GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Easy-Jtag / Easy-Jtag Plus (https://forum.gsmhosting.com/vbb/f672/)
-   -   EasyJTAG Box Addon "Emmc File Manager" addon Released. (https://forum.gsmhosting.com/vbb/f672/easyjtag-box-addon-emmc-file-manager-addon-released-2210118/)
mister magoo 05-30-2017 04:36
can anybody help me !! J7 excel repaired and certified by z3x all in order !! But after hard reset factory is only on emergency call, what do i have to do to not lose the certification of imei after hard reset ..
chemik007 07-03-2018 12:01
add-on license
Is this add-in able to recover data from the ntfs nokia windows mobile partition? At the moment, without a license, I only have the appearance of the partition size.
License purchase possible only on the Russian-language website of the producer?
http://v-lab.pl/ntfs.jpg
chemik007 07-03-2018 12:03
Will the files from the partition "DATA" in the photo be visible?
layder 07-09-2018 08:17
to recover files you may use easyjtag_emmc_plus_1.5.1
to recover phonebook/viber/wattsapp/messages you need to buy license
1.16 version available at shell
layder 08-06-2018 18:07
Z3X Emmc Manager 1.17 release
!! Requires firmware v1 of the box> = 1.62 / v2 of the box> = 2.29 !!
!! The program requires the activated Z3X CARD (JTAG) !!
- Updated SQLite library to 3.24.0
- Fixed bug when extracting contacts
- Fixed bug when closing session resulting in data corruption
- Improved extraction from store.vol (additional fields)
- New store.vol location paths added
- Improved detection of contact names when retrieving from store.vol
- Added blocking of voltage selection when working in E-Socket mode (v2 Box)
- Enhanced Extensensic mode
- Added support for markup for nVidia from Rom2 / Rom3
- Mass change of Attributes for selected files / folders is added
- Added change / mass change UID / GID for selected files / folders (EXT4)
- Added the ability to bulk upload files / folders to EXT4 / FAT (Upload Folder)
- Added automatic saving and restoration of Attributes / UID / GID / XATTR when replacing the file (EXT4 / FAT)
- For the first time in the World - SELinux / XATTR support for EXT4
- Added display of all SELinux / XATTR in the Properties window (View Properties)
- Added Add / Edit / Bulk add / change SELinux / XATTR for selected files / folders (EXT4)
- Changed default rights for new files / folders when creating (EXT4) Files - 644, folders - 775, symlink - 775
- Added Removing Notes from Samsung Devices (Tools / Extract tab of Samsung Memo)
- Added extraction of Notes from Notepad ++ application (Tools / Extract Contacts / SMS tab)
- Added extraction of Notes from the GreenDield application (Tools / Extract Contacts / SMS tab)
- Added Extract Hash and Salt for hacking Android Password (Crack Android PIN Code)
- Added automatic decryption of Android PIN (digital password) for Android 2.xx - 5.xx (Crack Android PIN Code)
- Added the change of the mount point of the partition after recording by vendor (Requires HTC, etc. otherwise bootloop)
- Added verification for writing / erasing, (Disable in settings - Check Write / Erase Data)
- Added shortening of logs when retrieving data (Disable in settings - Show Less Debug Data)
- Added fast check of sections on "emptiness" (Thanks to InfinityBox / JayDi) (Disables in settings - Empty Check)
- Many small and inconspicuous changes =)
Empty test is displayed when accessing a section on the Browser tab:
TRUE = Section is empty,
FALSE = Data is in the partition,
DATA = The partition contains the file system.
Decryption Android PIN supports Android 2.xx - 5.xx, file password.key, gatekeeper. * NOT supported.
Decryption of the alphanumeric password takes a long time, therefore it is not implemented. Use third-party utilities. (For example - oclHashCat)
Adding / Changing SELinux / XATTR - requires knowledge of these add-ons. security rights. Do not try to enter incorrect values.
Some function are requared third party licence (world licence)
http://www.uo5oq.com/index.php?do=us...&productid=646
download: https://mega.nz/#!eMAESIrT!KZcoNdfpB...oBRjuAO0HG4a1E
Sakalalina 09-12-2018 09:06
i love this tool, i've recovered many and many data from emmc!
I got one question now...i have to recover some data from a Huawei EMMC, the model of the phone is: WAS-LX1A...§the tool can detect it correctly, and can mount system and other partition, but not userdata...
it's due to an encryption?
Z3X EasyJtag EMMC File Manager v 1.17-CPP Rel at 05/08/2018 started..
