Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #18 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2012 Location: ESFAHAN-IR_09133267585
Member: 1725706 Status: Offline Thanks Meter: 189 | ![]() Quote:
Hello, please fix the problem of not reading or not formatting the Samsung emmc b412 16gb in the next version. Thanks br: masoud salamat | |
![]() | #20 (permalink) |
Member: 1725706 Status: Offline Thanks Meter: 189 | Kmk8x000vm-b412/16gb {KMK8X000VM-B412/16GB} ---------- eMMC Device Information ---------- eMMC CID : 1501004B3858564D4201585BDEE4B15D eMMC CSD : D02701320F5903FFF6DBFFEF92404009 eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2014 Rev.0x1 eMMC NAME: K8XVMB , S/N: 1482415844 eMMC NAME (HEX): 4B3858564D42 IC Name: Samsung , KMK8X000VM-B412/16GB+LPDDR2 8Gb @FBGA162 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: K8XVMB_1482415844_20200908_0924.extcsd Partition info not found Done. Checking security ... Running:eMMC: Factory Format Z3X EasyJtag Software ver. 3.7.0.20 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:14000 kHz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Failed. Repairing... eMMC Repair Operation Failed. Done. |
![]() | #23 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2002 Location: Belarus Age: 44
Member: 13148 Status: Offline Thanks Meter: 2,495 | Quote:
Post plase log of Medusa KMK8X eMMC firmware repair | |
The Following User Says Thank You to layder For This Useful Post: |
![]() | #26 (permalink) |
Junior Member Join Date: Dec 2004 Age: 42
Member: 95818 Status: Offline Thanks Meter: 0 | is there a way to rollback FW updates? the newest version keeps giving me CRC errors for my GPT tables via ISP 1bit, but I've verified they are correct via dumps. Never had errors like this prior to the FW update. |
![]() | #29 (permalink) | |
if you have problems, this means you are using either non-original adapters or do not comply with the requirements for wires | |
![]() | #30 (permalink) |
Junior Member ![]() Join Date: Aug 2016
Member: 2611378 Status: Offline Thanks Meter: 1 | after last update can't read eMMC isp 1bit with 36MHZ , must down speed to 24MHZ or less than to read success. |
The Following User Says Thank You to M.Elarapy For This Useful Post: |
