC4 (REPORT LUNS) -> Size: 16384 Block(s)/4,00 MB
UFS Init OK
Scanning Data From UFS Chip. Please wait..
Scanning GUID Partition Table from LUN 0
GUID Partition Table is Found. Max Parts: 128
GPT: GPT   [000000000000 - 000000006000] Size: 24,00 KB
GPT: BOTA0   [000000400000 - 000000400000] Size: 4,00 MB
GPT: BOTA1   [000000800000 - 000000400000] Size: 4,00 MB
GPT: EFS   [000000C00000 - 000001400000] Size: 20,00 MB
GPT: PARAM   [000002000000 - 000000800000] Size: 8,00 MB
GPT: BOOT   [000002800000 - 000001C00000] Size: 28,00 MB
GPT: RECOVERY   [000004400000 - 000002200000] Size: 34,00 MB
GPT: OTA   [000006600000 - 000000800000] Size: 8,00 MB
GPT: RADIO   [000006E00000 - 000002A00000] Size: 42,00 MB
GPT: TOMBSTONES   [000009800000 - 000000100000] Size: 1,00 MB
GPT: DNT   [000009900000 - 000000100000] Size: 1,00 MB
GPT: PERSISTENT   [000009A00000 - 0000000C0000] Size: 768,00 KB
GPT: STEADY   [000009AC0000 - 000000040000] Size: 256,00 KB
GPT: PERSDATA   [000009B00000 - 000000900000] Size: 9,00 MB
GPT: SBFS   [00000A400000 - 000000F00000] Size: 15,00 MB
GPT: SYSTEM   [00000B300000 - 0000E7400000] Size: 3,61 GB
GPT: CACHE   [0000F2700000 - 00000C800000] Size: 200,00 MB
GPT: HIDDEN   [0000FEF00000 - 00000C800000] Size: 200,00 MB
GPT: USERDATA   [00010B700000 - 000667000000] Size: 25,61 GB
GPT: BACKUP_GPT   [000772BFB000 - 000000005000] Size: 20,00 KB
Reading Table Completed
Scanning GUID Partition Table from LUN 1
GPT Signature Not Found. Break..
Scanning GUID Partition Table from LUN 2
Partition #5   mount as [/efs] -> 20,00 MB
Partition #15   mount as [/persdata/absolute] -> 9,00 MB
Partition #16   mount as [/dev_16] -> 15,00 MB
Partition #17   mount as [/system] -> 3,61 GB
Partition #18   mount as [/cache] -> 200,00 MB
Partition #19   mount as [/preload] -> 200,00 MB
Partition #20   mount as [/data] -> 25,61 GB
EmptyCheck:
 EMPTY -> #2 - [BOTA0]
 EMPTY -> #3 - [BOTA1]
 EMPTY -> #8 - [OTA]
 EMPTY -> #10 - [TOMBSTONES]
 EMPTY -> #11 - [DNT]
 EMPTY -> #12 - [PERSISTENT]
EmptyCheck: Done
Android Info:
Brand           = samsung
Vendor          = samsung
Device          = zeroflte
Model           = SM-G920I
Product         = zeroflte
Platform        = exynos5
CPU ABI         = arm64-v8a
Android Version = 6.0.1
Firm Version    = MMB29K.G920IUBU3EQE3
Inc. Version    = G920IUBU3EQE3
Firm Date       = Mon May 22 22:52:50 KST 2017
Security Patch  = 2017-05-01
Sams CPU        = exynos7420
Samsung S/N     = RQ8H30NERSD
Old 08-08-2020, 03:36   #12 (permalink)
Member: 1991929
Thanks Meter: 93
Thumbs up please post pic
Originally Posted by JefMaximo View Post
Solved.
UFS Power Mode: LOW
UFS ISP Mode: ON
UFS Safe Mode: ON
UFS: Socket Info:
UFS: Voltage Info:
 Mode: LOW
UFS: Memory Info:
 Vendor: SAMSUNG
 Firm Version: 0
 Max LUNs: 8
 LUNs Cnt: 3
 W-LUNs Cnt: 1
UFS Health Info:
UFS: LUNs Info:
UFS Init OK
EmptyCheck:
 EMPTY -> #8 - [OTA]
EmptyCheck: Done
Android Info:
Brand           = samsung
Vendor          = samsung
Device          = zeroflte
Model           = SM-G920I
Product         = zeroflte
Platform        = exynos5
CPU ABI         = arm64-v8a
please post pic of your reference sir soo others can follow this kind of problem...TIA
Old 08-08-2020, 06:58   #13 (permalink)
Member: 2213704
Thanks Meter: 22
Solved.
UFS Power Mode: LOW
UFS ISP Mode: ON
UFS Safe Mode: ON
UFS: Socket Info:
UFS: Voltage Info:
 Mode: LOW
UFS: Memory Info:
 Vendor: SAMSUNG
 Firm Version: 0
 Max LUNs: 8
 LUNs Cnt: 3
 W-LUNs Cnt: 1
UFS Health Info:
UFS: LUNs Info:
UFS Init OK
EmptyCheck:
 EMPTY -> #8 - [OTA]
EmptyCheck: Done
Android Info:
Brand           = samsung
Vendor          = samsung
Device          = zeroflte
Model           = SM-G920I
Product         = zeroflte
Platform        = exynos5
CPU ABI         = arm64-v8a
Please, share pictures of Wire and Connection
Old 08-15-2020, 20:43   #14 (permalink)
Member: 2866741
Got a Poblem with EasyJTAG and bga 254
Hello, i need some help, i have my box updated with the last firmware, and when i try to read a UFS Chip with EasyJtag Plus Suite i get the message UFS Init Failed, error: 0; what i read in other post is that i have to download an old version of Classic Suite and open it pressing the left ctrl key so if flash the box with an old firmware and then it works with the old classic suite, i need to make it work with the last easyjtag plus suite, can anybody please help me? this is obviously a firmware error. I bought this box and the bga254 adaptor and they weren't cheap, plus my customer is waiting for couple weeks
Old 08-15-2020, 20:43   #15 (permalink)
Member: 2213704
Thanks Meter: 22
Layder, what's wrong with my UFS BGA 254 ISP Socket I Still Can't detect Any Ufs Chip via ISP. Or is my Socket Faulty from factory
The Following User Says Thank You to Fg4ty899tt For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.24293 seconds with 7 queries