EasyAPI version: [2100]
Easy FileSystem version: [05082018]
SQLite Engine version: [3.24.0]
Fsck API version: [05082018]
Ese API version: [05082018]
Z3X Card Serial:
EasyJtag PLUS Box Found at [COM8]
EasyJtag Box Firmware: [2.30]
Generation: GPT [QC/SAMS]
Box Voltage set to: [2800] mV
Scanner Thread Created.
Setup HiPower CLK: [OFF]
Connecting To EasyJtag Box: [2800mV/42MHz/8BIT]
EasyJtag Box Found! Result: [0/OK]
EasyJtag S/N:
EasyJtag Firm: [2.30]
Box Bus Width = 8 BIT
Box Hardware  = EasyJtag 2nd Generation
Search EMMC Chip...
Testing Box Interface
 PIN CLK : 1724 mV - Pin OK
 PIN CMD : 1732 mV - Pin OK
 PIN DAT0: 1734 mV - Pin OK
 PIN DAT1: 1728 mV - Pin OK
 PIN DAT2: 1729 mV - Pin OK
 PIN DAT3: 1729 mV - Pin OK
 PIN DAT4: 1734 mV - Pin OK
 PIN DAT5: 1730 mV - Pin OK
 PIN DAT6: 1727 mV - Pin OK
 PIN DAT7: 1729 mV - Pin OK
Test End
EMMC Chip Found! [0/OK]
EMMC CID: [90014A484247346132D405C080BA546B]
EMMC CSD: [D02701328F5903FFFFFFFFE78A400017]
EMMC VENDOR: [SKHYNIX]
EMMC NAME: [HBG4a2]
EMMC ROM1 Size: [61071360 Block(s)/29820 MB]
EMMC ROM2/3 Size: [8192 Block(s)/4096 KB]
EMMC RPMB Size: [8192 Block(s)/4096 KB]
Switch To ROM1 Part: [0/OK]
Scanning Data From EMMC. Please wait..
Found GPT Table at 0x000000000200
Max Parts: [128]
GPT: VRL            [000000080000/000000040000] SIZE: 256,00 KB
GPT: VRL_BACKUP      [0000000C0000/000000040000] SIZE: 256,00 KB
GPT: FW_LPM3        [000000100000/000000040000] SIZE: 256,00 KB
GPT: FRP            [000000140000/0000000C0000] SIZE: 768,00 KB
GPT: FASTBOOT        [000000200000/000000400000] SIZE: 4,00 MB
GPT: MODEMNVM_FACTORY  [000000600000/000000400000] SIZE: 4,00 MB
GPT: NVME            [000000A00000/000000600000] SIZE: 6,00 MB
GPT: OEMINFO        [000001000000/000004000000] SIZE: 64,00 MB
GPT: RESERVED3      [000005000000/000000400000] SIZE: 4,00 MB
GPT: MODEMNVM_BACKUP  [000005400000/000000400000] SIZE: 4,00 MB
GPT: MODEMNVM_IMG    [000005800000/000000800000] SIZE: 8,00 MB
GPT: MODEMNVM_SYSTEM  [000006000000/000000400000] SIZE: 4,00 MB
GPT: SECURE_STORAGE  [000006400000/000002000000] SIZE: 32,00 MB
GPT: RESERVED4      [000008400000/000000200000] SIZE: 2,00 MB
GPT: RESERVED5      [000008600000/000000200000] SIZE: 2,00 MB
GPT: PERSIST        [000008800000/000000200000] SIZE: 2,00 MB
GPT: RESERVED1      [000008A00000/000000E00000] SIZE: 14,00 MB
GPT: MODEM_OM        [000009800000/000002000000] SIZE: 32,00 MB
GPT: SPLASH2        [00000B800000/000004000000] SIZE: 64,00 MB
GPT: MISC            [00000F800000/000000200000] SIZE: 2,00 MB
GPT: MODEMNVM_UPDATE  [00000FA00000/000001800000] SIZE: 24,00 MB
GPT: RESERVED2      [000011200000/000003C00000] SIZE: 60,00 MB
GPT: TEEOS          [000014E00000/000000400000] SIZE: 4,00 MB
GPT: TRUSTFIRMWARE  [000015200000/000000200000] SIZE: 2,00 MB
GPT: SENSORHUB      [000015400000/000001000000] SIZE: 16,00 MB
GPT: FW_HIFI        [000016400000/000000C00000] SIZE: 12,00 MB
GPT: ERECOVERY_KERNEL  [000017000000/000001800000] SIZE: 24,00 MB
GPT: ERECOVERY_RAMDISK  [000018800000/000002000000] SIZE: 32,00 MB
GPT: ERECOVERY_VENDOR  [00001A800000/000001000000] SIZE: 16,00 MB
GPT: KERNEL          [00001B800000/000001800000] SIZE: 24,00 MB
GPT: RAMDISK        [00001D000000/000001000000] SIZE: 16,00 MB
GPT: RECOVERY_RAMDISK  [00001E000000/000002000000] SIZE: 32,00 MB
GPT: RECOVERY_VENDOR  [000020000000/000001000000] SIZE: 16,00 MB
