12-29-2020, 16:21 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: bahrain
Member: 587083 Status: Offline Thanks Meter: 31 | Easy -jtag plus ufs not working always please check this error please check the image https://imgupload.io/image/jlwDM https://imgupload.io/image/jl19E https://imgupload.io/image/jlSy2 https://imgupload.io/image/jlmEI see if emmc is working fine https://imgupload.io/image/jlrxB i am usinf ufs ic friend & z3x plus easy jtag ufs same issue any idea ho to solved please help |
12-29-2020, 17:37 | #2 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | Quote:
and what ufs chip you test? what brand? | |
12-29-2020, 17:39 | #3 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
51 error - socket not detected (without cryptochip) you need contact with socket seller to change it | |
01-01-2021, 06:45 | #7 (permalink) |
Member: 587083 Status: Offline Thanks Meter: 31 | easy jtag product supporter mr blang please help my easy jtag not working hi how to solved this problem EasyJtag Suite Classic ver.: 3.7.0.20 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 18363), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 1.2.0.0 Z3X Card Serial : AA25-A36C , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 1 serial devices COM8 USB\VID_1781&PID_AAAC&REV_0100&MI_00 EasyJTAG Command Port (COM8) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.20 UFS Socket Info. Serial: 0123D610213CB7FDEE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 09.12.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. first i try my sucket to other easy jtag its working fine my easy jtag is the problem how to solved this problem easy jtag product supporter please help me |
01-01-2021, 20:39 | #8 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | But reason has been given did u try another adaptor make sure u use ryt adaptors bse easy jtag and jtag plus have difrnt pinning despite the same manufacture Sent from my iPhone using Tapatalk |
01-02-2021, 10:43 | #9 (permalink) | |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | Quote:
witch connection you used? better described clearly what you want to do if you need some help | |
01-02-2021, 12:22 | #10 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | First error, whatyou have is -51 - socket not found Second error - 56 - chip not found if chip not connect at socket - try to reball chip and clearing sockets pins BGA254 socket work with UFS chips directly socket to box connection and with eMMC with additional adapter connection and, please, do not SPAM some message to few topics Last edited by layder; 01-03-2021 at 12:28. |
The Following User Says Thank You to layder For This Useful Post: |
01-03-2021, 13:53 | #11 (permalink) | |
Member: 587083 Status: Offline Thanks Meter: 31 | Quote:
01-03-2021, 14:20 | #12 (permalink) | |
for this you need post complete information, which chip, which socket, photo of the connection. then we can understand something. you have not provided anything. I don't know what you are doing differently from other people | |
01-04-2021, 09:37 | #13 (permalink) | |
https://www.youtube.com/watch?v=51CJ_y24U74 | |
