Old 08-03-2022, 16:35   #1 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 469
Help unable connect SM-A035F
Hello everyone i tried to connect this phone to reset phone but box not detect the phone everything soldier correctly using this guy setup https://forum.gsmhosting.com/vbb/f67...-jtag-3025875/ but failed to connect CMD Timeout Error
eMMC_tool ver. 2.0.1.0 (release date: 05.05.2021)
Microsoft Windows 10 (64 bit) build 22000 (10.0.22000.708)
Looking for EasyJTAG box...
EasyJTAG API ver. 3403
EasyJTAG Box Serial = 17FFF01A8601862E
Card Serial = AAEA1B3C
EasyJTAG Box Firmware = 1.6300
Changelog:
05/05/2021 (ver 1.6.6.0)
Add: New keys for Oppo unpack
Fix: Bugs that have been found through your crash report
05.05.2021 (ver 2.0.1.0)
Add: Vendor LG
Add: Mediatek Preloader Parser
Add: OnePlus Unpacker
Add: Xiaomi Custom EDL Authorization
Add: Xiaomi Remove Mi Account (only Qualcomm)
Operation: Connect to Z3X EasyJtag
Setting Interface to EasyJtag1/ISP
Setting IO Levels to 1.8V
Setting Frequence to 21 Mhz
Setting BusWidth to 1 Bit
CMD Pullup Level: 1660 mV
CMD Active Level: 1742 mV
Setting HS Timing to Enabled
Can't init device. Error: -1. Reason: CMD Timeout Error
CMD Pullup Level: 1691 mV
Setting IO Levels to 2.8V
CMD Pullup Level: 2660 mV
CMD Active Level: 2732 mV
apricated any help please
Best Regards | Yoba
Old 08-04-2022, 10:42   #2 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 252
bro i see you dont know how to play voltage io on box...just connect cmd clk dat0 and ground wires put charging flex and plug usb to use vcc and vccq from phones power supply..then use high power mode in box..if you still struggle to conect then you need to remove that emmc on the board for stable connection
The Following User Says Thank You to simpleprince49 For This Useful Post:
Old 08-04-2022, 14:49   #3 (permalink)
Member: 2793734
Thanks Meter: 22
how to solder rst pin on easy jtag plus. other pins clk cmd dat0 have points but rst has no point. help
Old 08-04-2022, 16:41   #4 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 469
Sir i do just like you said solder all three cmd,data0,clk forgetting the two power and plug usb but nothing not connect ... Does it need pullup resistor? One thing i notice is is it normal to detect spd port when i plug usb..? There is spd port in device manager when i plug the device is there something short or its normal
Best Regards | Yoba
Old 08-04-2022, 18:17   #5 (permalink)
Member: 2793734
Thanks Meter: 22
i worked on that phone but i connected all points cmd clk dat0, 2.8 1.8 gnd
it will work
Page generated in 0.14519 seconds with 8 queries