GPT: DTS            [000021000000/000001C00000] SIZE: 28,00 MB
GPT: DTO            [000022C00000/000000400000] SIZE: 4,00 MB
GPT: MODEM_FW        [000023000000/000006000000] SIZE: 96,00 MB
GPT: RECOVERY_VBMETA  [000029000000/000000100000] SIZE: 1,00 MB
GPT: ERECOVERY_VBMETA  [000029100000/000000100000] SIZE: 1,00 MB
GPT: RESERVED8      [000029200000/000000200000] SIZE: 2,00 MB
GPT: DFX            [000029400000/000001000000] SIZE: 16,00 MB
GPT: VBMETA          [00002A400000/000000400000] SIZE: 4,00 MB
GPT: CACHE          [00002A800000/000008000000] SIZE: 128,00 MB
GPT: ODM            [000032800000/000008000000] SIZE: 128,00 MB
GPT: HISITEST0      [00003A800000/000000200000] SIZE: 2,00 MB
GPT: HISITEST1      [00003AA00000/000000200000] SIZE: 2,00 MB
GPT: HISITEST2      [00003AC00000/000000400000] SIZE: 4,00 MB
GPT: PATCH          [00003B000000/000002000000] SIZE: 32,00 MB
GPT: BOOTFAIL_INFO  [00003D000000/000000200000] SIZE: 2,00 MB
GPT: RRECORD        [00003D200000/000001000000] SIZE: 16,00 MB
GPT: RESERVED9      [00003E200000/000001E00000] SIZE: 30,00 MB
GPT: SYSTEM          [000040000000/000125000000] SIZE: 4,58 GB
GPT: CUST            [000165000000/00000C000000] SIZE: 192,00 MB
GPT: VERSION        [000171000000/000002000000] SIZE: 32,00 MB
GPT: VENDOR          [000173000000/000031000000] SIZE: 784,00 MB
GPT: PRODUCT        [0001A4000000/00000C000000] SIZE: 192,00 MB
GPT: USERDATA        [0001B0000000/000597C00000] SIZE: 22,37 GB
Partition #11  mount as [/mnvm2:0] -> [8,00 MB]
Partition #13  mount as [/sec_storage] -> [32,00 MB]
Partition #18  mount as [/modem_log] -> [32,00 MB]
Partition #19  mount as [/splash2] -> [64,00 MB]
Partition #36  mount as [/dev_36] -> [96,00 MB]
Partition #42  mount as [/cache] -> [128,00 MB]
Partition #43  mount as [/dev_43] -> [128,00 MB]
Partition #51  mount as [/dev_51] -> [4,58 GB]
Partition #52  mount as [/dev_52] -> [192,00 MB]
Partition #53  mount as [/dev_53] -> [32,00 MB]
Partition #54  mount as [/dev_54] -> [784,00 MB]
Partition #55  mount as [/dev_55] -> [192,00 MB]
EmptyCheck: Done
Scanner Thread Terminated, Elapsed: [00:00:02:361]
Found 56 Partition(s)..
Scan Done. Init Engine...
Resetting EasyJtag Box. Wait..
Reader Engine Initialized.. [0/OK]
Bus Mode: [8BIT]
Operation Done. [Init Engine], Elapsed: [00:00:00:894]
wgmmmx1 10-05-2018 21:06
Заказ Логов, Кредитов, Активаций - NCK, RPL, Логи, Активации GSM
How can buy this someone from europe ? I try liqpay and visa metode to add money to account but both not work with my visa credits card always error.
yuluosheng 10-06-2018 22:50
Update spa CPU support jtag writes
layder 10-07-2018 00:03
Try to write to uo5oq support: http://www.uo5oq.com/index.php?do=private&go=newpm
[email protected] 03-01-2019 16:28
I paid them by PayPal 2 days ago. Got Activation in 30 min
layder 05-27-2019 10:22
5 Attachment(s)
EasyJTAG Files Manager test version added UFS interface
Samsung S6/S6 edge (non crypted) can extract userdata
layder 10-24-2019 10:33
Official support https://t.me/joinchat/Ci7K71Ey6ohvYmNvjZ47bA
oktay50000 10-25-2019 05:34
is it possible to do on chip ufs?
sktamrkar 10-25-2019 10:40
Sir link is broken. Plz give another link.
Thnx
layder 10-25-2019 12:00
1.17 version is present at shell
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.16964 seconds with 6 queries
