06-24-2020, 04:06 | #16 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2772222 Status: Offline Thanks Meter: 9 | Please add the possibility to flash Motorola phones. In Brazil motorola cell phones are very common. Some devices from motorola are coming with ARB (Anti-Roll Back) and the only way to flash would be via eMMC. |
06-24-2020, 16:48 | #19 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | easyjtag_emmc_plus_1.6.3.0_23.06.2020_FW2.52 is present on z3x shell - new: 2.52 box firmware (EasyJTAG Plus box) - added: possibility to change VCCQ power for E-Socket (1.8v need for some Hynix IC) - fixed: Repartition on Xiaomi Redmi 6A and other (correct GPT creation) - fixed: Bugfix based on crash reports |
06-25-2020, 07:18 | #20 (permalink) | |
Freak Poster Join Date: Mar 2019 Location: Bahawal Nagar Age: 34
Member: 2902578 Status: Offline Thanks Meter: 151 | 21 -06 2020 test Quote:
06-27-2020, 12:50 | #25 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | |
06-29-2020, 05:32 | #26 (permalink) |
Freak Poster Join Date: Nov 2015 Location: pak Age: 39
Member: 2487963 Status: Offline Thanks Meter: 65 | EasyJtag Release v3.7.0.11. setup bug no back up extcsd.no info notpad BuildProp not pad info empty EasyEMMCLog file empty please team fix this |
The Following User Says Thank You to muhammadrafique For This Useful Post: |
07-02-2020, 02:27 | #28 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | have same problem in a20s cant read after update , easy jtag tool and easy jtag plus. and other box read normal. Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: , ,FW Ver.: 02.52 CMD Pullup Level:462 mV CMD Active Level:2388 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. /07/2020 1:49:08 p. m.> EasyJTAG Box Firmware = 2.5201 1/07/2020 1:49:09 p. m.> Setting interface to EasyJtag2/ISP 1/07/2020 1:49:09 p. m.> Setting bus width to 1 Bit 1/07/2020 1:49:09 p. m.> 1/07/2020 1:49:13 p. m.> Looking for EasyJTAG box... 1/07/2020 1:49:13 p. m.> EasyJTAG API ver. 3401 1/07/2020 1:49:13 p. m.> Setting IO Levels to 2.8V 1/07/2020 1:49:13 p. m.> Setting frequence to 9 MHz 1/07/2020 1:49:13 p. m.> EasyJTAG Box Serial = 1/07/2020 1:49:13 p. m.> EasyJTAG Box Firmware = 2.5201 1/07/2020 1:49:14 p. m.> Setting interface to EasyJtag2/ISP 1/07/2020 1:49:14 p. m.> Setting bus width to 1 Bit 1/07/2020 1:49:14 p. m.> Setting frequence to 9 MHz 1/07/2020 1:49:14 p. m.> CMD Pullup Level: 454 mV 1/07/2020 1:49:14 p. m.> CMD Active Level: 2386 mV 1/07/2020 1:49:14 p. m.> eMMC Init returned = -1 1/07/2020 1:49:14 p. m.> Can't init device. Reason: CMD Timeout Error 1/07/2020 1:49:14 p. m.> other box read fine Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1687552 Number of sectors : 7864320 Build ID : QP1A.190711.020 Display Build ID : QP1A.190711.020.A207MUBU2BTD7 Release ID : 10 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a20sub-user 10 QP1A.190711.020 A207MUBU2BTD7 release-keys |
