02-26-2018, 07:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Where is wrong 8297-l100 Read eMMC Info.................... PHP Code: PHP Code: Write Xml. File Done Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 Mhz CMD Pullup Level: 2095 mV CMD Active Level: 2727 mV EMMC Device Information : EMMC CID: 90014A48384731650507E90530315259 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: E9053031 , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G1e_E9053031_20180226_111154.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Operation: Write by vendor (Qualcomm/HiSilicon) Creating GPT-partitioninig Error writing at address: 0001D1FFBE00 , error: 33 , 33 Unknown error ... Retry #1 Error writing at address: 0001D1FFBE00 , error: 33 , 33 Unknown error ... Retry #2 GPT-partitioning done Partition name: modem Filename: NON-HLOS.bin , Offset: 000002000000 , filesize: 47793664 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 4049.17 KB/s Partition name: sbl1 Filename: sbl1.mbn , Offset: 000006000000 , filesize: 250664 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3186.25 KB/s Partition name: sbl1bak Filename: sbl1.mbn , Offset: 000006080000 , filesize: 250664 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3570.87 KB/s Partition name: aboot Filename: emmc_appsboot.mbn , Offset: 000006100000 , filesize: 2255244 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3815.31 KB/s Partition name: abootbak Filename: emmc_appsboot.mbn , Offset: 000007000000 , filesize: 2255244 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3924.40 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 000007F00000 , filesize: 150848 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2181.15 KB/s Partition name: rpmbak Filename: rpm.mbn , Offset: 000007F80000 , filesize: 150848 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2455.44 KB/s Partition name: tz Filename: tz.mbn , Offset: 000008000000 , filesize: 387016 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3159.57 KB/s Partition name: tzbak Filename: tz.mbn , Offset: 000008080000 , filesize: 387016 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3453.93 KB/s Partition name: hyp Filename: hyp.mbn , Offset: 000008100000 , filesize: 20520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1430.27 KB/s Partition name: hypbak Filename: hyp.mbn , Offset: 000008180000 , filesize: 20520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1553.98 KB/s Partition name: modemst1 Filename: dummy.bin , Offset: 000008300000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3850.16 KB/s Partition name: modemst2 Filename: dummy.bin , Offset: 000008480000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 4044.50 KB/s Partition name: misc Filename: MISC.img , Offset: 000008600000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3865.66 KB/s Partition name: fsg Filename: nv.tar.mbn , Offset: 00000A008000 , filesize: 77608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1635.47 KB/s Partition name: sec Filename: sec.dat , Offset: 00000A188000 , filesize: 428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 92.97 KB/s Partition name: boot Filename: boot.img , Offset: 00000A18C000 , filesize: 8366080 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 4000.50 KB/s Partition name: params Filename: param.bin , Offset: 00000C000000 , filesize: 10752 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 508.44 KB/s Partition name: panic Filename: panic.img , Offset: 00000C100000 , filesize: 4579328 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 4011.03 KB/s Partition name: system Filename: system.img , Offset: 00000E000000 , filesize: 1513087820 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 3140 Done writing partition. Write speed: 3955.42 KB/s Partition name: persist Filename: persist.img , Offset: 00008E000000 , filesize: 4427960 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 3906.00 KB/s Partition name: cache Filename: cache.img , Offset: 00008EA00000 , filesize: 6348948 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 3927.41 KB/s Partition name: recovery Filename: recovery.img , Offset: 000096A00000 , filesize: 8953856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 4015.44 KB/s Partition name: userdata Filename: userdata.img , Offset: 000097E00000 , filesize: 259079868 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 312 Done writing partition. Write speed: 3992.26 KB/s All done time: [00:10:11:903] |
